Use Visual Studio Code for your Particle development needs
sorry to hear about your bad day. Continue to write if you want to commiserate together further, I wasn’t having a super good day either… just not with this platform :slight_smile:
I think what you are after is a on-the-fly parser of the code, that would kick in while you write, but no, I haven’t seen such a piece of plugin/software around. Maybe the arduino plugin in VS Code could evolve to such thing in the future, maybe the Particle DEV could as well. However one can argue that the build process is so quick that “instantaneous feedback” vs “three to five seconds away feedback” is fine for a lot of people.
hope things look better tomorrow for you!
Gustavo.
Thanks.
If this were a language I had 1000 more hours of experience with, I would agree with you fully. As it stands, I fight syntax errors FAR more than anything else. The tooling should be able to assist me with that. I mean that’s what tools and computers are for.
My skills lie partially in C#, and C# is one way to write plugins for Visual Studio, which DOES understand C++ well enough to give me what I’m after.
So I think I’m going to write a Particle extension for Visual Studio.
that would be extremely awesome!
I have fully switched to VSCode for doing Particle development.
Having all the login and device selection in Atom was nice, but the error parser never worked and the lack of control+click for jump-to-definition forced the switch.
To get the error parser working for Particle cloud build in VSCode, I extended the script from the original source in this post. There was a pretty odd thing where “workspace” would be prepended to paths when errors were reported, and you’ll see it removed with the error parser regex.
Works on OSX. Untested on other platforms. Be sure to install the C/C++ extension. Error parsing isn’t always perfect, but it pretty much works and it is very nice to have. Use of a .ino file will not work, since it gets internally renamed to .cpp upon compile.
Here’s my tasks.json:
//tasks.json for Particle online build
"version": "0.1.0",
"command": "particle",
"isShellCommand": true,
"args": [],
"showOutput": "always",
"echoCommand": true,
"tasks": [
        "taskName": "compile",
        "suppressTaskName": false,
        "isBuildCommand": true,
        "args": ["electron","${workspaceRoot}", "--saveTo", "${workspaceRoot}/firmware.bin"],
        // Use the standard less compilation problem matcher.
            "problemMatcher": {
                "owner": "cpp",
                "fileLocation": ["relative", "${workspaceRoot}"],
                "pattern": {
                    "regexp": "^(/workspace|/worksapce/)(.*?):(\\d+):(\\d+):\\s+(warning|error|fatal error):\\s+(.*)$",
                    "file": 2,
                    "line": 3,
                    "column": 4,
                    "severity": 5,
                    "message": 6
                "severity":"error"
        "taskName": "flash",
        "isTestCommand": true,
        "args": ["--usb", "firmware.bin"]
Hi Andrew,
I’d like to give this a shot, but I need to ask you few questions:
How is this supposed to work?
what does it do if you have an error in the code when you compile?
is it supposed to flag the line with the error in the source file itself?
If you have a screenshot with the outcome, I’d like to see it, please.
I tried it in Ubuntu to see if I could find out how and if it would work, but did not succeed at even understanding what it should do.
thanks!
Gustavo.
Hrm, what I wrote above no longer seems to work. The thing I mentioned there, that the string “workspace” was oddly prepended to console lines, does not seem to happen anymore.
I am not sure if I changed something in my environment or shell, or maybe it was part of an update to VSCode or the particle-cli or backend build system since then.
So now, using the following tasks.json file, the warning & error parser should work:
"version": "0.1.0",
"args": [],
"tasks": [
            "problemMatcher": {
                "owner": "cpp",
                "pattern": {
                    "regexp": "^(.*?):(\\d+):(\\d+):\\s+(warning|error|fatal error):\\s+(.*)$",
                    "file": 1,
                    "line": 2,
                    "column": 3,
                    "severity": 4,
                    "message": 5
                "severity":"error"
This is almost exactly the same as this SO response for Makefiles, and the binding for F8 is also useful: https://stackoverflow.com/questions/30269449/how-do-i-set-up-vscode-to-compile-c-code
Here’s a screenshot of how the problems should be picked up by the problem matcher when running the build task:
oh wow, this is beautiful and extremely useful!
I can confirm it works in Ubuntu with VS Code 1.13.0.
You mentioned earlier that this would only work in cpp files, but I’m happy to see it works on ino files too :slight_smile:
Do you mind if I add this info to the hackster project?
thanks!
Gustavo.
Sure, go for it.
It’s kind of nuts to think about how much time I spent and how much code I generated using Atom and the web IDE with little to no error parser. Now, I would not be able to live without it.
Oh, I think the .ino/.cpp is another recent change in the Particle backend or particle-cli ; it used to report back error in Main.ino as Main.cpp, so the error parser went looking for a file that did not exist. But now ther eis name consistency, so it works.
If you're a Visual Studio user, I strongly recommend using Visual studio for your C++ work. You need to abstract the hardware stuff so you get to use all of Visual Studio features including the debugging etc. I'm guessing most of your time is spent in your logic rather than accessing the hardware (directly).
For anything more complicated than Blinky, this is what I do myself. It gives you a lot of opportunity to clean up your code and build good abstractions since you have a really good code editor with refactoring and debugger at your disposal. You can use include the GSL NuGet to get really good Code analysis and guidance as per the C++ Guidelines Support Library.
For example, here is my hardware abstraction interface (abstract class).
Hal.h - Hardware Abstraction Layer for Arduino
Abstracting some basic functions of the Arduino Library
So as to make it possible to decouple Arduino "things"
from other classes, decoupling those classes from Arduino
Created by Shiv Kumar, 2014.
website: http://www.matlus.com
Released into the public domain.
#pragma once
#ifndef Hal_h
#define Hal_h
class Hal {
protected:
public:
	Hal() {}
	virtual ~Hal() {}
	virtual void doPinMode(uint16_t pin, uint8_t mode) = 0;
	virtual void doDigitalWrite(uint16_t pin, uint8_t value) = 0;
	virtual void doAnalogWrite(uint16_t pin, int8_t value) = 0;
	virtual void attach(uint8_t pin) = 0;
	virtual void detach() = 0;
	virtual void write(int position) = 0;
	virtual int doConstrain(int numberToConstrain, int lowerBound, int upperBound) = 0;
	virtual int doMap(int value, int sourceMin, int sourceMax, int targetMin, int targetMax) = 0;
#endif
For my Visual Studio project and I have an implementation (descendant) of this class that uses the Console (std::cout). I have about 7 classes that I can design, develop and test to ensure my application works as expected. Then I simply move all these classes into the Wed IDE or Particle DEV. Of course I have an implementation of the Hal class called HalSpark that looks like this:
  HalSpark.h - Implementation of the Hal abstract class
  where this implementation delegates to the Arduino
  library functions
#pragma once
#ifndef HalSpark_h
#define HalSpark_h
#include "Hal.h"
#include "spark_wiring.h"
class HalSpark : public Hal {
public:
  HalSpark();
  ~HalSpark();
  void doPinMode(uint16_t pin, uint8_t mode) override final;
  void doDigitalWrite(uint16_t pin, uint8_t value) override final;
  void doAnalogWrite(uint16_t pin, int8_t value) override final;
  void attach(uint8_t pin) override final;
  void detach() override final;
  void write(int position) override final;
                  int upperBound) override final;
            int targetMax) override final;
#endif
#include "HalSpark.h"
HalSpark::HalSpark() {}
HalSpark::~HalSpark() {}
void HalSpark::doPinMode(uint16_t pin, uint8_t mode) {
  PinMode pMode = PinMode::OUTPUT;
  switch (mode) {
  case 0:
    pMode = PinMode::INPUT;
    break;
  case 1:
    break;
  case 2:
    pMode = PinMode::INPUT_PULLUP;
    break;
  pinMode(pin, pMode);
void HalSpark::doDigitalWrite(uint16_t pin, uint8_t value) {
  digitalWrite(pin, value);
void HalSpark::doAnalogWrite(uint16_t pin, int8_t value) {
  analogWrite(pin, value);
void HalSpark::attach(uint8_t pin) {
  // No implementation for this yet.
  // Will need to include the Servo Library
void HalSpark::detach() {
void HalSpark::write(int position) {
int HalSpark::doConstrain(int numberToConstrain, int lowerBound,
                          int upperBound) {
  return constrain(numberToConstrain, lowerBound, upperBound);
int HalSpark::doMap(int value, int sourceMin, int sourceMax, int targetMin,
                    int targetMax) {
  return map(value, sourceMin, sourceMax, targetMin, targetMax);
I use a similar thing for sensors and the like.
If the VS Code solution here works, then that's good/preferable I would think.
I’ve gotten just about everything to work by using the tasks.json file that @gusgonnet posted here: https://www.hackster.io/gusgonnet/use-visual-studio-code-for-your-particle-development-needs-9e23bc
However, I do need to add #include “application.h” to the top of my main.cpp. I am still using the default c_cpp_properties.json and do not know what paths to include so that VScode will know where to look for application.h. Does anyone know how where I can go to find that or how I should set up my c_cpp_properties.json so that I don’t get the squiggly warnings?
It’s possible but a super huge pain to get all of the paths correct. You’ll need both the system firmware headers and the headers from the gcc-arm toolchain.
This post shows how to do it with Visual Studio 2017 15.5 preview, which I don’t actually recommend that you try to switch to, however there are enough similarities to VS Code that you should be able to make the same sort of settings and get rid of all of the squiggly warnings in Code.
Hey Alex, I do not know how to do that, so I ignore the warnings... not ideal I admit.
Good luck and let us know if you figured it out with the post above from Rick.
Gustavo.
I think that I need to include the path where “application.h” is on my computer, but I don’t actually know where that is. I feel like that should be something easy, but I’m having a hard time figuring that out.
It’s not just application.h. You need everything that’s included from application.h or Particle.h. Also several of the gcc-arm header files. Also some defines and compiler options. For a Photon using 0.7.0, it’s:
			"name":"Particle photon",
			"includePath":[
				"${workspaceRoot}\\..\\firmware\\communication\\src",
				"${workspaceRoot}\\..\\firmware\\dynalib\\inc",
				"${workspaceRoot}\\..\\firmware\\hal\\inc",
				"${workspaceRoot}\\..\\firmware\\hal\\shared",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\api",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\include",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\libraries\\crypto",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\WWD\\include\\",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\platform\\GCC\\",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\platform\\include\\",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\security\\BESL",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\security\\BESL\\crypto",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\security\\BESL\\host\\WICED\\",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\security\\BESL\\include",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\photon\\wiced\\security\\BESL\\supplicant\\",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\stm32",
				"${workspaceRoot}\\..\\firmware\\hal\\src\\stm32f2xx",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\CMSIS\\Device\\ST\\Include",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\CMSIS\\Include",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\SPARK_Firmware_Driver\\inc",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\STM32_StdPeriph_Driver\\inc",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\STM32_USB_Device_Driver\\inc",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\STM32_USB_Host_Driver\\inc",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\STM32F2xx\\STM32_USB_OTG_Driver\\inc",
				"${workspaceRoot}\\..\\firmware\\platform\\MCU\\shared\\STM32\\inc",
				"${workspaceRoot}\\..\\firmware\\platform\\shared\\inc",
				"${workspaceRoot}\\..\\firmware\\services\\inc",
				"${workspaceRoot}\\..\\firmware\\system\\inc",
				"${workspaceRoot}\\..\\firmware\\user\\inc",
				"${workspaceRoot}\\..\\firmware\\wiring\\inc",
				"${workspaceRoot}\\..\\gcc-arm\\arm-none-eabi\\include",
				"${workspaceRoot}\\..\\gcc-arm\\arm-none-eabi\\include\\c++\\5.3.1",
				"${workspaceRoot}\\..\\gcc-arm\\arm-none-eabi\\include\\c++\\5.3.1\\arm-none-eabi",
				"${workspaceRoot}\\..\\gcc-arm\\arm-none-eabi\\include\\c++\\5.3.1\\arm-none-eabi\thumb",
				"${workspaceRoot}\\..\\gcc-arm\\arm-none-eabi\\include\\c++\\5.3.1\\ext",
				"${workspaceRoot}\\..\\gcc-arm\\lib\\gcc\\arm-none-eabi\\5.3.1\\include",
				"${workspaceRoot}\\src"
			"defines":[
				"BOOTLOADER_SDK_3_3_0_PARTICLE",
				"DFU_BUILD_ENABLE",
				"INCLUDE_PLATFORM=1",
				"LOG_INCLUDE_SOURCE_INFO=1",
				"LOG_MODULE_CATEGORY=\"\\\"app\\\"\"",
				"MODULAR_FIRMWARE=1",
				"MODULE_DEPENDENCY2=0,0,0",
				"MODULE_DEPENDENCY=4,2,207",
				"MODULE_FUNCTION=5",
				"MODULE_INDEX=1",
				"MODULE_VERSION=5",
				"PARTICLE=1",
				"PARTICLE_DCT_COMPATIBILITY",
				"PARTICLE_USER_MODULE",
				"PLATFORM_ID=6",
				"PLATFORM_NAME=photon",
				"PLATFORM_THREADING=1",
				"PRODUCT_FIRMWARE_VERSION=65535",
				"PRODUCT_ID=6",
				"RELEASE_BUILD",
				"SPARK=1",
				"SPARK_PLATFORM",
				"SPARK_PLATFORM_NET=BCM9WCDUSI09",
				"START_DFU_FLASHER_SERIAL_SPEED=14400",
				"START_YMODEM_FLASHER_SERIAL_SPEED=28800",
				"STM32F2XX",
				"STM32_DEVICE",
				"SYSTEM_VERSION_STRING=0.7.0",
				"USBD_PID_CDC=0xC006",
				"USBD_PID_DFU=0xD006",
				"USBD_VID_SPARK=0x2B04",
				"USER_FIRMWARE_IMAGE_LOCATION=0x80A0000",
				"USER_FIRMWARE_IMAGE_SIZE=0x20000",
				"USE_STDPERIPH_DRIVER",
				"_GNU_SOURCE",
				"_WINSOCK_H"
			"compilerSwitches":"-Wall -Wno-error=deprecated-declarations -Wno-switch -Wundef -fcheck-new -fdata-sections -ffunction-sections -fmessage-length=0 -fno-builtin-free -fno-builtin-malloc -fno-builtin-realloc -fno-exceptions -fno-rtti -fno-strict-aliasing -mcpu=cortex-m3 -mthumb -std=gnu++11 ",
			"intelliSenseMode":"linux-gcc-arm"
I was able to remove the red underline from arduino.h by adding this as one of the items in the “configurations” array in my c_cpp_properties.json
"includePath": [
                "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino"
Now just Arduino.h is underlined because it cannot open “avr/pgmspace.h”
Thanks for this info, do you have it for an Electron? I’m trying to get VS code building electron offline.
To help others… I have been able to get OpenOCD and GDB fired up and connecting through VScode.
Here is my launch.json file, I’d be keen for any updates on this. your value may vary.
            "name": "GDB OpenOCD - particle",
            "type": "cppdbg",
            "request": "launch",
            "targetArchitecture": "arm",
            "cwd": "${workspaceRoot}",
            "program": "${workspaceRoot}\\path\\to\\system-part1\\platform-10-m\\system-part1.elf",
            "debugServerPath": "C:/openocd-0.10.0/bin-x64/openocd.exe",
            "debugServerArgs": "-f interface/stlink-v2.cfg -f target/stm32f2x.cfg  -c \"telnet_port 4444\"",// -c init -c \"reset init\" ", //particle
            "filterStderr":"true",
            "filterStdout":"false",
            "serverStarted": "stm32f2x.cpu: hardware has 6 breakpoints, 4 watchpoints",
            "serverLaunchTimeout": 5000,
            "MIMode": "gdb",
            "miDebuggerPath" : "C:/Program Files (x86)/GNU Tools ARM Embedded/5.3 2016q1/bin/arm-none-eabi-gdb.exe",
            "setupCommands": [
                { "text": "-target-select remote localhost:3333", "description": "Connect to target",     "ignoreFailures": false },
                { "text": "-file-exec-and-symbols C:/path/to/source/firmware/build/target/system-part1/platform-10-m/system-part1.elf", "description": "Executable location",     "ignoreFailures": true },
                //{ "text": "-file-exec-and-symbols ${workspaceRoot}\\build\\target\\system-part1\\platform-10-m\\system-part1.elf", "description": "Executable location",     "ignoreFailures": true },
                //{ "text": "-interpreter-exec console \"monitor endian little\"", "ignoreFailures": false },
                { "text": "-interpreter-exec console \"monitor reset\"", "ignoreFailures": false },
                { "text": "-interpreter-exec console \"monitor halt\"", "ignoreFailures": false },
                { "text": "-interpreter-exec console \"monitor arm semihosting enable\"", "ignoreFailures": false },
                { "text": "-target-download", "description": "flash target", "ignoreFailures": false },
                { "text": "-enable-pretty-printing", "description": "Enable pretty-printing for gdb",     "ignoreFailures": true },
            "logging": {
                "engineLogging": true,
                "traceResponse": true
This starts OpenOCD, and when started launches GDB which connects to the OpenOCD session.
To download the code with GDB you need to turn off the write protection on the uC first, I did this with ST-link, it fails otherwise.
I haven’t been able to get it to connect unless it is in DFU mode, but I was using the LED on D7 so that maybe the cause. I’m still testing it out.
Yes, these are the include paths for the Electron 0.7.0:
			"name":"Particle electron",
			"includePath":[
				"${workspaceRoot}\\..\\firmware\\hal\\src\\electron",
			"defines":[
				"DFU_BUILD_ENABLE",
				"MODULE_INDEX=1",
				"MODULE_VERSION=5",
				"PARTICLE=1",
				"PLATFORM_ID=10",
				"PLATFORM_NAME=electron",
				"PRODUCT_ID=10",
				"RELEASE_BUILD",
				"SPARK=1",
				"SPARK_PLATFORM",
				"SPARK_PLATFORM_NET=UBLOXSARA",
				"STM32F2XX",
				"STM32_DEVICE",
				"USBD_PID_CDC=0xC00A",
				"USBD_PID_DFU=0xD00A",
				"USER_FIRMWARE_IMAGE_LOCATION=0x8080000",
				"_GNU_SOURCE",
				"_WINSOCK_H"
That’s great thankyou!
2018 update
Starting with version 1.27.2, Visual Studio Code deprecated the use of tasks 0.1.0 and hence the scripts described here did not work anymore. I fixed that now.
Gustavo.
