For some reason the namespace does not get used for const CRGB& rgb
As a temporary workaround you could add it manually like this const NSFastLED::CRGB& rgb
@ScruffR, I wonder if the pre-processor is playing havoc here. Perhaps a #pragma SPARK_NO_PREPROCESSOR
is worth testing?
@peekay123, yes this works.
Itās just odd that @bongo didnāt have this problem a few days ago.
Maybe there was some tweaking of the preproc going on in the background that caused some new oddities
So @bongo to circumvent this new issue add these lines to the top of your sketch
// to apply namespace to function parameter types too, use
//not required for FastLED since "application.h" gets included there already
//but SPARK_NO_PREPROCESSOR usually requires to add this include
//#include "application.h"
If you should also get errors about some functions being unknown, youād need to provide function prototypes.
Maybe @jgoggins or @suda could enlighten us about possible reasons for the change in behaviour
Still does not compile. Here's my sample sketch:
#include "FastLED/FastLED.h"
FASTLED_USING_NAMESPACE;
#define NUM_LEDS 256
#define DATA_PIN A5
#define CLOCK_PIN A3
CRGB leds[NUM_LEDS];
FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, GRB>(leds, NUM_LEDS);
led[1]=CRGB(255,0,0);
FastLED.show();
delay(500);
led[1]=CRGB(0,0,0);
FastLED.show();
delay(500);
And here's the compiler output:
In file included from ../inc/spark_wiring.h:29:0,
from ../inc/application.h:29,
from FastLED/led_sysdefs_arm_stm32.h:4,
from FastLED/led_sysdefs.h:16,
from FastLED/FastLED.h:34,
from FastLED/FastLED.cpp:2:
../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
from FastLED/colorpalettes.cpp:4:
from FastLED/colorutils.cpp:6:
from FastLED/hsv2rgb.cpp:4:
from FastLED/lib8tion.cpp:3:
from FastLED/noise.cpp:2:
from FastLED/power_mgt.cpp:2:
from FastLED/wiring.cpp:2:
fastled_test.cpp:2:0: warning: ignoring #pragma SPARK_NO_PREPROCESSOR [-Wunknown-pragmas]
In file included from fastled_test.cpp:8:0:
FastLED/FastLED.h:12:2: warning: #warning FastLED version 3001000 (Not really a warning, just telling you here.) [-Wcpp]
fastled_test.cpp: In function 'void loop()':
fastled_test.cpp:24:3: error: 'led' was not declared in this scope
make: *** [fastled_test.o] Error 1
Error: Could not compile. Please review your code.
In this case it's not an library/IDE issue, but a coding typo.
You declared leds[]
but try to use led[1]
Doh! Thanks @ScruffR. I had not seen the long list of warning messages I started seeing 7 days ago when I tried to compile code with a mistake. And thus I missed a genuine error in my code described at the end of a long list of messages.
My apologies to all who spent some time on this and my thanks for helping this novice.
Bongo
Hey there! I have been waiting to play with FastLED and the spark core for a long time now, and i am really happy to see it has been done!! So now iām trying to get i compiling locally with NetBeans, but i keep running in to some obstacles and now i need help moving forward.
I have just installed NetBeans again following Elco ans seulaterās tutorials (THIS) except iām not using ST-Link to flash, and i am using the feature/HAL branch.
First of all āall warnings being treated as errorsā i set, but not form the makefile. I have been looking to see if the āCFLAGS -Wno-errorā is being set elsewhere but havenāt accomplished to do so. So i tried to set it to ā-Wno-errorā in the makefile, but it does not have any affect⦠Any idea why i am getting all warnings as errors, has it anything to do with the Spark-CLI?
The reason i am getting an warning is the way that FastLED is showing its version number, so I tried to just out comment that warning in the code (the easy-fix⦠apparently!) but now I am getting new errorsā¦
Building firmware for Spark core, platform ID: 0
text data bss dec hex filename
12936 632 3564 17132 42ec ../build/target/bootloader/platform-0/bootloader.elf
../build/target/main/platform-0/src/application.o: In function `addLeds<(NSFastLED::ESPIChipsets)0u, 1u, 0u, (NSFastLED::EOrder)66u>':
C:\Repos\spark-firmware\main/./libraries/FastLED/firmware/FastLED.h:191: undefined reference to `NSFastLED::CLEDController::m_pHead'
C:\Repos\spark-firmware\main/./libraries/FastLED/firmware/FastLED.h:191: undefined reference to `NSFastLED::CLEDController::m_pTail'
C:\Repos\spark-firmware\main/./libraries/FastLED/firmware/FastLED.h:191: undefined reference to `NSFastLED::CFastLED::addLeds(NSFastLED::CLEDController*, NSFastLED::CRGB*, int, int)'
../build/target/main/platform-0/src/application.o: In function `NSFastLED::CFastLED::showColor(NSFastLED::CRGB const&)':
C:\Repos\spark-firmware\main/./libraries/FastLED/firmware/FastLED.h:399: undefined reference to `NSFastLED::CFastLED::showColor(NSFastLED::CRGB const&, unsigned char)'
../build/target/main/platform-0/src/application.o: In function `loop':
C:\Repos\spark-firmware\main/src/application.cpp:25: undefined reference to `NSFastLED::FastLED'
collect2.exe: error: ld returned 1 exit status
make[1]: *** [../build/target/main/platform-0/main.elf] Fejl 1
make: *** [main] Fejl 2
BUILD FAILED (exit value 2, total time: 7s)
I have placed the library in the library folder and included it like this ālibraries/FastLED/firmware/FastLED.hā
//#pragma SPARK_NO_PREPROCESSOR
#include "libraries/FastLED/firmware/FastLED.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
#define NUM_LEDS 160
#define DATA_PIN D1
#define CLOCK_PIN D0
FastLED.showColor(CRGB::Green);
Why am i getting those errors, have i implemented the library in a wrong way? Should i add anything to the makefile?
Also I wondered what is the best way to handle different libraries and multiply projects(application.cppās and other files) in NetBeans? Should i follow the uber library guide and just add them into the libraries folder and how can i choose witch project should get compile, in best meaner?
Can you elaborate a little bit on this?
When I declare this above setup()
I get the following error on compilation:
error: 'rgb' declared as reference but not initialized
How do I actually use it in a function like this:
void testColor(CRGB color) {
How would I call the function?
testColor(CRGB::Red);
throws an error when compiling:
error: 'CRGB' was not declared in this scope
@gotnull, have you tried the #pragma SPARK_NO_PREPROCESSOR
and in the quote you posted above the important bit was the manually added namespace qualifier
And this exact line of code would not really help you, since your over all program (which you haven't shown to have a look at ;-)) does not require that line, but Bongo's program did.
In your case you'd need to alter your code by adding the namespace like this
void testColor(NSFastLED::CRGB color) {
If I create the method like above and then call the following:
testColor(NSFastLED::CRGB::Black);
I get the same error:
Since Iām not using this lib and canāt really test any of my suggestions as such, Iām only going by my C++ experience.
Maybe @kriegsman can help you better with your particular problem
I donāt recall the exact details, because it was about two months ago that I helped someone with this (and have missed the conversation on this post), but there is something that the spark preprocessor was doing that was causing definitions to end up being moved (I think it was prototypes?) above the using statement. In their case it was enough to move their method declarations before usages, but I donāt recall exactly which. My entire dev setup is a bit hosed at the moment, but Iām working on spinning it back up as I have a bunch of M0 work to do as well as 2 photons showing up later this week.
Just so Iām clear (Iām a huge FastLED user with my arduino boards) ā This will not work out of the box with the Particle Photons ⦠it needs to be āportedā? That sucks!
@webdevbrian, wonāt be long before the official new firmware release happens. Then⦠porting fever!
Porting is necessary and common when moving optimized low-level code between different systems. You canāt take a PS4 game and run it on an XBox without porting, nor take a iOS app and run it on android.
The same is true when moving Arduino libraries to Particle devices, particularly when they use specific low-level features of the ATMega386p. The arduino is 8-bit, the STM32 in Particle devices 32-bit. You canāt put a square peg in a round hole without changes!
Would that be the HAL Iāve read about @peekay123?
Just talked to dan actually ā I know heās working hard (we all have FT jobs, totally understandable) ā just really excited to see the possibility with the increase of ram, flash and CPU clock speed ⦠this is going to get interesting!
Firmware release ⦠this piques my interest! Sorry, can you share more details? I own a shop with 20k+ FastLED Lib deployments, this is hugely of interest to me and my team. Thank you!
Sorry - didnāt see this response via email reply (I got a few email replies but not of a notification of your comment) ā
Trust me, I understand the difference between systems, let alone deployments! My team and I do this for a living. I was under the impression that the photon was an arduino equivalent, especially with the arduino IDE.
We have a ton of deployments using micros, minis and unos ā I just needed to understand the STM32, which I get, wholeheartedly. Iāve already spoke with Dan ā the man is a pure machine and a legend in his own right for sure.
I might be able to fit a square ped in a hole ⦠give me a few tools!
Being that this looks like the right thread:
Is there any LED lib support for the photon yet? FastLED, ADA ⦠no go so far it looks like (that I can find). Ordered a few dozen of these things, WHOOPS!
