I am new to Particle devices and I’m facing a problem to connect the Argon to IBM Watson IOT platform. I am using MQTT.h library to connect to IBM Watson. When i verify the code it displays “Code verfied. Great work” and when i flash the code it displays in Particle IDE “Flash successful. updating device firmware” and then Argon blinks magenta, then green and after a few seconds it starts breathing cyan. After it keeps breathing cyan, I cannot see my Argon connected to IBM cloud.
I am not sure whether the issue is with the code or MQTT library. I also tried using MQTT-TLS library to check if it works with my code but i get errors when i verify the code.
The code is given below. Please help me out
#include <Adafruit_DHT.h>
#include <OneWire.h>
#include <MQTT.h>
#include "DS18.h"
#include "MQTT.h"
#include "Adafruit_DHT.h"
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT11 // DHT 11
char *IOT_CLIENT = "d:ts200f:Argon:WebVisions";
char *IOT_HOST = "ts200f.messaging.internetofthings.ibmcloud.com";
char *IOT_PASSWORD = "_device_token_here_";
char *IOT_PUBLISH = "iot-2/evt/sensor_data/fmt/json";
char *IOT_USERNAME = "use-token-auth";
// MQTT callback
void callback(char* topic, byte* payload, unsigned int length);
DS18 sensor(5);
// MQTT client
MQTT client(IOT_HOST, 1883 , callback);
DHT dht(DHTPIN, DHTTYPE);
char* string2char(String command){
if(command.length()!=0){
char *p = const_cast<char*>(command.c_str());
return p;
// recieve message
void callback(char* topic, byte* payload, unsigned int length) {
delay(1000);
dht.begin();
delay(5000);
// connect to the server
client.connect( IOT_CLIENT, IOT_USERNAME, IOT_PASSWORD );
// publish/subscribe
if (client.isConnected()) {
client.publish(IOT_PUBLISH,"hello world");
//client.subscribe("inTopic/message");
