We are thinking of using Li-NMC batteries, instead of LiPo batteries, at the Li+ pins (or JST).
Li-NMC batteries also have the nominal voltage of 3.7V and maximum voltage of 4.2V, which is the same as LiPo. We may also be connecting a solar panel at our VIN pin, the battery at Li+ will be charging by BQ24195 IC.
I want to ask whether we can simply swap LiPo with Li-NMC batteries? Does the BQ24195 charger support Li-NMC batteries. Given that both battery chemistries have the same voltages, is there anything else to keep in mind while changing the battery chemistries, but keeping the same charge controller.
