Using a Photon on a WEP Wi-Fi network
#1
First of all, you should not use WEP Wi-Fi encryption! It’s so easily broken into you might as well have an open Wi-Fi network. Also, it’s really a pain to configure on the device so you should use WPA2-Personal, instead.
But if for some reason you need to use WEP, here are instructions for doing so. The page also has a handy calculator for dealing with ASCII keys and even the passphrase mode used on Linksys and some other routers, which I think is kind of cool.
http://rickkas7.github.io/wep/
Connectivity - can't connect to one particular WiFi network
#2
Hey Rick thanks for sharing this!
#3
Hi @rickkas7
We are soon to release our P1 product in Mexico. WEP Wifi here is unavoidable.
What do you suggest we can do to help the end customer ? The solution in your post is probably more than they can handle.
cheers
