Continuing the discussion from Particle Matter: Updates from Sprint 46:
One solution would be a better local build for Core+Photon.
Two threads are waiting for answers:
There’s a local compile package undergoing testing with the Particle dev so things should turn out much better. Click and compile offline
Good to know! Any ETA?
Unannounced officially but give it a spin… https://github.com/spark/particle-dev-local-compiler
Actually, I’m looking for local compilation on command line mode, so I can use makefiles with the IDE I’m used to.
You can study how it’s invoked via command line commands though
Thanks.
I’ve already done, and came up with a series of issues I’ve reported on this very forum, waiting for clues!
