Temperature sensor error Dallas, OneWire Libs
I wired up the Maker’s kit temperature sensor to an Argon and following the example from the ‘Make: Getting Started with the Photon’ book adding the spark-dallas-temperature and OneWire libraries. Got a fatal error on compile. Apparently the spark-dallas-temperature code has an incorrect reference to the /OneWire/OneWire header file. Not able to manually edit the lib source file. Any ideas?
You can try the DS18B20 library
