C:\Users\Student>spark keys server default_key.pub.pem 172.16.202.94:8080
Please specify a server key in DER format.
what does this means
also
did i type in the right stuff?
also
Don’t think you are doing it right…
It is spark keys server default_key.pub.pem IP_ADDRESS without the PORT number
this is changing the server public key to your own.
huh what u mean without the port number?
This is what you said.. 8080 is not required
still same
on Command-line, cd to spark-server
@Jeffery, you should give the server key as DER format If you put the server key into your core,
you should find out some tool to transform format from pem to the der. try this:
openssl rsa -in test.pem -outform DER -out test.der
it says
'openssl' is not recognized as an internal or external command,
operable program or batch file.
You are not in the right directory. Need to cd to the spark-server folder
i have to create a folder?
Did you check below link ? open ssl installation is also mentioned.
oh i thought this is the updated one so i did not check the older tutorials
C:\Users\Student>git command line
’git’ is not recognized as an internal or external command,
i installed the stuff but this came out when i type git command line
You need to install git , please google it , it is simple.
installed it but have not install Visual C++ 2010 Express as school internet dont allow me =.=
I’m trying to setup local cloud on Google compute. I’m having problems with dfu-util. I’m unable to dfu-uitl from the google cloud to create and transfer the certificates to the Spark. Has anyone tried setting up local cloud server other than localhost and/or on raspberry pi’s? If so, was it successful? Please share some instructions on how to setup local cloud service on cloud servers like Amazon EC2 or Google cloud compute or Microsoft Azure.
You dont need dfu-util to run on the cloud infrastructure. Install it on your own machine instead
@Jeffery why? r u in china ?
ermmm no?
how do i install it? where do i cd it to
So how do i generate the keys then? Generate them locally but pointing to the google cloud IP and then transfer the files via FTP to my Google cloud/spark-core/spark-server/core_keys ??
