Is there a strategy for detecting USB state on NRF based devices? We have a hardware watchdog that we would like to disable if a USB host is connected. The Boron and Argon.
Only mention I could find was pretty old:
I wrote a function that can quickly and efficiently poll whether there is power on the USB port on an nRF52 device:
#include "Particle.h"
SYSTEM_THREAD(ENABLED);
bool vusbDetect() {
// 0x40000000 POWER register
// USBREGSTATUS Address offset: 0x438 USB supply status
const uint32_t *usbRegStatus = (const uint32_t *)(0x40000438);
return (*usbRegStatus & 1) != 0;
pinMode(D7, OUTPUT);
digitalWrite(D7, vusbDetect());
The blue D7 LED will on when there’s power on VUSB, which will be true for both host and charger mode, unlike Serial.isConnected() which is only true when connected to a USB host.
In theory there’s an nRF52 event that would allow a callback to be called when it changes, but getting events across the Device OS - User boundary is a pain, and presumably you’d just poll when servicing your watchdog.
On the Boron and Argon this only detects the Micro USB connector power. There’s a Schottky diode between the Feather pin marked VUSB and the USB block of the nRF52, so the function will return false when powered by the Feather VUSB pin.
Many thanks, I’ll give this a shot. -AP
Unfortunately, while that register clearly works, it can not differentiate between 5V bus voltage and USB power. In the end they are the same of course. Hmm…
Perhaps a way to trap an impending DFU mode? I see that particle does a disconnect before entering DFU, but there is no system event.
USB Trigger DFU Mode:
0000037502 [system] INFO: Cloud: disconnecting
0000037503 [system] INFO: Cloud: disconnected
OK, here’s a version that detects only USB host and not USB charger:
// This returns true only for USB host, not a USB charger. It returns false for the VUSB pin on the Feather.
bool usbHostDetect() {
// 0x40027000 USBD register
// USBADDR Address offset: 0x470 Device USB address
const uint32_t *usbRegStatus = (const uint32_t *)(0x40027470);
return (*usbRegStatus != 0);
digitalWrite(D7, usbHostDetect());
Thanks, I need to get more familiar with the NRF device. I took a stab looking for that register and did not find it.
