Use Mustache to iterate a root list
I have a long JSON response and I want to use a mustache template to parse it. I’ve been using http://mustache.github.io/#demo to verify my template. While it works at the demo site it does not work in the webhook response template. My template and JSON sample are below:
    {{ReservationType}}|
A sample of the JSON:
    "BillingInstallment": "SinglePayment",
    "Description": "Basic Operation Woodshop",
    "IsAutoPay": false,
    "IsComped": false,
    "IsIndividual": true,
    "IsRecurring": false,
    "IsUnlimited": false,
    "NumberOfSessions": 1,
    "PackageID": 15838970,
    "PackageLengthQuantity": 0,
    "PackageLengthTimeUnit": "Undefined",
    "PackagePlanID": 195011,
    "RecurrencePatternOccurrences": 0,
    "RecurrencePatternQuantity": 0,
    "RecurrencePatternUnit": "None",
    "RenewAsPackagePlanID": 0,
    "ReservationType": "Class Woodshop BOSS",
    "ReservationTypeID": 190474
    "BillingInstallment": "None",
    "Description": "Vinyl Cutter / Heat Press certified member",
    "EndDate": "2019-11-20T00:00:00",
    "IsAutoPay": false,
    "IsComped": false,
    "IsIndividual": false,
    "IsRecurring": true,
    "NumberOfSessions": 3,
    "PackageID": 15838971,
    "PackagePlanID": 202351,
    "RecurrencePatternOccurrences": 1,
    "RecurrencePatternQuantity": 1,
    "RecurrencePatternUnit": "Weekly",
    "RenewAsPackagePlanID": 202351,
    "RenewalDate": "2019-11-13T00:00:00",
    "ReservationType": "EQ: Vinyl Cutter / Heat Press",
    "ReservationTypeID": 198567,
    "StartDate": "2019-11-14T00:00:00"
I hope to get
Class Woodshop BOSS|EQ: Vinyl Cutter / Heat Press|
If I reference a single element it works to get a single value, but not the . to iterate the list. This works
{{#0}}
{{/0}}
to return
Any hints are appreciated.
Jim
Hello?
Have you considered using JSONParserGeneratorRK which I know works or JSONSTREAMINGPARSER library?
@JSchrempp, first, I encourage you to use @rickkas7’s Mustache tester found here:
http://rickkas7.github.io/mustache/
When I run your first template:
I get the response you expected
When I test with the second template:
{{#0}}
{{/0}}
I get the first element as expected. Perhaps the Cloud Mustache parser is not behaving as expected. @rickkas7, any thoughts?
