Use (SPI.transfer) callback function in library
I'm modifying the Particle Adafruit Dotstar library so to use the DMA based transfer (https://docs.particle.io/reference/firmware/photon/#transfer-)
I try implementing a callback code (from this topic: Bug in SPI block transfer complete callback ).
However I get the error:
invalid use of non-static member function
I tried to put static in front of the function. However I probably do something wrong, because I'll get an error like:
cannot declare member function 'static void Adafruit_DotStar::hw_spi_DMA_TransferComplete_Callback()' to have static linkage [-fpermissive]
Any idea how I could solve this?
My fork and the line to the error (the callback function above this function):
In dotstar.h, change these two declarations:
  static void hw_spi_DMA_TransferComplete_Callback(void); // DMA transfer done
  static bool hw_spi_DMA_TransferCompleted;
In dotstar.cpp, insert this near the top, say after the #define USE_HW_SPI:
bool Adafruit_DotStar::hw_spi_DMA_TransferCompleted;
And put back the line you commented out.
Thanks that did the trick!
