Zul77
March 20, 2025, 3:36am
1
I'm doing augmented reality project using Unity and Photon (this tutorial: https://www.youtube.com/watch?v=wg9KY4TH__w&t=25s ). In the tutorial the link given to connect Unity and Particle Photon is as follow:
https://api.particle.io/v1/devices/events?access_token= 123456789900
However I fail to make the connection. Is there any new link for that purpose (The tutorial is 8 years old)?
Thank you.
You can no longer pass the access_token in the query string of the URL. Instead, you must pass the access token in an Authorization header. See how to send your access token .
I'm not familiar with Unity, but it looks like you might use SetRequestHeader .
Zul77
March 20, 2025, 11:05am
3
This is the code in Unity to get the data from Particle Photon. Just in case you are familiar with the format.
// based on this: http://answers.unity3d.com/questions/1085293/www-not-getting-site-that-doesnt-end-on-html.html
using UnityEngine;
using System.Collections.Generic;
using System.Net;
using UnityEngine.UI;
using System.Collections;
using System;
public class ReadStream : MonoBehaviour
public string PhotonParticleURL = "https://api.particle.io/v1/devices/events?access_token=8f2dde300247081efd541b1e36dbbc1a3ce4db23";
WebStreamReader request = null;
DataClassHumidity parseDataHumidity = new DataClassHumidity ();
DataClassUltraviolet parseDataUltraviolet = new DataClassUltraviolet ();
DataClassMotion parseDataMotion = new DataClassMotion ();
DataClassTemperature parseDataTemperature = new DataClassTemperature ();
DataClassLight parseDataLight = new DataClassLight ();
bool lightTrue = false;
bool humidityTrue = false;
bool motionTrue = false;
bool temperatureTrue = false;
bool ultravioletTrue = false;
public class DataClass
public int data;
public class DataClassHumidity
public int data;
public class DataClassUltraviolet
public int data;
public class DataClassMotion
public int data;
public class DataClassTemperature
public int data;
public class DataClassLight
public int data;
void Start()
//parseDataHumidity = new DataClass ();
StartCoroutine(WRequest());
void Update() {
IEnumerator WRequest()
request = new WebStreamReader();
request.Start(PhotonParticleURL); //https://www.ourtechart.com//wp-content/uploads/2016/04/jsonAllData.txt");
string stream = "";
while (true)
string block = request.GetNextBlock();
if (!string.IsNullOrEmpty(block))
stream += block;
//Debug.Log ("Stream1: " + stream);
string[] data = stream.Split(new string[] { "\n\n" }, System.StringSplitOptions.None);
//Debug.Log ("Data length: " + data.Length);
stream = data[data.Length - 1];
for (int i = 0; i < data.Length - 1; i++)
if (!string.IsNullOrEmpty(data[i]))
// Debug.Log ("Data: " + data [i]); // print all block of data (event + data)
if (data [i].Contains ("light")) {
lightTrue = true;
string output = data [i].Substring(data [i].IndexOf("{"));
parseDataLight = JsonUtility.FromJson<DataClassLight> (output);
//Debug.Log ("Data of Photoresistor: " + parseData.data);
//text.text = parseData.data.ToString ();
//gameObject.GetComponent<IoT> ().microPhotoresistorVal = parseDataLight.data;
if (data [i].Contains ("temperature")) {
temperatureTrue = true;
parseDataTemperature = JsonUtility.FromJson<DataClassTemperature> (output);
//Debug.Log ("Data of Temperature sensor: " + parseData.data);
//gameObject.GetComponent<IoT> ().microTemperatureVal = parseDataTemperature.data;
if (data [i].Contains ("motion")) {
motionTrue = true;
parseDataMotion = JsonUtility.FromJson<DataClassMotion> (output);
//Debug.Log ("Data of PIR sensor: " + parseData.data);
//gameObject.GetComponent<IoT> ().motionDetectedBool = Convert.ToBoolean(parseDataMotion.data);
if (data [i].Contains ("ultraviolet")) {
ultravioletTrue = true;
parseDataUltraviolet = JsonUtility.FromJson<DataClassUltraviolet> (output);
//Debug.Log ("Data of PIR ultraviolet: " + parseData.data);
//gameObject.GetComponent<IoT> ().microUltravioletVal = parseDataUltraviolet.data;
if (data [i].Contains ("humidity")) {
humidityTrue = true;
parseDataHumidity = JsonUtility.FromJson<DataClassHumidity> (output);
//Debug.Log ("Data of Humidity: " + parseData.data);
//gameObject.GetComponent<IoT> ().microHumidityVal = parseDataHumidity.data;
//Debug.Log ("TEst: " + humidityTrue + temperatureTrue + lightTrue + ultravioletTrue);
if (humidityTrue && temperatureTrue && lightTrue && ultravioletTrue) {
//Debug.Log ("PRINT ALLLLLLLLLLLLLL");
motionTrue = false;
lightTrue = false;
yield return new WaitForSeconds(1);
void OnApplicationQuit()
if (request != null)
request.Dispose();
void OnDataUpdate(decimal aAmount)
Debug.Log("Received new amount: " + aAmount);
// Do whatever you want with the value
