I'm working on developing firmware with the tracker som board (T404M). After flashing my firmware to the board, the serial disconnects, with the command particle serial list first returning No devices available via serial. A few minutes later, the command returns /dev/ttyACM0 - undefined. Only a few minutes after that does serial finally reconnect, allowing me to acsess the serial monitor. Is this expected behavior, or something weird with my hardware or the Tracker?
I've also had issues flashing, occasoinally giving errors around DFU permissions. It seems very inconsistent on it, I'd try flashing ~5-10 times in a row with the same error about now dfu permissions, and on the 11'th time it would flash perfectly fine
I'm using Ubuntu 23.04.
