I’m trying to piece together a library to use some 1Gb SPI flash and I’m a little confused about how the SPI1.transfer() function is supposed to work when you use a NULL callback function. According to the docs:
If NULL is passed as a callback then the result is synchronous i.e. the function will only return once the DMA transfer is complete.
I had assumed this means that the code would basically stop executing until the SPI1.transfer() was complete, however, that doesn’t appear to be how it’s working. When I execute the following code, the 2nd digital write happens long before the transfer is complete causing D5 (SS) to go high (which causes the slave to ignore the rest of the transmission). tx_buffer and rx_buffer are both of size len.
digitalWrite(D5,LOW);
SPI1.transfer(tx_buffer, rx_buffer, len, NULL);
digitalWrite(D5,HIGH);
I can calculate how long each transfer should take and add a delay and that solves the problem but i’m trying to figure out if this is how it’s supposed to work since this doesn’t feel like a very robust solution.
delayMicroseconds(writeDelay);
