Ubidots Reading Data into Spark
@aguspg This one is for you since Ubidots does not appear to have a forum. What I was hoping for is a basic example of how to GET data from ubidots and set it as a variable I can manipulate in Spark Core.
I am currently passing data to ubidots so how do I get a value back and set it as a var? Specifically using the ubidots ‘switch’ Thanks for helping a newb to Spark / Ubidots
request.path = "/api/v1.6/variables/"VARIABLE_ID"/values";
 request.body = "{\"value\":" + String(tempF) + "}";
 http.post(request, response, headers);
Hi @Herner, yes you can get data from a variable using the API endpoint described here:
http://ubidots.com/docs/api/v1_6/data/get_variables_id_values.html
The request path would be the same: “/api/v1.6/variables/“VARIABLE_ID”/values” , but the request would be an HTTP GET.
By the way, our community portal is: http://community.ubidots.com/
Best, aguspg
