When you see these errors related to _write, _read, _fseek etc. that means that you are using a C/C++ function that depends on having file system like printf or fopen, but there is no file system on small micros.
Normally people accidentally write printf when they mean Serial.print or similar.
Ah, thanks so much! It makes sense as I’ve been working with a lot of these functions lately, so it’s good to know where I should start looking for the culprit(s).
sprintf is fine, but snprintf is safer and a good habit to get into. Using sprintf or snprintf can cause your firmware to become larger, but that is the only downside and I use it all the time.
If you can post your code we can help look. Usually this is left over printf debugging or something turned on a #define that was unexpected.
You could also try a divide-and-conquer strategy and comment out each library and section of your code in turn and see if it compiles.
