Ubuntu 24.04 on Tachyon - Early Access & Open Development
Still fighting instability with vanilla 24.04 (headless, 1.1.27 but same behavior with earlier versions too) trying to do basic dev work… got a debug board online and captured syscon and linux consoles but neither show anything at the time of the crash. Here’s a screenshot showing activity around the time of the crash/reboot which happens around 17:12:13:
Both of my boards exhibit the same behavior. Has anyone else seen this? I’m willing to keep debugging but would appreciate some guidance on next steps. The lack of anything in the linux console suggests a complete freeze of the CPU until a watchdog timer forces the reboot.
Hey kph, I was running the 24.04 desktop ROW version for some time, no issues and never crashed! I was using it headless and RDP to iMac - slow but usable, maybe for some reason that version is more stable? Might be worth a try :slight_smile: Only changed back to 20.04 to test the IMX519 camera which is actually working now. I'll return to 24.04 when the camera fixes are incorporated.
Thanks for your comments. I have tried a lot of different configurations (ssh, adb shell, disabling CPUs 1-7, hardwiring speed governors, trying various linux kernel boot options, etc, etc) and I made some headway when running a single CPU but never completely resolved the problem. All of my experiments point to a load dependent and/or synchronization problem that’s triggering a low-level watchdog that forces a reboot. Either that or my hardware is flakey, but I doubt that because 20.04 is stable and both boards behave the same way.
The Qualcomm Linux docs describe debugging these kinds of problems - I’m waiting on permission from Qualcomm to dig into the details of their “Qualcomm Linux Debug Guide - Addendum”.
Can anyone answer my question regarding qps615.bin? Why is it suggesting I'm missing firmware?
Hi, just installed tachyon-ubuntu-24.04-RoW-desktop-1.1.28. After flashing, it powers on and shows the login screen. Upon logging in as particle, it immediately hangs (pointer frozen on a blank screen) and then reboots. The status LED never changes from pulsing green to magenta.
I am able to access the device through the particle console, and got this dump from dmesg:
dmesg
[ 22.876005] NET: Registered PF_VSOCK protocol family
[ 22.884358] Guest personality initialized and is inactive
[ 22.884556] VMCI host device registered (name=vmci, major=10, minor=118)
[ 22.884565] Initialized host personality
[ 23.070115] kauditd_printk_skb: 151 callbacks suppressed
[ 23.070131] audit: type=1400 audit(1765113118.261:163): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=2575 comm="apparmor_parser"
[ 23.503097] Initializing XFRM netlink socket
[ 23.519014] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 33.024703] lpass_audio_cc-sc7280 3300000.clock-controller: deferred probe timeout, ignoring dependency
[ 33.024713] lpass_audio_cc-sc7280: probe of 3300000.clock-controller failed with error -110
[ 44.422903] wwan wwan0: port wwan0at0 attached
[ 44.423071] wwan wwan0: port wwan0at1 attached
[ 46.562404] qcom_q6v5_pas 4080000.remoteproc: fatal error received: quectel_init.c:309:Ubuntu-Modem Graceful Restart is not enabled/supported. Intentionally crash with err fatal for segment loading.
[ 46.580528] remoteproc remoteproc0: crash detected in 4080000.remoteproc: type fatal error
[ 46.589083] remoteproc remoteproc0: handling crash #1 in 4080000.remoteproc
[ 46.596287] remoteproc remoteproc0: recovering 4080000.remoteproc
[ 46.602579] ipa 1e40000.ipa: received modem crashed event
[ 46.624126] wwan wwan0: port wwan0at0 disconnected
[ 51.456510] wwan wwan0: port wwan0at1 disconnected
[ 51.519826] ipa 1e40000.ipa: received modem offline event
[ 51.520388] remoteproc remoteproc0: stopped remote processor 4080000.remoteproc
[ 51.521271] ipa 1e40000.ipa: received modem starting event
[ 52.225464] ipa 1e40000.ipa: received modem running event
[ 52.225475] remoteproc remoteproc0: remote processor 4080000.remoteproc is now up
[ 74.924198] rfkill: input handler enabled
[ 77.078515] rfkill: input handler disabled
[ 77.402840] Internal error: synchronous external abort: 0000000096000010 [#1] SMP
[ 77.410537] Modules linked in: rpmsg_wwan_ctrl wwan xt_conntrack xt_MASQUERADE bridge stp llc xfrm_user xfrm_algo xt_set ip_set nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat vsock_loopback vmw_vsock_virtio_transport_common vmw_vsock_vmci_transport vmw_vmci vsock aes_ce_ccm michael_mic snd_seq_dummy snd_hrtimer rfcomm nf_tables libcrc32c overlay joydev input_leds hid_generic usbhid hid uas usb_storage onboard_usb_hub algif_hash algif_skcipher af_alg bnep qrtr_mhi binfmt_misc nls_iso8859_1 snd_soc_hdmi_codec snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq snd_seq_device snd_timer snd soundcore fastrpc ath11k_pci qrtr_smd rpmsg_ctrl ath11k rpmsg_char mac80211 cfg80211 libarc4 mhi pmic_glink_altmode qcom_battmgr ucsi_glink aux_hpd_bridge typec_ucsi pm8xxx_vibrator ff_memless aes_ce_blk aes_ce_cipher hci_uart crct10dif_ce btqca polyval_ce btrtl polyval_generic pm8941_pwrkey ghash_ce btintel btbcm qcom_spmi_adc5
[ 77.410630] qcom_spmi_adc_tm5 bluetooth qcom_vadc_common qcom_spmi_temp_alarm sm4 industrialio leds_qcom_lpg sha2_ce sha256_arm64 led_class_multicolor ecdh_generic msm ecc sha1_ce ocmem gpu_sched drm_exec drm_display_helper drm_dp_aux_bus cec qcom_tsens qcom_edac rc_core gpi qcom_q6v5_pas qcom_rproc_minidump qcom_pil_info qcom_q6v5 qcom_sysmon ipa qcrypto authenc qcom_common pci_pwrctl_pwrseq qcom_glink_smem libdes mdt_loader pci_pwrctl_core icc_osm_l3 qrtr qcom_rng leds_gpio uio_pdrv_genirq uio sch_fq_codel ledtrig_activity libcomposite nvme_fabrics nvme_keyring nvme_core nvme_auth efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 xhci_plat_hcd spidev dwc3_qcom qcom_eud dwc3 phy_qcom_qmp_combo pwrseq_qcom_wcn ulpi aux_bridge pinctrl_sc7280_lpass_lpi nvmem_reboot_mode qcom_pon rtc_pm8xxx nvmem_qcom_spmi_sdam pwrseq_core gpio_sbu_mux qcom_stats spi_geni_qcom i2c_qcom_geni udc_core typec llcc_qcom icc_bwmon pinctrl_lpass_lpi lpasscc_sc7280 socinfo reboot_mode pmic_glink gpio_keys rmtfs_mem
[ 77.590683] CPU: 5 PID: 9232 Comm: gnome-shell Not tainted 6.8.0-1056-particle #57+particle5
[ 77.593187] Hardware name: particle Particle Tachyon/Particle Tachyon, BIOS 2025.04-00030-gf7f7c3fc1f50 04/01/2025
[ 77.593962] pstate: 20400005 (nzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 77.594423] pc : clear_page+0x18/0x58
[ 77.594657] lr : kernel_init_pages+0x5c/0xa8
[ 77.594979] sp : ffff80008d98b750
[ 77.595217] x29: ffff80008d98b750 x28: 0000000000000901 x27: ffff1cf5ff8088c0
[ 77.595759] x26: 0000000000000901 x25: ffffdd03210ceac0 x24: 0000000000100cc2
[ 77.596224] x23: 0000000000000001 x22: 0000040000000000 x21: ffff000000000000
[ 77.596773] x20: fffffc73d4ed4040 x19: fffffc73d4ed4040 x18: ffff80008b94f0b0
[ 77.597225] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 77.597788] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000000000
[ 77.598239] x11: 0000000000000000 x10: 0000000000000000 x9 : ffffdd031e581aec
[ 77.598793] x8 : 0000000000000000 x7 : 0000000000000000 x6 : 0000000000000000
[ 77.599250] x5 : 0000000000000000 x4 : fffffc73d4ed4000 x3 : 0000000000000000
[ 77.599813] x2 : 0000000000000004 x1 : 0000000000000040 x0 : ffff1cf53b500000
[ 77.600268] Call trace:
[ 77.600482] clear_page+0x18/0x58
[ 77.600710] post_alloc_hook+0x19c/0x280
[ 77.601041] get_page_from_freelist+0x25c/0x750
[ 77.601379] __alloc_pages+0x17c/0x3a8
[ 77.601609] alloc_pages_mpol+0x94/0x298
[ 77.601941] shmem_alloc_folio+0xe4/0x128
[ 77.602175] shmem_alloc_and_add_folio+0xbc/0x408
[ 77.602503] shmem_get_folio_gfp+0x234/0x6c0
[ 77.602838] shmem_read_folio_gfp+0x68/0xe8
[ 77.603169] drm_gem_get_pages+0xac/0x318
[ 77.603406] get_pages+0x1f4/0x298 [msm]
[ 77.605628] msm_gem_fault+0x4c/0x188 [msm]
[ 77.607635] __do_fault+0x48/0x208
[ 77.607864] do_pte_missing+0x60/0x3f8
[ 77.608104] handle_pte_fault+0x12c/0x1a0
[ 77.608424] __handle_mm_fault+0x22c/0x400
[ 77.608657] handle_mm_fault+0xac/0x2e0
[ 77.608986] do_page_fault+0x17c/0x538
[ 77.609215] do_translation_fault+0x7c/0xd8
[ 77.609548] do_mem_abort+0x50/0xd0
[ 77.609773] el0_da+0x4c/0x198
[ 77.609997] el0t_64_sync_handler+0xdc/0x158
[ 77.610331] el0t_64_sync+0x1bc/0x1c0
[ 77.610572] Code: 37200121 12000c21 d2800082 9ac12041 (d50b7420)
[ 77.611011] ---[ end trace 0000000000000000 ]---
[ 77.616478] Internal error: synchronous external abort: 0000000096000010 [#2] SMP
[ 77.616956] Modules linked in: rpmsg_wwan_ctrl wwan xt_conntrack xt_MASQUERADE bridge stp llc xfrm_user xfrm_algo xt_set ip_set nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat vsock_loopback vmw_vsock_virtio_transport_common vmw_vsock_vmci_transport vmw_vmci vsock aes_ce_ccm michael_mic snd_seq_dummy snd_hrtimer rfcomm nf_tables libcrc32c overlay joydev input_leds hid_generic usbhid hid uas usb_storage onboard_usb_hub algif_hash algif_skcipher af_alg bnep qrtr_mhi binfmt_misc nls_iso8859_1 snd_soc_hdmi_codec snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq snd_seq_device snd_timer snd soundcore fastrpc ath11k_pci qrtr_smd rpmsg_ctrl ath11k rpmsg_char mac80211 cfg80211 libarc4 mhi pmic_glink_altmode qcom_battmgr ucsi_glink aux_hpd_bridge typec_ucsi pm8xxx_vibrator ff_memless aes_ce_blk aes_ce_cipher hci_uart crct10dif_ce btqca polyval_ce btrtl polyval_generic pm8941_pwrkey ghash_ce btintel btbcm qcom_spmi_adc5
[ 77.617189] qcom_spmi_adc_tm5 bluetooth qcom_vadc_common qcom_spmi_temp_alarm sm4 industrialio leds_qcom_lpg sha2_ce sha256_arm64 led_class_multicolor ecdh_generic msm ecc sha1_ce ocmem gpu_sched drm_exec drm_display_helper drm_dp_aux_bus cec qcom_tsens qcom_edac rc_core gpi qcom_q6v5_pas qcom_rproc_minidump qcom_pil_info qcom_q6v5 qcom_sysmon ipa qcrypto authenc qcom_common pci_pwrctl_pwrseq qcom_glink_smem libdes mdt_loader pci_pwrctl_core icc_osm_l3 qrtr qcom_rng leds_gpio uio_pdrv_genirq uio sch_fq_codel ledtrig_activity libcomposite nvme_fabrics nvme_keyring nvme_core nvme_auth efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 xhci_plat_hcd spidev dwc3_qcom qcom_eud dwc3 phy_qcom_qmp_combo pwrseq_qcom_wcn ulpi aux_bridge pinctrl_sc7280_lpass_lpi nvmem_reboot_mode qcom_pon rtc_pm8xxx nvmem_qcom_spmi_sdam pwrseq_core gpio_sbu_mux qcom_stats spi_geni_qcom i2c_qcom_geni udc_core typec llcc_qcom icc_bwmon pinctrl_lpass_lpi lpasscc_sc7280 socinfo reboot_mode pmic_glink gpio_keys rmtfs_mem
[ 77.629516] CPU: 2 PID: 9893 Comm: pmie_check Tainted: G D 6.8.0-1056-particle #57+particle5
[ 77.630189] Hardware name: particle Particle Tachyon/Particle Tachyon, BIOS 2025.04-00030-gf7f7c3fc1f50 04/01/2025
[ 77.630985] pstate: 20400005 (nzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 77.631440] pc : clear_page+0x18/0x58
[ 77.631668] lr : kernel_init_pages+0x5c/0xa8
[ 77.631988] sp : ffff80008e1334b0
[ 77.632228] x29: ffff80008e1334b0 x28: 0000000000000901 x27: ffff1cf5ff8088c0
[ 77.632775] x26: 0000000000000901 x25: ffffdd03210ceac0 x24: 0000000000540dc0
[ 77.633237] x23: 0000000000000001 x22: 0000040000000000 x21: ffff000000000000
[ 77.633783] x20: fffffc73d4ed6a80 x19: fffffc73d4ed6a80 x18: ffff80008cd250a8
[ 77.634244] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 77.634792] x14: 0000000000001ffe x13: 0000000000000000 x12: 0000000000000000
[ 77.635251] x11: 0000000000000000 x10: 0000000000000000 x9 : ffffdd031e581aec
[ 77.635808] x8 : 0000000000000000 x7 : 0000000000000000 x6 : 0000000000000000
[ 77.636256] x5 : 0000000000000000 x4 : fffffc73d4ed6a40 x3 : 0000000000000000
[ 77.636816] x2 : 0000000000000004 x1 : 0000000000000040 x0 : ffff1cf53b5a9000
[ 77.637277] Call trace:
[ 77.637495] clear_page+0x18/0x58
[ 77.637716] post_alloc_hook+0x19c/0x280
[ 77.638051] get_page_from_freelist+0x25c/0x750
[ 77.638382] __alloc_pages+0x17c/0x3a8
[ 77.638615] alloc_pages_mpol+0x94/0x298
[ 77.638942] alloc_pages+0x6c/0x118
[ 77.639172] __pmd_alloc+0x4c/0x2e8
[ 77.639403] __handle_mm_fault+0x2d4/0x400
[ 77.639730] handle_mm_fault+0xac/0x2e0
[ 77.639967] faultin_page+0x70/0x170
[ 77.640193] __get_user_pages+0xe4/0x380
[ 77.640510] get_user_pages_remote+0xd4/0x460
[ 77.640749] get_arg_page+0x94/0x288
[ 77.640973] copy_string_kernel+0xb8/0x238
[ 77.641298] do_execveat_common.isra.0+0x1b4/0x288
[ 77.641640] __arm64_sys_execve+0x4c/0x90
[ 77.641879] invoke_syscall+0x7c/0x130
[ 77.642103] el0_svc_common.constprop.0+0x4c/0x140
[ 77.642434] do_el0_svc+0x28/0x58
[ 77.642663] el0_svc+0x40/0x1b0
[ 77.642880] el0t_64_sync_handler+0x148/0x158
[ 77.643220] el0t_64_sync+0x1bc/0x1c0
[ 77.643456] Code: 37200121 12000c21 d2800082 9ac12041 (d50b7420)
[ 77.643896] ---[ end trace 0000000000000000 ]---
[ 77.644238] Internal error: synchronous external abort: 0000000096000010 [#3] SMP
[ 77.644792] Modules linked in: rpmsg_wwan_ctrl wwan xt_conntrack xt_MASQUERADE bridge stp llc xfrm_user xfrm_algo xt_set ip_set nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat vsock_loopback vmw_vsock_virtio_transport_common vmw_vsock_vmci_transport vmw_vmci vsock aes_ce_ccm michael_mic snd_seq_dummy snd_hrtimer rfcomm nf_tables libcrc32c overlay joydev input_leds hid_generic usbhid hid uas usb_storage onboard_usb_hub algif_hash algif_skcipher af_alg bnep qrtr_mhi binfmt_misc nls_iso8859_1 snd_soc_hdmi_codec snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq snd_seq_device snd_timer snd soundcore fastrpc ath11k_pci qrtr_smd rpmsg_ctrl ath11k rpmsg_char mac80211 cfg80211 libarc4 mhi pmic_glink_altmode qcom_battmgr ucsi_glink aux_hpd_bridge typec_ucsi pm8xxx_vibrator ff_memless aes_ce_blk aes_ce_cipher hci_uart crct10dif_ce btqca polyval_ce btrtl polyval_generic pm8941_pwrkey ghash_ce btintel btbcm qcom_spmi_adc5
[ 77.645007] qcom_spmi_adc_tm5 bluetooth qcom_vadc_common qcom_spmi_temp_alarm sm4 industrialio leds_qcom_lpg sha2_ce sha256_arm64 led_class_multicolor ecdh_generic msm ecc sha1_ce ocmem gpu_sched drm_exec drm_display_helper drm_dp_aux_bus cec qcom_tsens qcom_edac rc_core gpi qcom_q6v5_pas qcom_rproc_minidump qcom_pil_info qcom_q6v5 qcom_sysmon ipa qcrypto authenc qcom_common pci_pwrctl_pwrseq qcom_glink_smem libdes mdt_loader pci_pwrctl_core icc_osm_l3 qrtr qcom_rng leds_gpio uio_pdrv_genirq uio sch_fq_codel ledtrig_activity libcomposite nvme_fabrics nvme_keyring nvme_core nvme_auth efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 xhci_plat_hcd spidev dwc3_qcom qcom_eud dwc3 phy_qcom_qmp_combo pwrseq_qcom_wcn ulpi aux_bridge pinctrl_sc7280_lpass_lpi nvmem_reboot_mode qcom_pon rtc_pm8xxx nvmem_qcom_spmi_sdam pwrseq_core gpio_sbu_mux qcom_stats spi_geni_qcom i2c_qcom_geni udc_core typec llcc_qcom icc_bwmon pinctrl_lpass_lpi lpasscc_sc7280 socinfo reboot_mode pmic_glink gpio_keys rmtfs_mem
[ 77.657358] CPU: 3 PID: 9900 Comm: polkitd Tainted: G D 6.8.0-1056-particle #57+particle5
[ 77.667268] Hardware name: particle Particle Tachyon/Particle Tachyon, BIOS 2025.04-00030-gf7f7c3fc1f50 04/01/2025
[ 77.667949] pstate: 20400005 (nzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 77.668407] pc : clear_page+0x18/0x58
[ 77.668639] lr : kernel_init_pages+0x5c/0xa8
[ 77.668960] sp : ffff80008e1231f0
[ 77.669190] x29: ffff80008e1231f0 x28: 0000000000000901 x27: ffff1cf5ff8088c0
[ 77.669743] x26: 0000000000000901 x25: ffffdd03210ceac0 x24: 0000000000112cc0
[ 77.670197] x23: 0000000000000001 x22: 0000040000000000 x21: ffff000000000000
[ 77.670748] x20: fffffc73d4ed7a40 x19: fffffc73d4ed7a40 x18: ffff80008cd3f0e0
[ 77.671202] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 77.671755] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000000000
[ 77.672209] x11: 0000000000000000 x10: 0000000000000000 x9 : ffffdd031e581aec
[ 77.672763] x8 : 0000000000000000 x7 : 0000000000000000 x6 : 0000000000000000
[ 77.673216] x5 : 0000000000000000 x4 : fffffc73d4ed7a00 x3 : 0000000000000000
[ 77.673769] x2 : 0000000000000004 x1 : 0000000000000040 x0 : ffff1cf53b5e8000
[ 77.674223] Call trace:
[ 77.674442] clear_page+0x18/0x58
[ 77.674666] post_alloc_hook+0x19c/0x280
[ 77.674995] get_page_from_freelist+0x25c/0x750
[ 77.675327] __alloc_pages+0x17c/0x3a8
[ 77.675562] alloc_slab_page+0x78/0x148
[ 77.675889] allocate_slab+0x8c/0x388
[ 77.676123] new_slab+0x50/0x98
[ 77.676349] ___slab_alloc+0x284/0x650
[ 77.676583] __slab_alloc.isra.0+0x40/0xa0
[ 77.676897] __kmalloc_node+0x16c/0x4c8
[ 77.677135] memcg_alloc_slab_cgroups+0x4c/0xe8
[ 77.677470] allocate_slab+0xc0/0x388
[ 77.677694] new_slab+0x50/0x98
[ 77.677910] ___slab_alloc+0x284/0x650
[ 77.678144] __slab_alloc.isra.0+0x40/0xa0
[ 77.678471] kmem_cache_alloc+0x394/0x3d8
[ 77.678711] vm_area_dup+0x38/0x1e0
[ 77.678935] dup_mmap+0x31c/0x718
[ 77.679159] dup_mm.constprop.0+0x74/0x130
[ 77.679476] copy_process+0xd20/0x1030
[ 77.679712] kernel_clone+0xa4/0x538
[ 77.679938] __do_sys_clone+0x78/0xe0
[ 77.680162] __arm64_sys_clone+0x2c/0x58
[ 77.680490] invoke_syscall+0x7c/0x130
[ 77.680716] el0_svc_common.constprop.0+0x114/0x140
[ 77.681049] do_el0_svc+0x28/0x58
[ 77.681283] el0_svc+0x40/0x1b0
[ 77.681503] el0t_64_sync_handler+0x148/0x158
[ 77.681834] el0t_64_sync+0x1bc/0x1c0
[ 77.682073] Code: 37200121 12000c21 d2800082 9ac12041 (d50b7420)
[ 77.682508] ---[ end trace 0000000000000000 ]---
[ 77.682841] Internal error: synchronous external abort: 0000000096000010 [#4] SMP
[ 77.683403] Modules linked in: rpmsg_wwan_ctrl wwan xt_conntrack xt_MASQUERADE bridge stp llc xfrm_user xfrm_algo xt_set ip_set nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat vsock_loopback vmw_vsock_virtio_transport_common vmw_vsock_vmci_transport vmw_vmci vsock aes_ce_ccm michael_mic snd_seq_dummy snd_hrtimer rfcomm nf_tables libcrc32c overlay joydev input_leds hid_generic usbhid hid uas usb_storage onboard_usb_hub algif_hash algif_skcipher af_alg bnep qrtr_mhi binfmt_misc nls_iso8859_1 snd_soc_hdmi_codec snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq snd_seq_device snd_timer snd soundcore fastrpc ath11k_pci qrtr_smd rpmsg_ctrl ath11k rpmsg_char mac80211 cfg80211 libarc4 mhi pmic_glink_altmode qcom_battmgr ucsi_glink aux_hpd_bridge typec_ucsi pm8xxx_vibrator ff_memless aes_ce_blk aes_ce_cipher hci_uart crct10dif_ce btqca polyval_ce btrtl polyval_generic pm8941_pwrkey ghash_ce btintel btbcm qcom_spmi_adc5
When I asked Claude what that meant, it said:
The Problem
The crash occurs in clear_page() with a synchronous external abort (0x96000010), which typically indicates:
  1. Bad RAM/Memory error - Physical memory corruption or hardware failure
  2. Memory controller issue - Problems with the DDR memory controller
  3. Power delivery problem - Insufficient or unstable power to memory
However, Ubuntu 20.04 installs fine, so I doubt it’s a physical memory problem. Also, I tried with battery and with external PD power, so I don’t think it’s an unstable power problem.
I downloaded tachyon-ubuntu-24.04-RoW-desktop-1.1.27 and flashed it manually to make sure it wasn’t something in the latest release, but it behaves the same way.
Thoughts? Anyone else encountering this?
You mean it's working in desktop mode? I didn't think that was working yet and have been operating mine headless.
Well, perhaps not. Video output over USB-C is working, and the login screen is working, but maybe that's as far as they got. Would be great to have some release notes - are those available somewhere?
FYI, the instability with 24.04 on my TACH4NA boards resolved with version 1.0.24 of tachyon-u-boot. Onward.
