I am trying to create a webhook that will get an array of integers from a single field (field2) of a Thingspeak channel. I need to minimize the output so as not to overrun the webhook limit. The output I'm trying to produce would be like this:
235,
420,
399,
410,
410,
what I get so far is this:
2024-01-31 14:12:11 -0600,1297,HEAT,235,61.6,18.2,26.1,68.0_67.4,52.2_51.0,
2024-01-31 15:12:26 -0600,1298,HEAT,420,62.0,32.8,46.2,70.1_67.7,44.9_43.0,
2024-01-31 17:28:45 -0600,1299,HEAT,399,61.7,31.4,44.8,70.3_68.3,48.2_45.3,
2024-01-31 20:03:46 -0600,1300,HEAT,410,61.9,31.3,44.7,70.5_68.6,47.4_45.3,
2024-01-31 21:31:04 -0600,1301,HEAT,410,61.6,31.2,44.8,69.9_67.5,48.3_44.7,
2024-01-31 23:48:44 -0600,1302,HEAT,410,62.3,30.6,43.7,7
Below is the custom template I'm using although I've tried many variations. I think I need to use a responseTemplate but everything I've tried so far seems to kill the output. Would anyone have some insight into my problem?
Thank you,
Bob
"name": "Get_HVAC_RT_History",
"event": "Get_HVAC_RT_History",
"deviceID": "999999999999999",
"responseTopic": "",
"errorResponseTopic": "",
"url": "https://api.thingspeak.com/channels/0000000/feeds.csv?api_key=MYREADKEY&minutes=1440&offset=-6",
"requestType": "GET",
"noDefaults": true,
"rejectUnauthorized": true,
"responseTemplate": ""
