Ugh, what broke?
Sorry for the length of the code, but I think I have a Particule.subscribe() problem. Please note, I’m barely a C programmer and not a C++ programmer. But I think either I was just getting lucky with this C prior to 2.0 or something in 2.0 broke this and I’m not seeing it. I deleted the PRIVATE and MY_DEVICE tags, but otherwise I’m not seeing anything I should definitely change.
Anyway, prior to trying to simply update to 2.0.1 with this code, everything worked. My setup() would publish a “getstate” to the cloud, and two of my devices would respond and change the "DUNNO’ on the display to “Open” or “Closed.”
Now, I see the “getstate” in my cloud event log, but the state on the display stays “DUNNO” for both devices. If I publish a “getstate” using the console, the display stays “DUNNO” for main gate, changes to “Open” on CH Gate, and then the device reboots.
Anyone see anything obviously stupid here in the handlers?
–Donnie
#include <pid.h>
#include <LiquidCrystal_I2C_Spark.h>
#include <clickButton.h>
// SHT31 stuff
#include <application.h>
#include <spark_wiring_i2c.h>
#include "elapsedMillis.h"
// SHT31 I2C address is 0x44(68)
#define Addr 0x44
int temp = 0;
double cTemp = 0.0, fTemp = 0.0, humidity = 0.0;
int setFanSpeed(String speed);
char publishString[40];
//wiring
int relayPin = D2;  // not currently actually used
int fanpin = D3;    // pwm signal out to fan(s)
int pinYellow = D6; // up
int pinBlue = D7;   // down
// This all uses the elapsedMillis library to setup the ability to turn on the backlight for 10s at a time
// #define LCD_BACKLIGHT_INTERVAL 60000
#define LCD_BACKLIGHT_INTERVAL 6000000
#define SP_INCREMENTS 0.2
elapsedMillis lcdBacklightInterval;
bool backlight = false;
ClickButton buttonYellow(pinYellow, LOW, CLICKBTN_PULLUP);
ClickButton buttonBlue(pinBlue, LOW, CLICKBTN_PULLUP);
int buttonYellowClicks = 0;
int buttonBlueClicks = 0;
double fanspeed = 150; // default fan speed
void maingateHandler(const char *eventname, const char *data);
void clubgateHandler(const char *eventname, const char *data);
int mainstatus(String command);
int clubstatus(String command);
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 20 chars and 4 line display
// double kp=2;   //proportional parameter
// double ki=5;   //integral parameter
// double kd=1;   //derivative parameter
double kp=75;   //proportional parameter
double ki=1;   //integral parameter
double kd=3;   //derivative parameter
// Minimum and Maximum PWM command, according fan specs and noise level required
// My fans draw 1.05A at full bore but my power supply is a 2A (24V), so I may need to put a meter
// on it and see what Max would keep it at 1A. The fans also won't start up to something below
// around 50 maybe, so I need to be above that. But 90 is fine as they are always going to need
// more cooling than that.
double commandMin = 20;
double commandMax = 255;
// default starter temp.
double setTemp = 64.5;
// declare my PID. Give it the temp from the sensor, the fanspeed variable to set, the target temp,
// the proportioning parameters, and make it REVERSE, which means target cooling.
PID myPID(&fTemp, &fanspeed, &setTemp, kp, ki, kd, PID::REVERSE);
/* This function is called once at start up ----------------------------------*/
    Particle.variable("fTemp", fTemp);
    Particle.variable("humidity", humidity);
    Particle.variable("fanspeed", fanspeed);
    Particle.variable("kp", kp);
    Particle.variable("ki", ki);
    Particle.variable("kd", kd);
    Particle.function("backlight", backlightSet);
    Particle.function("kp", kpSet);
    Particle.function("ki", kiSet);
    Particle.function("kd", kdSet);
    // listen to turn on or off from main gate ID and call a handler if it changes, same for clubhouse gate
    Particle.subscribe("main_gate_1", maingateHandler);
    Particle.subscribe("clubhouse_gate_1", clubgateHandler);
    // do a request for the state and the above subscribes will get called when they see the request
    Particle.publish("getstate", "1");
    // setup some buttons
    pinMode(pinYellow, INPUT_PULLUP);
    pinMode(pinBlue, INPUT_PULLUP);
    pinMode(fanpin, OUTPUT);  // set the fanpin to an output
    pinMode(relayPin, OUTPUT); // set the relay pin to an output
    digitalWrite(relayPin, HIGH); // turn on relay at startup
    // variables that need to be setup for the button debounce library
    // buttonYellow.debounceTime   = 20;   // Debounce timer in ms
    // buttonYellow.multiclickTime = 250;  // Time limit for multi clicks
    // buttonYellow.longClickTime  = 1000; // time until "held-down clicks" register
    // some things we can set from the Particle app
    Particle.function("relayState", djbRelay);
	Serial.begin(115200);
    lcd.init();  //initialize the lcd
    // turn on the backlight at boot time (it'll turn off after 10s)
    lcd.backlight();  // turn backlight on
    backlight = true;
    lcd.setCursor (0, 0 );            // go to the top left corner
    lcd.print("Main Gate: DUNNO"); // write this string on the top row
    lcd.setCursor (0, 1 );            // go to the third row
    lcd.print("CH Gate: DUNNO"); // pad with spaces for centering
    lcd.setCursor(17,3);
    sprintf(publishString, "%3.0f", fanspeed);
    lcd.print(publishString);
    lcd.setCursor(16,2);
    sprintf(publishString, "%3.1f", setTemp);
    //turn the PID on
    myPID.SetMode(PID::AUTOMATIC);
    myPID.SetOutputLimits(commandMin, commandMax);
/* This function loops forever --------------------------------------------*/
    // these functions get the button data
    buttonYellow.Update();
    buttonBlue.Update();
    if(buttonYellow.clicks != 0) buttonYellowClicks = buttonYellow.clicks;
    if(buttonBlue.clicks != 0) buttonBlueClicks = buttonBlue.clicks;
    if (buttonYellowClicks == 1)
        if (!backlight) { // if backlight is OFF
            backlight = true; // backlight is now on
            lcdBacklightInterval = 0;
        } else {
	        setTemp = setTemp+SP_INCREMENTS;
                lcdBacklightInterval = 0; // reset the interval timer
    if (buttonBlueClicks == 1)
        } else {
	        setTemp = setTemp-SP_INCREMENTS;
    delay(5);
    // get temp and do things with it
    unsigned int data[6];
    // Start I2C Transmission
    Wire.beginTransmission(Addr);
    // Send 16-bit command byte
    Wire.write(0x2C);
    Wire.write(0x06);
    // Stop I2C transmission
    Wire.endTransmission();
    // delay(300);
    // Select data register
    Wire.write(0x00);
    // Stop I2C Transmission
    // Request 6 bytes of data from the device
    Wire.requestFrom(Addr, 6);
    // Read 6 bytes of data
    // temp msb, temp lsb, crc, hum msb, hum lsb, crc
    if (Wire.available() == 6)
        data[0] = Wire.read();
        data[1] = Wire.read();
        data[2] = Wire.read();
        data[3] = Wire.read();
        data[4] = Wire.read();
        data[5] = Wire.read();
    // Convert the data
    temp = (data[0] * 256) + data[1];
    cTemp = -45.0 + (175.0 * temp / 65535.0);
    fTemp = (cTemp * 1.8) + 32;
    humidity = 100 * ((data[3] * 256) + data[4]) / 65535.0;
    lcd.setCursor(0, 2);
    sprintf(publishString, "Temp %2.2f", fTemp);
    lcd.setCursor(0,3);
    sprintf(publishString, "Humidity: %2.2f", humidity);
    //process PID
    myPID.Compute();
    // write new fanspeed (25khz carrier signal is what these fans want)
    analogWrite(fanpin, fanspeed, 25600);
    lcd.setCursor (17,3);
    if (backlight) { // if backlight is on
        if (lcdBacklightInterval > LCD_BACKLIGHT_INTERVAL) { // check to see if it's time to turn it off
            backlight = false; // set the state to off
            lcd.noBacklight(); // turn it off
    // pass the command that was sent to the main gate down to us
    mainstatus(data);
    if(command == "ON")
         lcd.setCursor (0, 0);            // go to the 2nd row
         lcd.print("Main Gate: Open     "); // pad string with spaces for centering
    if(command == "OFF")
         lcd.print("Main Gate: Closed    "); // pad string with spaces for centering
    // pass the command that was sent to the clubhouse gate down to us
    clubstatus(data);
    if(command == "ON")
         lcd.setCursor (0, 1);            // go to the 2nd row
         lcd.print("CH Gate: Open     "); // pad string with spaces for centering
         lcd.print("CH Gate: Closed    "); // pad string with spaces for centering
int djbRelay(String command){
	if(command.equalsIgnoreCase("on")){
		return 1;
	if(command.equalsIgnoreCase("off")){
		analogWrite(relayPin, LOW);
		return 1;
	return 0;
int backlightSet(String command){
		lcd.backlight();
                backlight = true;
                lcdBacklightInterval = 0; // reset the counter to 0 because it just turned on
		return 1;
	else {
            lcd.noBacklight();
            backlight = false;
	return 1;
int kpSet(String command){
    kp = command.toFloat();
    myPID.SetTunings(kp, ki, kd);
int kiSet(String command){
    ki = command.toFloat();
int kdSet(String command){
    kd = command.toFloat();
Most of your Particle.function() callbacks are missing the obligatory return statement.
With the compilers used for older versions of device OS you could get away with that although always problematic, but not now it will cause a panic crash.
BTW, application.h would now be Particle.h and spark_wiring_i2c.h is superfluous as it already gets included via Particle.h (already was the case with application.h too).
You sir are wonderful. So now no crashes. But one nagging thing…it still doesn’t update the gate status at boot time. Stays “DUNNO” until I go to the console and publish a “getstate.” Any idea there? Updated code:
#include <pid.h>
#include <Particle.h>
// #include <spark_wiring_i2c.h>
#define Addr 0x44
int temp = 0;
//wiring
    backlight = true;
    //turn the PID on
        } else {
        } else {
    delay(5);
    Wire.write(0x2C);
    Wire.write(0x06);
    // delay(300);
    Wire.write(0x00);
    // Convert the data
    lcd.setCursor(0,3);
    //process PID
    myPID.Compute();
    mainstatus(data);
    if(command == "ON")
	return 1;
	return 1;
    return 0;
    clubstatus(data);
    if(command == "ON")
	return 1;
	return 1;
    return 0;
		return 1;
		digitalWrite(relayPin, LOW);
		return 1;
	return 0;
		lcd.backlight();
                backlight = true;
		return 1;
	else {
            lcd.noBacklight();
            backlight = false;
	return 1;
    return 1;
    return 1;
    return 1;
FWIW, that boot status did work before the 2.0 update as well. And also, wow on not doing returns. That was dumb.
–Donnie
I think it’s just happening too fast. I’m scared to do a while (!Particle.connected()); for some reason in setup(), but maybe I’ll just do an if connected in loop() and then only do it the first time it’s connected. Unless there’s a better way I’m not thinking of…
–Donnie
Yeah, verified it’s happening too fast now. Put a 5s delay before the publish and it worked fine. That doesn’t bother me on this device very much, but it would be nice if there’s a safe way to do this. Maybe I’m overthinking just blocking with the while(!Particle.connected()); though. I would like the device to still function for its other tasks if it can’t connect to wifi or the cloud.
–Donnie
And of course, I spoke too soon. Had a boot where 5s wasn’t enough for either response, then changed it to 10s and only got one of the two responses registered. So weird. I’m pretty sure I’m missing something important here, too.
–Donnie
Okay, I think I’m done here. I simply removed the publish from setup() and then wrapped it in a Particle.connected() loop in loop() that also checks and sets a flag so the publish only happens the first time through loop() when Particle.connected() returns true. After that, we don’t bother.
Seems to work great. I’ll stop my stream of consciousness now. :slight_smile:
–Donnie
Yup, sorry for all that confusion, there has been a change in behaviour in a recent update that "broke" older code.
Now Particle.subscribe() handlers are only getting into effect a few seconds after loop() started the first time.
You can find a discussion about this here
