Tutorial #4: Temperature Logger - Error in Event Data published
I copied the code from the tutorial to the build, verified, and flashed it to my device (Spark Core). Here is the URL Tutorial #4: Temperature Logger
#include <OneWire.h>
OneWire ds = OneWire(D4);  // 1-wire signal on pin D4
unsigned long lastUpdate = 0;
float lastTemp;
  // Set up 'power' pins, comment out if not used!
  pinMode(D3, OUTPUT);
  pinMode(D5, OUTPUT);
  digitalWrite(D3, LOW);
  digitalWrite(D5, HIGH);
void loop(void) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    Serial.println();
    ds.reset_search();
    delay(250);
    return;
  Serial.print("ROM =");
  for( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr[i], HEX);
  if (OneWire::crc8(addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return;
  Serial.println();
  switch (addr[0]) {
    case 0x10:
      Serial.println("  Chip = DS1820/DS18S20");
      type_s = 1;
      break;
    case 0x28:
      Serial.println("  Chip = DS18B20");
      type_s = 0;
      break;
    case 0x22:
      Serial.println("  Chip = DS1822");
      type_s = 0;
      break;
    case 0x26:
      Serial.println("  Chip = DS2438");
      type_s = 2;
      break;
    default:
      Serial.println("Unknown device type.");
      return;
  ds.reset();
  ds.select(addr);
  // ds.write(0x44, 1);
  ds.write(0x44, 0);
  delay(1000);
  present = ds.reset();
  ds.select(addr);
  ds.write(0xB8,0);         // Recall Memory 0
  ds.write(0x00,0);         // Recall Memory 0
  ds.select(addr);
  ds.write(0xBE,0);         // Read Scratchpad
  if (type_s == 2) {
    ds.write(0x00,0);       // The DS2438 needs a page# to read
  Serial.print("  Data = ");
  Serial.print(present, HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  Serial.println();
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s == 2) raw = (data[2] << 8) | data[1];
  byte cfg = (data[4] & 0x60);
  switch (type_s) {
    case 1:
      raw = raw << 3; // 9 bit resolution default
      if (data[7] == 0x10) {
        raw = (raw & 0xFFF0) + 12 - data[6];
      celsius = (float)raw * 0.0625;
      break;
    case 0:
      if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
      if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
      if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
      break;
    case 2:
      data[1] = (data[1] >> 3) & 0x1f;
      if (data[2] > 127) {
        celsius = (float)data[2] - ((float)data[1] * .03125);
      }else{
        celsius = (float)data[2] + ((float)data[1] * .03125);
  if((((celsius <= 0 && celsius > -1) && lastTemp > 5)) || celsius > 125) {
      celsius = lastTemp;
  fahrenheit = celsius * 1.8 + 32.0;
  lastTemp = celsius;
  Serial.print("  Temperature = ");
  Serial.print(celsius);
  Serial.print(" Celsius, ");
  Serial.print(fahrenheit);
  Serial.println(" Fahrenheit");
  String temperature = String(fahrenheit);
  Particle.publish("temperature", temperature, PRIVATE);
  delay(10000);
No errors on the code but the console displays {count:15++} under Events instead of temperature
. Please help.
Wiring on my breadboard is as per image temp-logger-wiring
Note: I am using a 10,000 Ohms resistor not 4,700 Ohms
These events don’t come from your device but from a different source via the cloud.
The DEVICE column tells you the source is api and the event name is not your expected temperature event but some iftt-trigger-status-check (wherever that comes from).
You should check the serial output. Maybe this gives you a hint about the reason.
When you are refering to a tutorial, can you also post the link?
BTW, you say you are using a Spark Core but the topic is tagged as Photon :confused:
Thank you for shading the light on the source and event name. Let me also edit the post details, its my first post :slight_smile:
How do i know what kind of chip i have?
  Serial.println();
  // we have a good address at this point
  // what kind of chip do we have?
  // we will set a type_s value for known types or just return
  // the first ROM byte indicates which chip
  switch (addr[0]) {
    case 0x10:
      type_s = 1;
      break;
    case 0x28:
      type_s = 0;
      break;
    case 0x22:
      type_s = 0;
      break;
    case 0x26:
      type_s = 2;
      break;
    default:
      return;
The program should tell you via the serial output.
It first retrieves the "serial number" of the chip and by looking of the first byte of that number it determins what type it is.
That's why I said
:wink:
