Use Web IDE to create a bin file then load through USB
I’ve looked around and don’t see a solution to this. I would to do some code development behind an enterprise network using the Web IDE. Since the photon will be isolated from this network, is there a way to copy the compiled bin file from the cloud to a local machine? Then use CLI to load the bin file to the photon over the USB port.
You can tap the cloud icon next to the project name.
This has even got a tooltip telling you what it’s for :wink:
Just what I need. Many thanks. :smiley:
