Tracker ONE524M blinking green
Hello community,
I have a tracker that used to work in Europe. and now it doesn’t work and blinking green/ East Africa.
  1. I tried to use restore with this setting: and still blinking green: Device Restore USB | Tools | Particle
  2. I tried debug cloud. the device breathing cyan for like 10 second then blinking Cloud Debug | Troubleshooting | Particle
    here the log:
    Connected to USB serial
    e[999;999He[6n> 0000015672 [app] INFO: Starting Tests!
    0000015672 [app] INFO: Platform: Tracker
    0000015672 [app] INFO: Binary compiled for: 2.1.0
    0000015673 [app] INFO: Cloud Debug Release 2.1.4
    0000015673 [app] INFO: System version: 2.1.0
    0000015674 [app] INFO: Device ID: e00fce6859ea9206d7673324
    0000015674 [app] INFO: Power source: USB Host
    0000015676 [app] INFO: Battery state: charged, SoC: 99.21
    0000015676 [app] INFO: This device could have Ethernet (is 3rd generation)
    0000015678 [app] INFO: FEATURE_ETHERNET_DETECTION not enabled, so Ethernet will not be used (even i
    0000023690 [app] INFO: deviceID: e00fce6859ea9206d7673324
    0000023691 [app] INFO: PMIC inputVoltageLimit: 3880 mV
    0000023692 [app] INFO: PMIC inputCurrentLimit: 500 mA
    0000023693 [app] INFO: PMIC minimumSystemVoltage: 3500 mV
    0000023694 [app] INFO: PMIC chargeCurrentValue: 1024 mA
    0000023695 [app] INFO: PMIC chargeVoltageValue: 4112 mV
    0000023695 [app] INFO: modem is not yet responding
    0000023700 [system.nm] INFO: State changed: DISABLED → IFACE_DOWN
    0000023701 [system.nm] INFO: State changed: IFACE_DOWN → IFACE_REQUEST_UP
    0000023703 [net.pppncp] TRACE: PPP netif event from queue: 1
    0000023703 [ncp.client] TRACE: Modem already on
    0000023728 [system.nm] INFO: State changed: IFACE_REQUEST_UP → IFACE_UP
    0000023769 [gsm0710muxer] INFO: Starting GSM07.10 muxer
    0000023770 [gsm0710muxer] INFO: Openning mux channel 0
    0000023770 [gsm0710muxer] INFO: GSM07.10 muxer thread started
    0000023772 [gsm0710muxer] INFO: Openning mux channel 1
    0000023783 [app] INFO: Still trying to connect to cellular 00:00
    0000023784 [app] INFO: Power source: USB Host
    0000023785 [app] INFO: Battery state: charged, SoC: 99.21
    0000023824 [ncp.at] TRACE: > AT
    0000023829 [ncp.at] TRACE: < OK
    0000023829 [ncp.client] TRACE: NCP ready to accept AT commands
    0000023830 [ncp.at] TRACE: > AT+CFUN=1,0
    0000023834 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
    0000023838 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
    0000024419 [ncp.at] TRACE: < OK
    0000024419 [gsm0710muxer] INFO: Mux channel 1 already opened
    0000024420 [ncp.at] TRACE: > AT
    0000024422 [ncp.at] TRACE: < OK
    0000024422 [ncp.client] TRACE: NCP state changed: 1
    0000024422 [net.pppncp] TRACE: NCP event 1
    0000024423 [ncp.at] TRACE: > AT+QCFG=“cmux/urcport”,1
    0000024426 [ncp.at] TRACE: < OK
    0000024427 [ncp.at] TRACE: > AT+CGEREP=1,0
    0000024429 [ncp.at] TRACE: < OK
    0000024430 [net.ppp.client] TRACE: PPP thread event ADM_UP
    0000024431 [net.ppp.client] TRACE: State NONE → READY
    0000024433 [ncp.at] TRACE: > AT+CFUN=1,0
    0000024474 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
    0000024477 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
    0000024435 [ncp.at] TRACE: < OK
    0000024436 [ncp.at] TRACE: > AT+CCID
    0000024438 [ncp.at] TRACE: < +CCID: 89883070000010678603
    0000024438 [ncp.at] TRACE: < OK
    0000024439 [ncp.at] TRACE: > AT+CGDCONT=1,“IP”,“super”
    0000024484 [app.help] INFO: PDP context definition (CGDCONT): cid=1 pdpType=IP APN=super
    0000024443 [ncp.at] TRACE: < OK
    0000024443 [ncp.at] TRACE: > AT+CFUN=1,0
    0000024488 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
    0000024490 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
    0000024445 [ncp.at] TRACE: < OK
    0000024446 [ncp.at] TRACE: > AT+CREG=2
    0000024494 [app.help] INFO: Network registration (CREG) Set to location enabled (2)
    0000024447 [ncp.at] TRACE: < OK
    0000024448 [ncp.at] TRACE: > AT+CGREG=2
    0000024498 [app.help] INFO: GPRS network (CGREG) Set to location enabled (2)
    0000024450 [ncp.at] TRACE: < OK
    0000024450 [ncp.at] TRACE: > AT+CEREG=2
    0000024501 [app.help] INFO: EPS network (CEREG) Set to location enabled (2)
    0000024452 [ncp.at] TRACE: < OK
    0000024452 [ncp.client] TRACE: NCP connection state changed: 1
    0000024453 [net.pppncp] TRACE: NCP event 2
    0000024453 [net.pppncp] TRACE: State changed event: 1
    0000024454 [ncp.at] TRACE: > AT+COPS?
    0000024454 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
    0000024457 [ncp.at] TRACE: < +COPS: 0
    0000024510 [app.help] INFO: Operator Selection (COPS) Read: mode=automatic (0)
    0000024458 [ncp.at] TRACE: < OK
    0000024458 [ncp.at] TRACE: > AT+CREG?
    0000024460 [ncp.at] TRACE: < +CREG: 2,0
    0000024514 [app.help] INFO: Network registration (CREG) Status: not registered, not searching (0)
    0000024460 [ncp.at] TRACE: < OK
    0000024461 [ncp.at] TRACE: > AT+CGREG?
    0000024463 [ncp.at] TRACE: < +CGREG: 2,0
    0000024519 [app.help] INFO: GPRS network (CGREG) Status: not registered, not searching (0)
    0000024463 [ncp.at] TRACE: < OK
    0000024464 [ncp.at] TRACE: > AT+CEREG?
    0000024466 [ncp.at] TRACE: < +CEREG: 2,4
    0000024525 [app.help] INFO: EPS network (CEREG) Status: unknown, may be out of coverage area (4)
    0000024466 [ncp.at] TRACE: < OK
    0000025466 [ncp.at] TRACE: < +CPIN: READY
    0000025467 [ncp.at] TRACE: < +QUSIM: 1
    0000025467 [ncp.at] TRACE: > AT+CIMI
    0000025472 [ncp.at] TRACE: < OK
    0000026172 [ncp.at] TRACE: < +QIND: SMS DONE
    0000027072 [ncp.at] TRACE: < +QIND: PB DONE
    0000028072 [ncp.at] TRACE: < +CREG: 5,“00F1”,“0054D16”,2
    0000028078 [app.help] INFO: Network registration (CREG) Status: registered, roaming (5)
    0000028080 [app.help] INFO: Tracking area code: 00F1
    0000028081 [app.help] INFO: Cell identifier: 0054D16
    0000028083 [app.help] INFO: Access technology: UTRAN (2)
    0000028073 [ncp.at] TRACE: > AT+CIMI
    0000028078 [ncp.at] TRACE: < OK
    0000029478 [ncp.at] TRACE: < +CGREG: 5,“00F1”,“0054D16”,2
    0000029482 [app.help] INFO: GPRS network (CGREG) Status: registered, roaming (5)
    0000029484 [app.help] INFO: Tracking area code: 00F1
    0000029484 [app.help] INFO: Cell identifier: 0054D16
    0000029486 [app.help] INFO: Access technology: UTRAN (2)
    0000029479 [ncp.client] TRACE: NCP connection state changed: 2
    0000029479 [gsm0710muxer] INFO: Openning mux channel 2
    0000029488 [net.pppncp] TRACE: NCP event 100
    0000029488 [net.pppncp] TRACE: New auth info
    0000029491 [net.pppncp] TRACE: NCP event 2
    0000029491 [net.pppncp] TRACE: State changed event: 2
    0000029492 [ncp.at] TRACE: > AT+CIMI
    0000029492 [net.ppp.client] TRACE: PPP thread event LOWER_UP
    0000029493 [net.ppp.client] TRACE: State READY → CONNECT
    0000029493 [net.ppp.client] TRACE: State CONNECT → CONNECTING
    0000029497 [ncp.at] TRACE: < OK
    0000030500 [ncp.at] TRACE: > AT
    0000030503 [ncp.at] TRACE: < OK
    0000030503 [ncp.at] TRACE: > ATO
    0000030507 [ncp.at] TRACE: > ATD99**1#
    0000030519 [net.ppp.client] TRACE: PPP phase → 3
    0000030519 [net.ppp.client] TRACE: PPP phase → 6
    0000030527 [net.ppp.client] TRACE: PPP phase → 7
    0000030531 [net.ppp.client] TRACE: PPP phase → 9
    0000031537 [net.ppp.ipcp] ERROR: Peer NAK’d an option unknown to us
    0000033695 [ncp.at] TRACE: > AT+CGMI
    0000033700 [ncp.at] TRACE: < OK
    0000033701 [app] INFO: manufacturer: Quectel
    0000033704 [app] INFO: model: EG91
    0000033707 [app] INFO: firmware version: EG91EXGAR08A03M1G
    0000033713 [app] INFO: ordering code: QuectelEG91Revision: EG91EXGAR08A03M1G
    0000033717 [app] INFO: IMEI: 867648042179992
    0000033720 [app] INFO: IMSI: Quectel
    0000033725 [app] INFO: ICCID: 89883070000010678603
    0000033783 [app] INFO: Still trying to connect to cellular 00:10
    0000033783 [app] INFO: Power source: USB Host
    0000033785 [app] INFO: Battery state: charged, SoC: 99.21
    0000043783 [app] INFO: Still trying to connect to cellular 00:20
    0000043783 [app] INFO: Power source: USB Host
    0000043785 [app] INFO: Battery state: charged, SoC: 99.21
    0000053783 [app] INFO: Still trying to connect to cellular 00:30
    0000053783 [app] INFO: Power source: USB Host
    0000053785 [app] INFO: Battery state: charged, SoC: 99.21
Thank you for your assistance @chipmc
@rickkas7 your suggestion/support will be much appreciated
Can someone please help me? I cannot find where to submit a support ticket and It has been 8 days since I am waiting
@Colleen :slight_smile:
Hi Djamila-
Sorry for the delay. Flashing green means that the Tracker is having trouble connecting. Has the tracker moved into an area with weak cell signal? Check the Carrier List to make sure you have a compatible cellular carrier for your device and location.
Hi @colleen ,
I am in Kigali, Rwanda and we have a good 3G/4G coverage. we do have also Borons that are working perfectly with local SIMs.
After “cloud debug” the tracker blinked cyan for 10 seconds then went back to green.
Hi @djamimat -
Chip mentioned that this issue is ongoing.
Has the problem changed at all? Can you share the latest cloud debug output?
My hunch right now is that this Tracker was configured for European networks and that is why it’s not currently working. @rickkas7 what do you think?
It’s not possible to tell from just that information what is wrong. The best option is to use the Web Device Doctor to flash debugging firmware to the Tracker.
You can often monitor the status directly from the web page, but for certain blinking green errors you may need to use a serial terminal program or the particle serial monitor command in the Particle CLI to get detailed logs during the connection process to see what’s actually failing.
Hi everyone. Firstly thanks for your help on this matter; we have been deploying Particle devices in Rwanda for 4 years now (www.kumva.io), and it would be great to find a scalable solution to our connectivity issues :slight_smile:
The device is Tracker ONE523MEA, and below is the connectivity debug output:
Serial monitor opened successfully:
> 0000015380 [app] INFO: Starting Tests!
0000015380 [app] INFO: Platform: Tracker
0000015380 [app] INFO: Binary compiled for: 4.0.0
0000015381 [app] INFO: Cloud Debug Release 4.0.5
0000015381 [app] INFO: System version: 4.0.0
0000015382 [app] INFO: Device ID: e00fce6859ea9206d7673324
0000015382 [app] INFO: Power source: USB Host
0000015385 [app] INFO: Battery state: charged, SoC: 100.00
0000015385 [app] INFO: This device could have Ethernet (is 3rd generation)
0000015387 [app] INFO: FEATURE_ETHERNET_DETECTION not enabled, so Ethernet will not be used (even i
0000023395 [app] INFO: deviceID: e00fce6859ea9206d7673324
0000023396 [app] INFO: PMIC inputVoltageLimit: 3880 mV
0000023397 [app] INFO: PMIC inputCurrentLimit: 500 mA
0000023398 [app] INFO: PMIC minimumSystemVoltage: 3500 mV
0000023399 [app] INFO: PMIC chargeCurrentValue: 1024 mA
0000023400 [app] INFO: PMIC chargeVoltageValue: 4112 mV
0000023400 [app] INFO: modem is not yet responding
0000023406 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000023412 [app] INFO: Still trying to connect to cellular 00:00
0000023413 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000023414 [app] INFO: Power source: USB Host
0000023417 [ncp.client] TRACE: Powering modem on, ncpId: 0x64
0000023417 [ncp.client] TRACE: Modem already on
0000023479 [mux] INFO: Starting GSM07.10 muxer
0000023480 [mux] INFO: Openning mux channel 0
0000023480 [mux] INFO: GSM07.10 muxer thread started
0000023482 [mux] INFO: Openning mux channel 1
0000023482 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000023486 [app] INFO: Battery state: charged, SoC: 100.00
0000023533 [ncp.at] TRACE: > AT
0000023536 [ncp.at] TRACE: < OK
0000023537 [ncp.client] TRACE: NCP ready to accept AT commands
0000023537 [ncp.at] TRACE: > AT+CFUN=1,0
0000023547 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000023564 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000023541 [ncp.at] TRACE: < OK
0000023541 [mux] INFO: Mux channel 1 already opened
0000023542 [ncp.at] TRACE: > AT
0000023543 [ncp.at] TRACE: < OK
0000023544 [ncp.client] TRACE: NCP state changed: 1
0000023544 [net.pppncp] TRACE: NCP event 1
0000023545 [ncp.at] TRACE: > AT+QCFG="cmux/urcport",1
0000023548 [ncp.at] TRACE: < OK
0000023550 [ncp.at] TRACE: > AT+CGEREP=1,0
0000023551 [ncp.at] TRACE: < OK
0000023553 [net.ppp.client] TRACE: PPP thread event ADM_UP
0000023553 [net.ppp.client] TRACE: State NONE -> READY
0000023555 [ncp.at] TRACE: > AT+CFUN=1,0
0000023601 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000023603 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000023558 [ncp.at] TRACE: < OK
0000023558 [ncp.at] TRACE: > AT+CCID
0000023561 [ncp.at] TRACE: < +CCID: 89883070000010678603
0000023561 [ncp.at] TRACE: < OK
0000023562 [ncp.at] TRACE: > AT+CGDCONT=1,"IP","super"
0000023608 [app.help] INFO: PDP context definition (CGDCONT): cid=1 pdpType=IP APN=super
0000023566 [ncp.at] TRACE: < OK
0000023567 [ncp.at] TRACE: > AT+CFUN=1,0
0000023611 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000023613 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000023568 [ncp.at] TRACE: < OK
0000023569 [ncp.at] TRACE: > AT+CREG=2
0000023616 [app.help] INFO: Network registration (CREG) Set to location enabled (2)
0000023571 [ncp.at] TRACE: < OK
0000023572 [ncp.at] TRACE: > AT+CGREG=2
0000023619 [app.help] INFO: GPRS network (CGREG) Set to location enabled (2)
0000023573 [ncp.at] TRACE: < OK
0000023574 [ncp.at] TRACE: > AT+CEREG=2
0000023623 [app.help] INFO: EPS network (CEREG) Set to location enabled (2)
0000023576 [ncp.at] TRACE: < OK
0000023576 [ncp.client] TRACE: NCP connection state changed: 1
0000023576 [net.pppncp] TRACE: NCP event 2
0000023577 [net.pppncp] TRACE: State changed event: 1
0000023577 [ncp.at] TRACE: > AT+COPS?
0000023578 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000023585 [ncp.at] TRACE: < +COPS: 0,0,"MTNIrinde#Covid19 Twilio",2
0000023630 [app.help] INFO: Operator Selection (COPS) Read: mode=automatic (0)
0000023632 [app.help] INFO: format=long alphanumeric (0)
0000023632 [app.help] INFO: oper=MTNIrinde#Covid19 Twilio
0000023585 [ncp.at] TRACE: < OK
0000023586 [ncp.at] TRACE: > AT+CREG?
0000023588 [ncp.at] TRACE: < +CREG: 2,5,"00F1","005A387",2
0000023637 [app.help] INFO: Network registration (CREG) Status: registered, roaming (5)
0000023638 [app.help] INFO: Tracking area code: 00F1
0000023639 [app.help] INFO: Cell identifier: 005A387
0000023640 [app.help] INFO: Access technology: UTRAN (2)
0000023589 [ncp.at] TRACE: < OK
0000023590 [ncp.at] TRACE: > AT+CGREG?
0000023592 [ncp.at] TRACE: < +CGREG: 2,5,"00F1","005A387",2
0000023644 [app.help] INFO: GPRS network (CGREG) Status: registered, roaming (5)
0000023652 [app.help] INFO: Tracking area code: 00F1
0000023655 [app.help] INFO: Cell identifier: 005A387
0000023656 [app.help] INFO: Access technology: UTRAN (2)
0000023593 [ncp.at] TRACE: < OK
0000023593 [ncp.at] TRACE: > AT+CEREG?
0000023595 [ncp.at] TRACE: < +CEREG: 2,4
0000023661 [app.help] INFO: EPS network (CEREG) Status: unknown, may be out of coverage area (4)
0000023596 [ncp.at] TRACE: < OK
0000023596 [ncp.client] TRACE: NCP connection state changed: 2
0000023596 [mux] INFO: Openning mux channel 2
0000023646 [net.pppncp] TRACE: NCP event 100
0000023646 [net.pppncp] TRACE: New auth info
0000023649 [net.pppncp] TRACE: NCP event 2
0000023649 [net.pppncp] TRACE: State changed event: 2
0000023650 [net.ppp.client] TRACE: PPP thread event LOWER_UP
0000023650 [net.ppp.client] TRACE: State READY -> CONNECT
0000023651 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000023651 [ncp.at] TRACE: > AT+CIMI
0000023654 [ncp.at] TRACE: < OK
0000024657 [ncp.at] TRACE: > AT
0000024658 [ncp.at] TRACE: < OK
0000024659 [ncp.at] TRACE: > ATO
0000024662 [ncp.at] TRACE: > ATD*99***1#
0000024672 [net.ppp.client] TRACE: PPP phase -> 3
0000024672 [net.ppp.client] TRACE: PPP phase -> 6
0000024682 [net.ppp.client] TRACE: PPP phase -> 7
0000024686 [net.ppp.client] TRACE: PPP phase -> 9
0000025689 [net.ppp.ipcp] ERROR: Peer NAK'd an option unknown to us
0000033400 [ncp.at] TRACE: > AT+CGMI
0000033405 [ncp.at] TRACE: < OK
0000033406 [app] INFO: manufacturer: Quectel
0000033409 [app] INFO: model: EG91
0000033412 [app] INFO: firmware version: EG91EXGAR08A03M1G
0000033417 [app] INFO: ordering code: QuectelEG91Revision: EG91EXGAR08A03M1G
0000033421 [app] INFO: IMEI: 867648042179992
0000033424 [app] INFO: IMSI: Quectel
0000033428 [app] INFO: ICCID: 89883070000010678603
0000033429 [app] INFO: Still trying to connect to cellular 00:10
0000033429 [app] INFO: Power source: USB Host
0000033432 [app] INFO: Battery state: charged, SoC: 100.00
0000043428 [app] INFO: Still trying to connect to cellular 00:20
0000043428 [app] INFO: Power source: USB Host
0000043431 [app] INFO: Battery state: charged, SoC: 100.00
0000053428 [app] INFO: Still trying to connect to cellular 00:30
0000053428 [app] INFO: Power source: USB Host
0000053431 [app] INFO: Battery state: charged, SoC: 100.00
0000063428 [app] INFO: Still trying to connect to cellular 00:40
0000063428 [app] INFO: Power source: USB Host
0000063431 [app] INFO: Battery state: charged, SoC: 100.00
0000073428 [app] INFO: Still trying to connect to cellular 00:50
0000073428 [app] INFO: Power source: USB Host
0000073431 [app] INFO: Battery state: charged, SoC: 100.00
0000083428 [app] INFO: Still trying to connect to cellular 01:00
0000083428 [app] INFO: Power source: USB Host
0000083431 [app] INFO: Battery state: charged, SoC: 100.00
0000093428 [app] INFO: Still trying to connect to cellular 01:10
0000093428 [app] INFO: Power source: USB Host
0000093431 [app] INFO: Battery state: charged, SoC: 100.00
0000103428 [app] INFO: Still trying to connect to cellular 01:20
0000103428 [app] INFO: Power source: USB Host
0000103431 [app] INFO: Battery state: charged, SoC: 100.00
0000113428 [app] INFO: Still trying to connect to cellular 01:30
0000113428 [app] INFO: Power source: USB Host
0000113431 [app] INFO: Battery state: charged, SoC: 100.00
^[[1;2A^[[1;2A^[[1;2A^[[1;2A^[[1;0000123428 [app] INFO: Still trying to connect to cellular 01:40
0000123428 [app] INFO: Power source: USB Host
0000123431 [app] INFO: Battery state: charged, SoC: 100.00
0000133428 [app] INFO: Still trying to connect to cellular 01:50
0000133428 [app] INFO: Power source: USB Host
0000133431 [app] INFO: Battery state: charged, SoC: 100.00
0000143428 [app] INFO: Still trying to connect to cellular 02:00
0000143428 [app] INFO: Power source: USB Host
0000143431 [app] INFO: Battery state: charged, SoC: 100.00
0000153428 [app] INFO: Still trying to connect to cellular 02:10
0000153428 [app] INFO: Power source: USB Host
0000153431 [app] INFO: Battery state: charged, SoC: 100.00
0000163428 [app] INFO: Still trying to connect to cellular 02:20
0000163428 [app] INFO: Power source: USB Host
0000163431 [app] INFO: Battery state: charged, SoC: 100.00
0000173428 [app] INFO: Still trying to connect to cellular 02:30
0000173428 [app] INFO: Power source: USB Host
0000173431 [app] INFO: Battery state: charged, SoC: 100.00
0000183428 [app] INFO: Still trying to connect to cellular 02:40
0000183428 [app] INFO: Power source: USB Host
0000183431 [app] INFO: Battery state: charged, SoC: 100.00
0000193428 [app] INFO: Still trying to connect to cellular 02:50
0000193428 [app] INFO: Power source: USB Host
0000193431 [app] INFO: Battery state: charged, SoC: 100.00
0000203428 [app] INFO: Still trying to connect to cellular 03:00
0000203428 [app] INFO: Power source: USB Host
0000203431 [app] INFO: Battery state: charged, SoC: 100.00
0000213428 [app] INFO: Still trying to connect to cellular 03:10
0000213428 [app] INFO: Power source: USB Host
0000213431 [app] INFO: Battery state: charged, SoC: 100.00
0000219681 [net.ppp.client] TRACE: PPP phase -> 11
0000219681 [net.ppp.client] TRACE: PPP phase -> 6
0000223428 [app] INFO: Still trying to connect to cellular 03:20
0000223428 [app] INFO: Power source: USB Host
0000223431 [app] INFO: Battery state: charged, SoC: 100.00
0000231681 [net.ppp.client] TRACE: PPP phase -> 12
0000231681 [net.ppp.client] TRACE: PPP phase -> 0
0000231681 [net.ppp.client] TRACE: PPP thread event DOWN
0000231682 [net.ppp.client] TRACE: State CONNECTING -> DISCONNECT
0000231682 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0000231682 [net.ppp.client] TRACE: PPP thread event DOWN
0000231683 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0000231683 [net.ppp.client] TRACE: State DISCONNECTED -> CONNECT
0000231783 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000232785 [ncp.at] TRACE: > AT
0000232787 [ncp.at] TRACE: < OK
0000232788 [ncp.at] TRACE: > ATO
0000232791 [ncp.at] TRACE: > ATD*99***1#
0000232801 [net.ppp.client] TRACE: PPP phase -> 3
0000232801 [net.ppp.client] TRACE: PPP phase -> 6
0000232810 [net.ppp.client] TRACE: PPP phase -> 7
0000232814 [net.ppp.client] TRACE: PPP phase -> 9
0000233428 [app] INFO: Still trying to connect to cellular 03:30
0000233428 [app] INFO: Power source: USB Host
0000233431 [app] INFO: Battery state: charged, SoC: 100.00
0000233817 [net.ppp.ipcp] ERROR: Peer NAK'd an option unknown to us
0000243428 [app] INFO: Still trying to connect to cellular 03:40
0000243428 [app] INFO: Power source: USB Host
0000243431 [app] INFO: Battery state: charged, SoC: 100.00
0000253428 [app] INFO: Still trying to connect to cellular 03:50
0000253428 [app] INFO: Power source: USB Host
0000253431 [app] INFO: Battery state: charged, SoC: 100.00
0000263428 [app] INFO: Still trying to connect to cellular 04:00
0000263428 [app] INFO: Power source: USB Host
0000263431 [app] INFO: Battery state: charged, SoC: 100.00
0000273428 [app] INFO: Still trying to connect to cellular 04:10
0000273428 [app] INFO: Power source: USB Host
0000273431 [app] INFO: Battery state: charged, SoC: 100.00
0000283428 [app] INFO: Still trying to connect to cellular 04:20
0000283428 [app] INFO: Power source: USB Host
0000283431 [app] INFO: Battery state: charged, SoC: 100.00
0000293428 [app] INFO: Still trying to connect to cellular 04:30
0000293428 [app] INFO: Power source: USB Host
0000293431 [app] INFO: Battery state: charged, SoC: 100.00
0000303428 [app] INFO: Still trying to connect to cellular 04:40
0000303428 [app] INFO: Power source: USB Host
0000303431 [app] INFO: Battery state: charged, SoC: 100.00
0000313428 [app] INFO: Still trying to connect to cellular 04:50
0000313428 [app] INFO: Power source: USB Host
0000313431 [app] INFO: Battery state: charged, SoC: 100.00
0000323428 [app] INFO: Still trying to connect to cellular 05:00
0000323428 [app] INFO: Power source: USB Host
0000323431 [app] INFO: Battery state: charged, SoC: 100.00
0000323702 [net.pppncp] ERROR: Failed to bring up PPP session after 300 seconds
0000323702 [net.pppncp] TRACE: NCP event 3
0000323702 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000323703 [net.ppp.client] TRACE: PPP thread event ADM_DOWN
0000323703 [net.ppp.client] TRACE: State CONNECTING -> DISCONNECT
0000323703 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0000323704 [system.nm] TRACE: Interface 4 power state changed: 3
0000323704 [ncp.client] TRACE: Try powering modem off using AT command
0000323705 [net.ppp.client] TRACE: PPP phase -> 11
0000323705 [net.ppp.client] TRACE: PPP phase -> 6
0000323706 [ncp.at] TRACE: > AT+QPOWD
0000323709 [net.ppp.client] TRACE: PPP phase -> 12
0000323710 [net.ppp.client] TRACE: PPP phase -> 0
0000323710 [net.ppp.client] TRACE: PPP thread event DOWN
0000323710 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0000323711 [net.ppp.client] TRACE: State DISCONNECTED -> NONE
0000323781 [ncp.at] TRACE: < OK
0000323782 [ncp.client] TRACE: Waiting the modem to be turned off...
0000333428 [app] INFO: Still trying to connect to cellular 05:10
0000333428 [app] INFO: Power source: USB Host
0000333431 [app] INFO: Battery state: charged, SoC: 100.00
0000337997 [net.pppncp] TRACE: NCP event 3
0000337997 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000337997 [system.nm] TRACE: Interface 4 power state changed: 1
0000337998 [ncp.client] TRACE: It takes 14216 ms to power off the modem.
0000337998 [mux] INFO: Stopping GSM07.10 muxer
0000337999 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000337999 [mux] INFO: Closing all muxed channels
0000337999 [mux] INFO: Closing mux channel 1
0000338000 [mux] INFO: Closing mux channel 2
0000338000 [mux] INFO: Muxed channel 3 already closed
0000338000 [mux] INFO: Muxed channel 4 already closed
0000338001 [mux] INFO: GSM07.10 muxer thread exiting
0000338001 [ncp.client] TRACE: NCP connection state changed: 1
0000338001 [net.pppncp] TRACE: NCP event 2
0000338002 [net.pppncp] TRACE: State changed event: 1
0000338002 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000338003 [mux] INFO: GSM07.10 muxer stopped
0000338003 [ncp.client] TRACE: Soft power off modem successfully
0000338003 [ncp.client] TRACE: Deinit modem serial.
0000338104 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000338104 [ncp.client] TRACE: Modem already off
0000338104 [ncp.client] TRACE: Soft power off modem successfully
0000338105 [ncp.client] TRACE: Deinit modem serial.
0000338105 [ncp.client] TRACE: NCP connection state changed: 0
0000338105 [net.pppncp] TRACE: NCP event 2
0000338106 [net.pppncp] TRACE: State changed event: 0
0000338106 [ncp.client] TRACE: NCP state changed: 0
0000338106 [net.pppncp] TRACE: NCP event 1
0000338107 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000338206 [ncp.client] TRACE: Powering modem on, ncpId: 0x64
0000338206 [net.pppncp] TRACE: NCP event 3
0000338206 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000338207 [system.nm] TRACE: Interface 4 power state changed: 4
0000343428 [app] INFO: Still trying to connect to cellular 05:20
0000343428 [app] INFO: Power source: USB Host
0000343431 [app] INFO: Battery state: charged, SoC: 100.00
0000347472 [net.pppncp] TRACE: NCP event 3
0000347472 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000347472 [system.nm] TRACE: Interface 4 power state changed: 2
0000347473 [ncp.client] TRACE: Modem powered on
0000348473 [ncp.at] TRACE: > AT
0000348475 [ncp.at] TRACE: < OK
0000348476 [ncp.client] TRACE: NCP ready to accept AT commands
0000348476 [ncp.at] TRACE: > AT+CFUN=1,0
0000348483 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000348487 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000348479 [ncp.at] TRACE: < OK
0000348479 [ncp.at] TRACE: > AT+IFC=2,2
0000348482 [ncp.at] TRACE: < OK
0000348483 [ncp.at] TRACE: > AT
0000348484 [ncp.at] TRACE: < OK
0000348485 [ncp.at] TRACE: > AT+IPR=460800
0000348489 [ncp.at] TRACE: < OK
0000349490 [ncp.at] TRACE: > AT
0000349491 [ncp.at] TRACE: < OK
0000349491 [ncp.at] TRACE: > AT+CPIN?
0000349493 [ncp.at] TRACE: < +CPIN: READY
0000349494 [ncp.at] TRACE: < OK
0000349494 [ncp.at] TRACE: > AT+CCID
0000349496 [ncp.at] TRACE: < +CCID: 89883070000010678603
0000349496 [ncp.at] TRACE: < OK
0000349496 [ncp.at] TRACE: > AT+QDSIM=0
0000349497 [ncp.at] TRACE: < OK
0000349498 [ncp.at] TRACE: > AT+CMUX=0,0,7,1509,,,,,
0000349499 [ncp.at] TRACE: < OK
0000349500 [mux] INFO: Starting GSM07.10 muxer
0000349500 [mux] INFO: Openning mux channel 0
0000349501 [mux] INFO: GSM07.10 muxer thread started
0000349602 [mux] INFO: Openning mux channel 1
0000349653 [ncp.at] TRACE: > AT
0000349654 [ncp.at] TRACE: < +CREG: 0
0000349676 [app.help] INFO: Network registration (CREG) Status: not registered, not searching (0)
0000349654 [ncp.at] TRACE: < +CGREG: 0
0000349700 [app.help] INFO: GPRS network (CGREG) Status: not registered, not searching (0)
0000349655 [ncp.at] TRACE: < +CGEV: ME DETACH
0000349656 [ncp.at] TRACE: < OK
0000349656 [ncp.client] TRACE: NCP state changed: 1
0000349656 [net.pppncp] TRACE: NCP event 1
0000349657 [ncp.at] TRACE: > AT+QCFG="cmux/urcport",1
0000349659 [ncp.at] TRACE: < OK
0000349660 [ncp.at] TRACE: > AT+CGEREP=1,0
0000349661 [ncp.at] TRACE: < OK
0000349663 [net.ppp.client] TRACE: PPP thread event ADM_UP
0000349663 [net.ppp.client] TRACE: State NONE -> READY
0000349665 [ncp.at] TRACE: > AT+CFUN=1,0
0000349709 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000349711 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000349667 [ncp.at] TRACE: < OK
0000349668 [ncp.at] TRACE: > AT+CCID
0000349670 [ncp.at] TRACE: < +CCID: 89883070000010678603
0000349670 [ncp.at] TRACE: < OK
0000349671 [ncp.at] TRACE: > AT+CGDCONT=1,"IP","super"
0000349716 [app.help] INFO: PDP context definition (CGDCONT): cid=1 pdpType=IP APN=super
0000349675 [ncp.at] TRACE: < OK
0000349676 [ncp.at] TRACE: > AT+CFUN=1,0
0000349720 [app.help] INFO: Set module functionality (CFUN): full functionality (1)
0000349722 [app.help] INFO: Reset Mode: do not reset before setting fun (0)
0000349677 [ncp.at] TRACE: < OK
0000349678 [ncp.at] TRACE: > AT+CREG=2
0000349725 [app.help] INFO: Network registration (CREG) Set to location enabled (2)
0000349679 [ncp.at] TRACE: < OK
0000349680 [ncp.at] TRACE: > AT+CGREG=2
0000349728 [app.help] INFO: GPRS network (CGREG) Set to location enabled (2)
0000349682 [ncp.at] TRACE: < OK
0000349683 [ncp.at] TRACE: > AT+CEREG=2
0000349731 [app.help] INFO: EPS network (CEREG) Set to location enabled (2)
0000349685 [ncp.at] TRACE: < OK
0000349685 [ncp.client] TRACE: NCP connection state changed: 1
0000349685 [net.pppncp] TRACE: NCP event 2
0000349686 [net.pppncp] TRACE: State changed event: 1
0000349687 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000349687 [ncp.at] TRACE: > AT+COPS?
0000349689 [ncp.at] TRACE: < +COPS: 0
0000349738 [app.help] INFO: Operator Selection (COPS) Read: mode=automatic (0)
0000349689 [ncp.at] TRACE: < OK
0000349690 [ncp.at] TRACE: > AT+CREG?
0000349691 [ncp.at] TRACE: < +CREG: 2,2
0000349742 [app.help] INFO: Network registration (CREG) Status: not registered, searching (2)
0000349692 [ncp.at] TRACE: < OK
0000349692 [ncp.at] TRACE: > AT+CGREG?
0000349694 [ncp.at] TRACE: < +CGREG: 2,2
0000349746 [app.help] INFO: GPRS network (CGREG) Status: not registered, searching (2)
0000349695 [ncp.at] TRACE: < OK
0000349695 [ncp.at] TRACE: > AT+CEREG?
0000349697 [ncp.at] TRACE: < +CEREG: 2,2
0000349750 [app.help] INFO: EPS network (CEREG) Status: not registered, searching (2)
0000349698 [ncp.at] TRACE: < OK
0000350098 [ncp.at] TRACE: < +QIND: PB DONE
0000353428 [app] INFO: Still trying to connect to cellular 05:30
0000353428 [app] INFO: Power source: USB Host
0000353431 [app] INFO: Battery state: charged, SoC: 100.00
0000354998 [ncp.at] TRACE: < +CEREG: 2
0000355000 [app.help] INFO: EPS network (CEREG) Status: not registered, searching (2)
0000355098 [ncp.at] TRACE: < +CREG: 5,"00F1","005B6CD",2
0000355101 [app.help] INFO: Network registration (CREG) Status: registered, roaming (5)
0000355102 [app.help] INFO: Tracking area code: 00F1
0000355103 [app.help] INFO: Cell identifier: 005B6CD
0000355104 [app.help] INFO: Access technology: UTRAN (2)
0000355099 [ncp.at] TRACE: > AT+CIMI
0000355111 [ncp.at] TRACE: < OK
0000357012 [ncp.at] TRACE: < +CGREG: 5,"00F1","005B6CD",2
0000357015 [app.help] INFO: GPRS network (CGREG) Status: registered, roaming (5)
0000357016 [app.help] INFO: Tracking area code: 00F1
0000357017 [app.help] INFO: Cell identifier: 005B6CD
0000357018 [app.help] INFO: Access technology: UTRAN (2)
0000357012 [ncp.client] TRACE: NCP connection state changed: 2
0000357013 [mux] INFO: Openning mux channel 2
0000357044 [net.pppncp] TRACE: NCP event 100
0000357045 [net.pppncp] TRACE: New auth info
0000357047 [net.pppncp] TRACE: NCP event 2
0000357047 [net.pppncp] TRACE: State changed event: 2
0000357048 [ncp.at] TRACE: > AT+CIMI
0000357049 [net.ppp.client] TRACE: PPP thread event LOWER_UP
0000357050 [net.ppp.client] TRACE: State READY -> CONNECT
0000357050 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000357052 [ncp.at] TRACE: < OK
0000358054 [ncp.at] TRACE: > AT
0000358057 [ncp.at] TRACE: < OK
0000358058 [ncp.at] TRACE: > ATO
0000358061 [ncp.at] TRACE: > ATD*99***1#
0000358073 [net.ppp.client] TRACE: PPP phase -> 3
0000358073 [net.ppp.client] TRACE: PPP phase -> 6
0000358082 [net.ppp.client] TRACE: PPP phase -> 7
0000358086 [net.ppp.client] TRACE: PPP phase -> 9
0000359089 [net.ppp.ipcp] ERROR: Peer NAK'd an option unknown to us
0000363428 [app] INFO: Still trying to connect to cellular 05:40
0000363428 [app] INFO: Power source: USB Host
0000363431 [app] INFO: Battery state: charged, SoC: 100.00
0000364072 [ncp.at] TRACE: < +CREG: 5,"00F8","004B70B",2
0000364074 [app.help] INFO: Network registration (CREG) Status: registered, roaming (5)
0000364075 [app.help] INFO: Tracking area code: 00F8
0000364076 [app.help] INFO: Cell identifier: 004B70B
0000364077 [app.help] INFO: Access technology: UTRAN (2)
0000364172 [ncp.at] TRACE: < +CGREG: 5,"00F8","004B70B",2
0000364174 [app.help] INFO: GPRS network (CGREG) Status: registered, roaming (5)
0000364175 [app.help] INFO: Tracking area code: 00F8
0000364176 [app.help] INFO: Cell identifier: 004B70B
0000364177 [app.help] INFO: Access technology: UTRAN (2)
0000373428 [app] INFO: Still trying to connect to cellular 05:50
0000373428 [app] INFO: Power source: USB Host
0000373431 [app] INFO: Battery state: charged, SoC: 100.00
0000383428 [app] INFO: Still trying to connect to cellular 06:00
0000383428 [app] INFO: Power source: USB Host
0000383431 [app] INFO: Battery state: charged, SoC: 100.00
0000393428 [app] INFO: Still trying to connect to cellular 06:10
0000393428 [app] INFO: Power source: USB Host
0000393431 [app] INFO: Battery state: charged, SoC: 100.00
0000403428 [app] INFO: Still trying to connect to cellular 06:20
0000403428 [app] INFO: Power source: USB Host
0000403431 [app] INFO: Battery state: charged, SoC: 100.00
0000413428 [app] INFO: Still trying to connect to cellular 06:30
0000413428 [app] INFO: Power source: USB Host
0000413431 [app] INFO: Battery state: charged, SoC: 100.00
0000423428 [app] INFO: Still trying to connect to cellular 06:40
0000423428 [app] INFO: Power source: USB Host
0000423431 [app] INFO: Battery state: charged, SoC: 100.00
0000433428 [app] INFO: Still trying to connect to cellular 06:50
0000433428 [app] INFO: Power source: USB Host
0000433431 [app] INFO: Battery state: charged, SoC: 100.00
0000443428 [app] INFO: Still trying to connect to cellular 07:00
0000443428 [app] INFO: Power source: USB Host
0000443431 [app] INFO: Battery state: charged, SoC: 100.00
0000453428 [app] INFO: Still trying to connect to cellular 07:10
0000453428 [app] INFO: Power source: USB Host
0000453431 [app] INFO: Battery state: charged, SoC: 100.00
0000463428 [app] INFO: Still trying to connect to cellular 07:20
0000463428 [app] INFO: Power source: USB Host
0000463431 [app] INFO: Battery state: charged, SoC: 100.00
0000473428 [app] INFO: Still trying to connect to cellular 07:30
0000473428 [app] INFO: Power source: USB Host
0000473431 [app] INFO: Battery state: charged, SoC: 100.00
0000483428 [app] INFO: Still trying to connect to cellular 07:40
0000483428 [app] INFO: Power source: USB Host
0000483431 [app] INFO: Battery state: charged, SoC: 100.00
0000493428 [app] INFO: Still trying to connect to cellular 07:50
0000493428 [app] INFO: Power source: USB Host
0000493431 [app] INFO: Battery state: charged, SoC: 100.00
0000503428 [app] INFO: Still trying to connect to cellular 08:00
0000503428 [app] INFO: Power source: USB Host
0000503431 [app] INFO: Battery state: charged, SoC: 100.00
0000513428 [app] INFO: Still trying to connect to cellular 08:10
0000513428 [app] INFO: Power source: USB Host
0000513431 [app] INFO: Battery state: charged, SoC: 100.00
0000523428 [app] INFO: Still trying to connect to cellular 08:20
0000523428 [app] INFO: Power source: USB Host
0000523431 [app] INFO: Battery state: charged, SoC: 100.00
0000533428 [app] INFO: Still trying to connect to cellular 08:30
0000533428 [app] INFO: Power source: USB Host
0000533431 [app] INFO: Battery state: charged, SoC: 100.00
0000536172 [ncp.at] TRACE: < +CREG: 3
0000536176 [app.help] INFO: Network registration (CREG) Status: registration denied (3)
0000536172 [ncp.client] TRACE: NCP connection state changed: 1
0000536172 [net.pppncp] TRACE: NCP event 2
0000536173 [net.pppncp] TRACE: State changed event: 1
0000536173 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000536173 [net.ppp.client] TRACE: State CONNECTING -> DISCONNECT
0000536174 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0000536174 [net.ppp.client] TRACE: PPP phase -> 11
0000536175 [net.ppp.client] TRACE: PPP phase -> 6
0000536273 [ncp.at] TRACE: < +CGREG: 3
0000536275 [app.help] INFO: GPRS network (CGREG) Status: registration denied (3)
0000537473 [ncp.at] TRACE: < +CGEV: NW DETACH
0000543428 [app] INFO: Still trying to connect to cellular 08:40
0000543428 [app] INFO: Power source: USB Host
0000543431 [app] INFO: Battery state: charged, SoC: 100.00
0000548175 [net.ppp.client] TRACE: PPP phase -> 12
0000548175 [net.ppp.client] TRACE: PPP phase -> 0
0000548175 [net.ppp.client] TRACE: PPP thread event DOWN
0000548176 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0000548176 [net.ppp.client] TRACE: State DISCONNECTED -> READY
0000551173 [ncp.at] TRACE: > AT+CEER
0000551179 [ncp.at] TRACE: < +CEER: 6,259
0000551179 [ncp.at] TRACE: < OK
0000551180 [ncp.at] TRACE: > AT+CMEE?
0000551182 [ncp.at] TRACE: < +CMEE: 1
0000551182 [ncp.at] TRACE: < OK
0000551183 [ncp.at] TRACE: > AT+CREG?
0000551185 [ncp.at] TRACE: < +CREG: 2,3
0000551198 [app.help] INFO: Network registration (CREG) Status: registration denied (3)
0000551185 [ncp.at] TRACE: < OK
0000551186 [ncp.at] TRACE: > AT+CEREG?
0000551188 [ncp.at] TRACE: < +CEREG: 2,4
0000551202 [app.help] INFO: EPS network (CEREG) Status: unknown, may be out of coverage area (4)
0000551188 [ncp.at] TRACE: < OK
0000551189 [ncp.at] TRACE: > AT+QCSQ
0000551192 [ncp.at] TRACE: < +QCSQ: "LTE",125,0,8,0
0000551192 [ncp.at] TRACE: < OK
0000553392 [ncp.at] TRACE: < +CREG: 5,"00F1","005A387",2
0000553399 [app.help] INFO: Network registration (CREG) Status: registered, roaming (5)
0000553400 [app.help] INFO: Tracking area code: 00F1
0000553401 [app.help] INFO: Cell identifier: 005A387
0000553402 [app.help] INFO: Access technology: UTRAN (2)
0000553393 [ncp.at] TRACE: > AT+CIMI
0000553393 [ncp.at] TRACE: < +CGREG: 5,"00F1","005A387",2
0000553405 [app.help] INFO: GPRS network (CGREG) Status: registered, roaming (5)
0000553406 [app.help] INFO: Tracking area code: 00F1
0000553407 [app.help] INFO: Cell identifier: 005A387
0000553408 [app.help] INFO: Access technology: UTRAN (2)
0000553394 [ncp.at] TRACE: < +CEREG: 4
0000553411 [app.help] INFO: EPS network (CEREG) Status: unknown, may be out of coverage area (4)
0000553398 [ncp.at] TRACE: < OK
0000553428 [app] INFO: Still trying to connect to cellular 08:50
0000553428 [app] INFO: Power source: USB Host
0000553431 [app] INFO: Battery state: charged, SoC: 100.00
0000553498 [ncp.client] TRACE: NCP connection state changed: 2
0000553498 [mux] INFO: Mux channel 2 already opened
0000553498 [net.pppncp] TRACE: NCP event 100
0000553499 [net.pppncp] TRACE: New auth info
0000553500 [net.pppncp] TRACE: NCP event 2
0000553501 [net.pppncp] TRACE: State changed event: 2
0000553501 [ncp.at] TRACE: > AT+CIMI
0000553502 [net.ppp.client] TRACE: PPP thread event LOWER_UP
0000553504 [net.ppp.client] TRACE: State READY -> CONNECT
0000553504 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000553505 [ncp.at] TRACE: < OK
0000554507 [ncp.at] TRACE: > AT
0000554510 [ncp.at] TRACE: < OK
0000554511 [ncp.at] TRACE: > ATO
0000554514 [ncp.at] TRACE: > ATD*99***1#
0000554529 [net.ppp.client] TRACE: PPP phase -> 3
0000554529 [net.ppp.client] TRACE: PPP phase -> 6
0000554538 [net.ppp.client] TRACE: PPP phase -> 7
0000554542 [net.ppp.client] TRACE: PPP phase -> 9
0000555547 [net.ppp.ipcp] ERROR: Peer NAK'd an option unknown to us
0000563428 [app] INFO: Sti
@chipmc was particularly worried about the "out of coverage" message:
**0000023661 [app.help] INFO: EPS network (CEREG) Status: unknown, may be out of coverage area (4)**
and thought this was odd too:
**0000023585 [ncp.at] TRACE: < +COPS: 0,0,"MTNIrinde#Covid19 Twilio",2**
Looping in @Cyusa.Yvan for any further testing needs.
also, below are the Device Doctor logs as requested (sorry if this is a repetition of the first post):
Modem Manufacturer: Quectel
Modem Model: EG91
Modem Firmware Version: EG91EXGAR08A03M1G
Power Supply: USB Host
Battery: Charging
Battery SoC: 100
Country:
Carrier:
Access Technology:
Band:
Cellular Global Identity:
0000001774 [system.nm] TRACE: Request to power on the interface
0000001775 [ncp.client] TRACE: Powering modem on, ncpId: 0x64
0000001775 [ncp.client] TRACE: Modem already on
0000001837 [mux] INFO: Starting GSM07.10 muxer
0000001838 [mux] INFO: Openning mux channel 0
0000001838 [mux] INFO: GSM07.10 muxer thread started
0000001840 [mux] INFO: Openning mux channel 1
0000001841 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000001842 [app] INFO: Starting modem
0000001893 [ncp.at] TRACE: > AT
0000001894 [ncp.at] TRACE: < OK
0000001894 [ncp.client] TRACE: NCP ready to accept AT commands
0000001895 [ncp.at] TRACE: > AT+CFUN=1,0
0000001897 [ncp.at] TRACE: < OK
0000001897 [mux] INFO: Mux channel 1 already opened
0000001898 [ncp.at] TRACE: > AT
0000001899 [ncp.at] TRACE: < OK
0000001899 [ncp.client] TRACE: NCP state changed: 1
0000001900 [net.pppncp] TRACE: NCP event 1
0000001901 [ncp.at] TRACE: > AT+QCFG="cmux/urcport",1
0000001904 [ncp.at] TRACE: < OK
0000001904 [ncp.at] TRACE: > AT+CGEREP=1,0
0000001906 [ncp.at] TRACE: < OK
0000001947 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000001951 [net.ppp.client] TRACE: PPP thread event ADM_UP
0000001952 [net.ppp.client] TRACE: State NONE -> READY
0000001955 [ncp.at] TRACE: > AT+CFUN=1,0
0000001955 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000001957 [ncp.at] TRACE: < OK
0000001958 [ncp.at] TRACE: > AT+CCID
0000001962 [ncp.at] TRACE: < +CCID: 89883070000010678603
0000001962 [ncp.at] TRACE: < OK
0000001963 [ncp.at] TRACE: > AT+CGDCONT=1,"IP","super"
0000001969 [ncp.at] TRACE: < OK
0000001969 [ncp.at] TRACE: > AT+CFUN=1,0
0000001971 [ncp.at] TRACE: < OK
0000001972 [ncp.at] TRACE: > AT+CREG=2
0000001973 [ncp.at] TRACE: < OK
0000001974 [ncp.at] TRACE: > AT+CGREG=2
0000001975 [ncp.at] TRACE: < OK
0000001976 [ncp.at] TRACE: > AT+CEREG=2
0000001978 [ncp.at] TRACE: < OK
0000001978 [ncp.client] TRACE: NCP connection state changed: 1
0000001978 [net.pppncp] TRACE: NCP event 2
0000001978 [net.pppncp] TRACE: State changed event: 1
0000001979 [ncp.at] TRACE: > AT+COPS?
0000001979 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000001986 [ncp.at] TRACE: < +COPS: 0,0,"MTNIrinde#Covid19 Twilio",2
0000001987 [ncp.at] TRACE: < OK
0000001987 [ncp.at] TRACE: > AT+CREG?
0000001990 [ncp.at] TRACE: < +CREG: 2,5,"00F1","005B6CD",2
0000001990 [ncp.at] TRACE: < OK
0000001991 [ncp.at] TRACE: > AT+CGREG?
0000001994 [ncp.at] TRACE: < +CGREG: 2,5,"00F1","005B6CD",2
0000001994 [ncp.at] TRACE: < OK
0000001995 [ncp.at] TRACE: > AT+CEREG?
0000001997 [ncp.at] TRACE: < +CEREG: 2,4
0000001997 [ncp.at] TRACE: < OK
0000001998 [ncp.client] TRACE: NCP connection state changed: 2
0000001998 [mux] INFO: Openning mux channel 2
0000002047 [net.pppncp] TRACE: NCP event 100
0000002048 [net.pppncp] TRACE: New auth info
0000002050 [net.pppncp] TRACE: NCP event 2
0000002050 [net.pppncp] TRACE: State changed event: 2
0000002051 [ncp.at] TRACE: > AT+CIMI
0000002051 [net.ppp.client] TRACE: PPP thread event LOWER_UP
0000002052 [net.ppp.client] TRACE: State READY -> CONNECT
0000002053 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000002054 [ncp.at] TRACE: < OK
0000003058 [ncp.at] TRACE: > AT
0000003559 [ncp.at] TRACE: > AT
0000004045 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,u-blox AG - www.u-blox.com*4E
0000004047 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,HW UBX-M8030 00080000*60
0000004048 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,EXT CORE 3.01 (e3981c)*39
0000004050 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,ROM BASE 2.01 (75331)*19
0000004051 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,FWVER=UDR 1.31*40
0000004052 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,PROTVER=19.20*12
0000004053 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,MOD=NEO-M8U-0*7C
0000004054 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,FIS=0xEF4015 (200056)*59
0000004056 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,GPS;GLO;GAL;BDS*77
0000004057 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,SBAS;IMES;QZSS*49
0000004058 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,GNSS OTP=GPS;GLO*37
0000004060 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,LLC=FFFFFFFF-FFFFFFFF-FFFFFFFF-5FFFFBFE-FFFFFF
0000004061 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,ANTSUPERV=AC *00
0000004063 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,ANTSTATUS=DONTKNOW*2D
0000004064 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,PF=3BF*4F
0000004065 [app.gps.nmea] TRACE: RX: $GNRMC,,V,,,,,,,,1.32,E,N*16
0000004066 [app.gps.nmea] TRACE: RX: $GNVTG,,,,,,,,,N*2E
0000004067 [app.gps.nmea] TRACE: RX: $GNGGA,,,,,,0,00,99.99,,,,,,*56
0000004068 [app.gps.nmea] TRACE: RX: $GNGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*2E
0000004070 [app.gps.nmea] TRACE: RX: $GNGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*2E
0000004071 [app.gps.nmea] TRACE: RX: $GPGSV,1,1,00*79
0000004071 [app.gps.nmea] TRACE: RX: $GLGSV,1,1,00*65
0000004072 [app.gps.nmea] TRACE: RX: $GNGLL,,,,,,V,N*7A
0000004073 [app.gps.ubx] TRACE: TX:
0000004076 [app.gps.ubx] TRACE: RX:
0000004077 [app.gps.ubx] INFO: enable PUBX-POSITION
0000004077 [app.gps.ubx] TRACE: TX:
0000004082 [app.gps.ubx] TRACE: RX:
0000004083 [app.gps.ubx] INFO: enable PUBX-SVSTATUS
0000004084 [app.gps.ubx] TRACE: TX:
0000004086 [app.gps.ubx] TRACE: RX:
0000004086 [app.gps.ubx] INFO: enable PUBX-TIME
0000004087 [app.gps.ubx] TRACE: TX:
0000004089 [app.gps.ubx] TRACE: RX:
0000004089 [app.gps.ubx] TRACE: TX:
0000004091 [app.gps.ubx] TRACE: RX:
0000004092 [app.gps.ubx] TRACE: TX:
0000004095 [app.gps.ubx] TRACE: RX:
0000004095 [app.gps.ubx] TRACE: TX:
0000004097 [app.gps.ubx] TRACE: RX:
0000004098 [app.gps.ubx] TRACE: TX:
0000004100 [app.gps.ubx] TRACE: RX:
0000004101 [app.gps.ubx] TRACE: TX:
0000004103 [app.gps.ubx] TRACE: RX:
0000004103 [app.gps.ubx] TRACE: TX:
0000004105 [app.gps.ubx] TRACE: RX:
0000004106 [app.gps.ubx] TRACE: TX:
0000004108 [app.gps.ubx] TRACE: RX:
0000004109 [app.gps.ubx] TRACE: TX:
0000004111 [app.gps.ubx] TRACE: RX:
0000004111 [app.gps.ubx] TRACE: TX:
0000004113 [app.gps.ubx] TRACE: RX:
0000004114 [app.gps.ubx] TRACE: TX:
0000004116 [app.gps.ubx] TRACE: RX:
0000004117 [app.gps.ubx] INFO: enable GPS
0000004117 [app.gps.ubx] INFO: enable QZSS
0000004118 [app.gps.ubx] INFO: enable SBAS
0000004119 [app.gps.ubx] INFO: enable Galileo
0000004119 [app.gps.ubx] INFO: enable BeiDou
0000004120 [app.gps.ubx] INFO: enable GLONASS
0000004120 [app.gps.ubx] TRACE: TX:
0000004123 [app.gps.ubx] TRACE: RX:
0000004124 [app.gps.ubx] INFO: set to power management mode 0
0000004125 [app.gps.ubx] TRACE: TX:
0000004126 [app.gps.ubx] TRACE: RX:
0000004127 [app.gps.ubx] INFO: set dynamic platform model to 0
0000004128 [app.gps.ubx] TRACE: TX:
0000004130 [app.gps.ubx] TRACE: RX:
0000004133 [app] TRACE: waiting for stable GNSS lock for triggers
0000004233 [app] TRACE: waiting for stable GNSS lock for triggers
0000004233 [app] INFO: cellular is on
0000004492 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,ANTSTATUS=INIT*3B
0000004524 [app.gps.ubx] TRACE: RX:
0000004528 [app.gps.nmea] TRACE: RX: $PUBX,00,000000.98,0157.13623,S,03004.31707,E,1269.999,NF,1370
0000004529 [app.gps.nmea] TRACE: RX: $PUBX,03,00*1C
0000004531 [app.gps.nmea] TRACE: RX: $PUBX,04,000000.98,220320,0.98,2098,18,0,0.000,21*11
0000004533 [app.gps.ubx] TRACE: RX:
0000005084 [ncp.at] TRACE: > AT
0000005233 [app] TRACE: waiting for stable GNSS lock for triggers
0000005294 [app] INFO: Auto-connect disabled
0000005384 [hal] TRACE: Cached ESP32 NCP firmware version: 7
0000005495 [app.gps.nmea] TRACE: RX: $GNTXT,01,01,02,ANTSTATUS=OK*25
0000005585 [ncp.at] TRACE: > AT
0000005753 [app.gps.nmea] TRACE: RX: $PUBX,00,000002.00,0157.13623,S,03004.31707,E,1269.999,NF,1370
0000005806 [hal] TRACE: Cached ESP32 NCP firmware version: 7
0000006233 [app] TRACE: waiting for stable GNSS lock for triggers
0000006751 [app.gps.nmea] TRACE: RX: $PUBX,00,000003.00,0157.13623,S,03004.31707,E,1269.999,NF,1370
0000007089 [ncp.at] TRACE: > AT
0000007090 [ncp.at] TRACE: < OK
0000007091 [ncp.at] TRACE: > ATO
0000007094 [ncp.at] TRACE: > ATD*99***1#
0000007102 [net.ppp.client] TRACE: PPP phase -> 3
0000007102 [net.ppp.client] TRACE: PPP phase -> 6
0000007104 [ncp.at] TRACE: > AT
0000007106 [ncp.at] TRACE: < OK
0000007111 [net.ppp.client0000008233 [app] TRACE: waiting for stable GNSS lock for triggers
0000008751 [app.gps.nmea] TRACE: RX: $PUBX,00,000005.00,0157.13623,S,03004.31707,E,1269.999,NF,1370
0000009233 [app] TRACE: waiting for stable GNSS lock for triggers
0000009747 [app.gps.ubx] TRACE: RX:
0000009754 [app.gps.nmea] TRACE: RX: $PUBX,00,000006.00,0157.13623,S,03004.31707,E,1269.999,NF,1370
0000010233 [app] TRACE: waiting for stable GNSS lock for triggers
0000010752 [app.gps.nmea] TRACE: RX: $PUBX,00,000007.00,0157.13623,S,03004.31707,E,1269.999,NF,1371
0000011233 [app] TRACE: waiting for stable GNSS lock for triggers
0000011751 [app.gps.nmea] TRACE: RX: $PUBX,00,000008.00,0157.13623,S,03004.31707,E,1269.999,NF,1371
0000012233 [app] TRACE: waiting for stable GNSS lock for triggers
0000012755 [app.gps.nmea] TRACE: RX: $PUBX,00,000009.00,0157.13623,S,03004.31707,E,1269.999,NF,1371
0000013233 [app] TRACE: waiting for stable GNSS lock for triggers
0000013753 [app.gps.nmea] TRACE: RX: $PUBX,00,000010.00,0157.13623,S,03004.31707,E,1269.999,NF,1371
0000014233 [app] TRACE: waiting for stable GNSS lock for triggers
0000014751 [app.gps.ubx] TRACE: RX:
0000014757 [app.gps.nmea] TRACE: RX: $PUBX,00,000011.00,0157.13623,S,03004.31707,E,1269.999,NF,1372
0000014760 [app.gps.ubx] TRACE: RX:
0000015233 [app] TRACE: waiting for stable GNSS lock for triggers
0000015755 [app.gps.nmea] TRACE: RX: $PUBX,00,000012.00,0157.13623,S,03004.31707,E,1269.999,NF,1372
0000016233 [app] TRACE: waiting for stable GNSS lock for triggers
0000016756 [app.gps.nmea] TRACE: RX: $PUBX,00,000013.00,0157.13623,S,03004.31707,E,1269.999,NF,1373
0000017233 [app] TRACE: waiting for stable GNSS lock for triggers
0000017757 [app.gps.nmea] TRACE: RX: $PUBX,00,000014.00,0157.13623,S,03004.31707,E,1269.999,NF,1374
0000018233 [app] TRACE: waiting for stable GNSS lock for triggers
0000018756 [app.gps.nmea] TRACE: RX: $PUBX,00,000015.00,0157.13623,S,03004.31707,E,1269.999,NF,1375
0000019233 [app] TRACE: waiting for stable GNSS lock for triggers
0000019753 [app.gps.ubx] TRACE: RX:
0000019759 [app.gps.nmea] TRACE: RX: $PUBX,00,000016.00,0157.13623,S,03004.31707,E,1269.999,NF,1375
0000020233 [app] TRACE: waiting for stable GNSS lock for triggers
0000020756 [app.gps.nmea] TRACE: RX: $PUBX,00,000017.00,0157.13623,S,03004.31707,E,1269.999,NF,1376
0000021233 [app] TRACE: waiting for stable GNSS lock for triggers
0000021755 [app.gps.nmea] TRACE: RX: $PUBX,00,000018.00,0157.13623,S,03004.31707,E,1269.999,NF,1378
0000022233 [app] TRACE: waiting for stable GNSS lock for triggers
0000022757 [app.gps.nmea] TRACE: RX: $PUBX,00,000019.00,0157.13623,S,03004.31707,E,1269.999,NF,1379
0000023233 [app] TRACE: waiting for stable GNSS lock for triggers
0000023756 [app.gps.nmea] TRACE: RX: $PUBX,00,000020.00,0157.13623,S,03004.31707,E,1269.999,NF,1380
0000024233 [app] TRACE: waiting for stable GNSS lock for triggers
0000024749 [app.gps.ubx] TRACE: RX:
0000024757 [app.gps.nmea] TRACE: RX: $PUBX,00,000021.00,0157.13623,S,03004.31707,E,1269.999,NF,1382
0000024761 [app.gps.ubx] TRACE: RX:
0000025233 [app] TRACE: waiting for stable GNSS lock for triggers
0000025757 [app.gps.nmea] TRACE: RX: $PUBX,00,000022.00,0157.13623,S,03004.31707,E,1269.999,NF,1384
0000026233 [app] TRACE: waiting for stable GNSS lock for triggers
0000026755 [app.gps.nmea] TRACE: RX: $PUBX,00,000023.00,0157.13623,S,03004.31707,E,1269.999,NF,1386
0000027233 [app] TRACE: waiting for stable GNSS lock for triggers
0000027756 [app.gps.nmea] TRACE: RX: $PUBX,00,000024.00,0157.13623,S,03004.31707,E,1269.999,NF,1388
0000028233 [app] TRACE: waiting for stable GNSS lock for triggers
0000028757 [app.gps.nmea] TRACE: RX: $PUBX,00,000025.00,0157.13623,S,03004.31707,E,1269.999,NF,1390
0000029233 [app] TRACE: waiting for stable GNSS lock for triggers
0000029750 [app.gps.ubx] TRACE: RX:
0000029754 [app.gps.nmea] TRACE: RX: $PUBX,00,000026.00,0157.13623,S,03004.31707,E,1269.999,NF,1392
0000030233 [app] TRACE: waiting for stable GNSS lock for triggers
0000030756 [app.gps.nmea] TRACE: RX: $PUBX,00,000027.00,0157.13623,S,03004.31707,E,1269.999,NF,1395
0000031233 [app] TRACE: waiting for stable GNSS lock for triggers
0000031757 [app.gps.nmea] TRACE: RX: $PUBX,00,000028.00,0157.13623,S,03004.31707,E,1269.999,NF,1398
0000032233 [app] TRACE: waiting for stable GNSS lock for triggers
0000032757 [app.gps.nmea] TRACE: RX: $PUBX,00,000029.00,0157.13623,S,03004.31707,E,1269.999,NF,1400
0000033233 [app] TRACE: waiting for stable GNSS lock for triggers
0000033756 [app.gps.nmea] TRACE: RX: $PUBX,00,000030.00,0157.13623,S,03004.31707,E,1269.999,NF,1404
0000034233 [app] TRACE: waiting for stable GNSS lock for triggers
0000034751 [app.gps.ubx] TRACE: RX:
0000034757 [app.gps.nmea] TRACE: RX: $PUBX,00,000031.00,0157.13623,S,03004.31707,E,1269.999,NF,1407
0000034759 [app.gps.nmea] TRACE: RX: $PUBX,03,00*1C
0000034763 [app.gps.nmea] TRACE: RX: $PUBX,04,000031.00,220320,31.00,2098,18,0,0.000,21*21
0000034767 [app.gps.ubx] TRACE: RX:
0000035233 [app] TRACE: waiting for stable GNSS lock for triggers
0000035757 [app.gps.nmea] TRACE: RX: $PUBX,00,000032.00,0157.13623,S,03004.31707,E,1269.999,NF,1411
0000036233 [app] TRACE: waiting for stable GNSS lock for triggers
0000036755 [app.gps.nmea] TRACE: RX: $PUBX,00,000033.00,0157.13623,S,03004.31707,E,1269.999,NF,1414
0000037233 [app] TRACE: waiting for stable GNSS lock for triggers
0000037757 [app.gps.nmea] TRACE: RX: $PUBX,00,000034.00,0157.13623,S,03004.31707,E,1269.999,NF,1418
0000038233 [app] TRACE: waiting for stable GNSS lock for triggers
0000038756 [app.gps.nmea] TRACE: RX: $PUBX,00,000035.00,0157.13623,S,03004.31707,E,1269.999,NF,1423
0000039233 [app] TRACE: waiting for stable GNSS lock for triggers
0000039751 [app.gps.ubx] TRACE: RX:
0000039755 [app.gps.nmea] TRACE: RX: $PUBX,00,000036.00,0157.13623,S,03004.31707,E,1269.999,NF,1427
0000040233 [app] TRACE: waiting for stable GNSS lock for triggers
0000040755 [app.gps.nmea] TRACE: RX: $PUBX,00,000037.00,0157.13623,S,03004.31707,E,1269.999,NF,1432
0000041233 [app] TRACE: waiting for stable GNSS lock for triggers
0000041756 [app.gps.nmea] TRACE: RX: $PUBX,00,000038.00,0157.13623,S,03004.31707,E,1269.999,NF,1437
0000042233 [app] TRACE: waiting for stable GNSS lock for triggers
0000042756 [app.gps.nmea] TRACE: RX: $PUBX,00,000039.00,0157.13623,S,03004.31707,E,1269.999,NF,1442
0000043233 [app] TRACE: waiting for stable GNSS lock for triggers
0000043757 [app.gps.nmea] TRACE: RX: $PUBX,00,000040.00,0157.13623,S,03004.31707,E,1269.999,NF,1448
0000044233 [app] TRACE: waiting for stable GNSS lock for triggers
0000044754 [app.gps.ubx] TRACE: RX:
0000044762 [app.gps.nmea] TRACE: RX: $PUBX,00,000041.00,0157.13623,S,03004.31707,E,1269.999,NF,1453
0000044765 [app.gps.ubx] TRACE: RX:
0000045233 [app] TRACE: waiting for stable GNSS lock for triggers
0000045758 [app.gps.nmea] TRACE: RX: $PUBX,00,000042.00,0157.13623,S,03004.31707,E,1269.999,NF,1459
0000046233 [app] TRACE: waiting for stable GNSS lock for triggers
0000046756 [app.gps.nmea] TRACE: RX: $PUBX,00,000043.00,0157.13623,S,03004.31707,E,1269.999,NF,1466
0000047233 [app] TRACE: waiting for stable GNSS lock for triggers
0000047757 [app.gps.nmea] TRACE: RX: $PUBX,00,000044.00,0157.13623,S,03004.31707,E,1269.999,NF,1472
0000048233 [app] TRACE: waiting for stable GNSS lock for triggers
0000048760 [app.gps.nmea] TRACE: RX: $PUBX,00,000045.00,0157.13623,S,03004.31707,E,1269.999,NF,1479
0000049233 [app] TRACE: waiting for stable GNSS lock for triggers
0000049755 [app.gps.ubx] TRACE: RX:
0000049761 [app.gps.nmea] TRACE: RX: $PUBX,00,000046.00,0157.13623,S,03004.31707,E,1269.999,NF,1486
0000050233 [app] TRACE: waiting for stable GNSS lock for triggers
0000050761 [app.gps.nmea] TRACE: RX: $PUBX,00,000047.00,0157.13623,S,03004.31707,E,1269.999,NF,1494
0000051233 [app] TRACE: waiting for stable GNSS lock for triggers
0000051762 [app.gps.nmea] TRACE: RX: $PUBX,00,000048.00,0157.13623,S,03004.31707,E,1269.999,NF,1501
0000052233 [app] TRACE: waiting for stable GNSS lock for triggers
0000052760 [app.gps.nmea] TRACE: RX: $PUBX,00,000049.00,0157.13623,S,03004.31707,E,1269.999,NF,1509
0000053233 [app] TRACE: waiting for stable GNSS lock for triggers
0000053773 [app.gps.nmea] TRACE: RX: $PUBX,00,092317.54,0157.13623,S,03004.31707,E,1269.999,NF,1485
0000054173 [app.gps.ubx] TRACE: RX:
0000054177 [app.gps.nmea] TRACE: RX: $PUBX,00,092318.00,0157.13623,S,03004.31707,E,1269.999,NF,1485
0000054179 [app.gps.ubx] TRACE: RX:
0000054233 [app] TRACE: waiting for stable GNSS lock for triggers
0000055233 [app] TRACE: waiting for stable GNSS lock for triggers
0000055399 [app.gps.nmea] TRACE: RX: $PUBX,00,092319.00,0157.13623,S,03004.31707,E,1269.999,NF,1486
0000056233 [app] TRACE: waiting for stable GNSS lock for triggers
0000056480 [app.gps.nmea] TRACE: RX: $PUBX,00,092320.00,0157.13623,S,03004.31707,E,1269.999,NF,1487
0000057233 [app] TRACE: waiting for stable GNSS lock for triggers
0000057460 [app.gps.nmea] TRACE: RX: $PUBX,00,092321.00,0157.13623,S,03004.31707,E,1269.999,NF,1488
0000058233 [app] TRACE: waiting for stable GNSS lock for triggers
0000058457 [app.gps.nmea] TRACE: RX: $PUBX,00,092322.00,0157.13623,S,03004.31707,E,1269.999,NF,1489
0000059233 [app] TRACE: waiting for stable GNSS lock for triggers
0000059448 [app.gps.ubx] TRACE: RX:
0000059455 [app.gps.nmea] TRACE: RX: $PUBX,00,092323.00,0157.13623,S,03004.31707,E,1269.999,NF,1491
0000060233 [app] TRACE: waiting for stable GNSS lock for triggers
0000060450 [app.gps.nmea] TRACE: RX: $PUBX,00,092324.00,0157.13623,S,03004.31707,E,1269.999,NF,1493
0000061233 [app] TRACE: waiting for stable GNSS lock for triggers
0000061454 [app.gps.nmea] TRACE: RX: $PUBX,00,092325.00,0157.13623,S,03004.31707,E,1269.999,NF,1495
0000062233 [app] TRACE: waiting for stable GNSS lock for triggers
0000062462 [app.gps.nmea] TRACE: RX: $PUBX,00,092326.00,0157.13623,S,03004.31707,E,1269.999,NF,1498
0000063233 [app] TRACE: waiting for stable GNSS lock for triggers
0000063447 [app.gps.nmea] TRACE: RX: $PUBX,00,092327.00,0157.13623,S,03004.31707,E,1269.999,NF,1501
0000064233 [app] TRACE: waiting for stable GNSS lock for triggers
0000064444 [app.gps.ubx] TRACE: RX:
0000064452 [app.gps.nmea] TRACE: RX: $PUBX,00,092328.00,0157.13623,S,03004.31707,E,1269.999,NF,1504
0000064464 [app.gps.nmea] TRACE: RX: $PUBX,03,11,1,-,167,64,24,000,7,-,,,28,012,8,-,148,13,,000,9,e
0000064468 [app.gps.nmea] TRACE: RX: $PUBX,04,092328.00,031122,379408.00,2234,18,875079,-488.826,21
0000064472 [app.gps.ubx] TRACE: RX:
0000065233 [app] TRACE: waiting for stable GNSS lock for triggers
0000065456 [app.gps.nmea] TRACE: RX: $PUBX,00,092329.00,0157.13623,S,03004.31707,E,1269.999,NF,1508
0000066233 [app] TRACE: waiting for stable GNSS lock for triggers
0000066325 [app.gps.nmea] TRACE: RX: $PUBX,00,092330.00,0157.13623,S,03004.31707,E,1269.999,NF,1512
0000067233 [app] TRACE: waiting for stable GNSS lock for triggers
0000067277 [app.gps.nmea] TRACE: RX: $PUBX,00,092331.00,0157.13623,S,03004.31707,E,1269.999,NF,1516
0000068233 [app] TRACE: waiting for stable GNSS lock for triggers
0000068283 [app.gps.nmea] TRACE: RX: $PUBX,00,092332.00,0157.13623,S,03004.31707,E,1269.999,NF,1521
0000069233 [app] TRACE: waiting for stable GNSS lock for triggers
0000069278 [app.gps.ubx] TRACE: RX:
0000069285 [app.gps.nmea] TRACE: RX: $PUBX,00,092333.00,0157.13623,S,03004.31707,E,1269.999,NF,1526
0000070233 [app] TRACE: waiting for stable GNSS lock for triggers
0000070282 [app.gps.nmea] TRACE: RX: $PUBX,00,092334.00,0157.13623,S,03004.31707,E,1269.999,NF,1532
0000071233 [app] TRACE: waiting for stable GNSS lock for triggers
0000071300 [app.gps.nmea] TRACE: RX: $PUBX,00,092335.00,0157.13623,S,03004.31707,E,1269.999,NF,1537
0000072233 [app] TRACE: waiting for stable GNSS lock for triggers
0000072294 [app.gps.nmea] TRACE: RX: $PUBX,00,092336.00,0157.13623,S,03004.31707,E,1269.999,NF,1543
0000073233 [app] TRACE: waiting for stable GNSS lock for triggers
0000073295 [app.gps.nmea] TRACE: RX: $PUBX,00,092337.00,0157.13623,S,03004.31707,E,1269.999,NF,1550
0000074233 [app] TRACE: waiting for stable GNSS lock for triggers
0000074358 [app.gps.ubx] TRACE: RX:
0000074364 [app.gps.nmea] TRACE: RX: $PUBX,00,092338.00,0157.11022,S,03004.33135,E,1441.699,NF,97,8
0000074368 [app.gps.ubx] TRACE: RX:
0000075233 [app] TRACE: waiting for stable GNSS lock for triggers
0000075288 [app.gps.nmea] TRACE: RX: $PUBX,00,092339.00,0157.11039,S,03004.33140,E,1440.726,G3,53,5
0000076233 [app] TRACE: waiting for stable GNSS lock for triggers
0000076320 [app.gps.nmea] TRACE: RX: $PUBX,00,092340.00,0157.10965,S,03004.33172,E,1439.480,G3,57,5
0000077233 [app] TRACE: waiting for stable GNSS lock for triggers
0000077307 [app.gps.nmea] TRACE: RX: $PUBX,00,092341.00,0157.10934,S,03004.33189,E,1438.666,G3,51,4
0000078233 [app] TRACE: waiting for stable GNSS lock for triggers
0000078330 [app.gps.nmea] TRACE: RX: $PUBX,00,092342.00,0157.10913,S,03004.33213,E,1438.781,G3,47,4
0000079233 [app] TRACE: waiting for stable GNSS lock for triggers
0000079290 [app.gps.ubx] TRACE: RX:
0000079301 [app.gps.nmea] TRACE: RX: $PUBX,00,092343.00,0157.10912,S,03004.33233,E,1438.659,G3,44,3
0000080233 [app] TRACE: waiting for stable GNSS lock for triggers
0000080322 [app.gps.nmea] TRACE: RX: $PUBX,00,092344.00,0157.10897,S,03004.33264,E,1437.209,G3,41,3
0000081233 [app] TRACE: waiting for stable GNSS lock for triggers
0000081311 [app.gps.nmea] TRACE: RX: $PUBX,00,092345.00,0157.10884,S,03004.33277,E,1437.080,G3,39,3
0000082233 [app] TRACE: waiting for stable GNSS lock for triggers
0000082335 [app.gps.nmea] TRACE: RX: $PUBX,00,092346.00,0157.10889,S,03004.33289,E,1437.539,G3,37,3
0000083233 [app] TRACE: waiting for stable GNSS lock for triggers
0000083297 [app.gps.nmea] TRACE: RX: $PUBX,00,092347.00,0157.10887,S,03004.33294,E,1437.940,G3,35,3
0000084233 [app] TRACE: waiting for stable GNSS lock for triggers
0000084313 [app.gps.ubx] TRACE: RX:
0000084333 [app.gps.nmea] TRACE: RX: $PUBX,00,092348.00,0157.10882,S,03004.33297,E,1438.163,G3,34,2
0000084342 [app.gps.ubx] TRACE: RX:
0000085233 [app] TRACE: waiting for stable GNSS lock for triggers
0000085310 [app.gps.nmea] TRACE: RX: $PUBX,00,092349.00,0157.10885,S,03004.33313,E,1437.555,G3,32,2
0000086233 [app] TRACE: waiting for stable GNSS lock for triggers
0000086343 [app.gps.nmea] TRACE: RX: $PUBX,00,092350.00,0157.10893,S,03004.33317,E,1437.456,G3,31,2
0000087233 [app] TRACE: waiting for stable GNSS lock for triggers
0000087292 [app.gps.nmea] TRACE: RX: $PUBX,00,092351.00,0157.10893,S,03004.33336,E,1437.213,G3,30,2
0000088233 [app] TRACE: waiting for stable GNSS lock for triggers
0000088322 [app.gps.nmea] TRACE: RX: $PUBX,00,092352.00,0157.10900,S,03004.33352,E,1436.441,G3,29,2
0000089233 [app] TRACE: waiting for stable GNSS lock for triggers
0000089279 [app.gps.ubx] TRACE: RX:
0000089298 [app.gps.nmea] TRACE: RX: $PUBX,00,092353.00,0157.10898,S,03004.33370,E,1436.222,G3,29,2
0000090233 [app] TRACE: publishing from triggers
0000090320 [app.gps.nmea] TRACE: RX: $PUBX,00,092354.00,0157.10896,S,03004.33377,E,1436.376,G3,28,2
0000091000 [app] TRACE: publishing timed out and transitioning to EXECUTE
0000091233 [app] TRACE: evaluatePublish pending_immediate
0000091233 [app] TRACE: publishing from immediate
0000091302 [app.gps.nmea] TRACE: RX: $PUBX,00,092355.00,0157.10894,S,03004.33390,E,1435.934,G3,27,2
0000092233 [app] TRACE: publishing from triggers
0000092344 [app.gps.nmea] TRACE: RX: $PUBX,00,092356.00,0157.10892,S,03004.33394,E,1435.949,G3,27,2
0000093233 [app] TRACE: publishing from triggers
0000093301 [app.gps.nmea] TRACE: RX: $PUBX,00,092357.00,0157.10890,S,03004.33399,E,1436.087,G3,26,2
0000094233 [app] TRACE: publishing from triggers
0000094327 [app.gps.ubx] TRACE: RX:
0000094337 [app.gps.nmea] TRACE: RX: $PUBX,00,092358.00,0157.10893,S,03004.33414,E,1435.383,G3,25,2
0000094357 [app.gps.nmea] TRACE: RX: $PUBX,03,12,1,-,167,64,20,000,7,U,248,66,31,042,8,-,147,12,,00
0000094363 [app.gps.nmea] TRACE: RX: $PUBX,04,092358.00,031122,379438.00,2234,18,859751,-551.372,21
0000094368 [app.gps.ubx] TRACE: RX:
0000095233 [app] TRACE: publishing from triggers
0000095312 [app.gps.nmea] TRACE: RX: $PUBX,00,092359.00,0157.10892,S,03004.33416,E,1435.116,G3,25,2
0000096233 [app] TRACE: publishing from triggers
0000096345 [app.gps.nmea] TRACE: RX: $PUBX,00,092400.00,0157.10886,S,03004.33401,E,1435.409,G3,24,2
0000097233 [app] TRACE: publishing from triggers
0000097317 [app.gps.nmea] TRACE: RX: $PUBX,00,092401.00,0157.10877,S,03004.33394,E,1435.469,G3,24,2
0000098233 [app] TRACE: publishing from triggers
0000098341 [app.gps.nmea] TRACE: RX: $PUBX,00,092402.00,0157.10878,S,03004.33397,E,1435.170,G3,24,1
0000099233 [app] TRACE: publishing from triggers
0000099360 [app.gps.ubx] TRACE: RX:
0000099380 [app.gps.nmea] TRACE: RX: $PUBX,00,092403.00,0157.10876,S,03004.33413,E,1434.795,RK,22,1
0000100233 [app] TRACE: publishing from triggers
0000100383 [app.gps.nmea] TRACE: RX: $PUBX,00,092404.00,0157.10880,S,03004.33428,E,1434.973,RK,22,1
0000101233 [app] TRACE: publishing from triggers
0000101359 [app.gps.nmea] TRACE: RX: $PUBX,00,092405.00,0157.10880,S,03004.33428,E,1434.889,RK,22,1
0000102233 [app] TRACE: publishing from triggers
0000102377 [app.gps.nmea] TRACE: RX: $PUBX,00,092406.00,0157.10880,S,03004.33436,E,1435.052,RK,22,1
0000103233 [app] TRACE: publishing from triggers
0000103354 [app.gps.nmea] TRACE: RX: $PUBX,00,092407.00,0157.10881,S,03004.33445,E,1435.229,RK,21,1
0000104233 [app] TRACE: publishing from triggers
0000104389 [app.gps.ubx] TRACE: RX:
0000104409 [app.gps.nmea] TRACE: RX: $PUBX,00,092408.00,0157.10881,S,03004.33456,E,1435.341,RK,21,1
0000104417 [app.gps.ubx] TRACE: RX:
0000105233 [app] TRACE: publishing from triggers
0000105381 [app.gps.nmea] TRACE: RX: $PUBX,00,092409.00,0157.10882,S,03004.33467,E,1435.353,RK,21,1
0000106233 [app] TRACE: publishing from triggers
0000106409 [app.gps.nmea] TRACE: RX: $PUBX,00,092410.00,0157.10882,S,03004.33479,E,1435.336,RK,21,1
0000107233 [app] TRACE: publishing from triggers
0000107402 [app.gps.nmea] TRACE: RX: $PUBX,00,092411.00,0157.10881,S,03004.33481,E,1435.433,RK,20,1
0000108233 [app] TRACE: publishing from triggers
0000108406 [app.gps.nmea] TRACE: RX: $PUBX,00,092412.00,0157.10879,S,03004.33488,E,1435.516,RK,20,1
0000109233 [app] TRACE: publishing from triggers
0000109365 [app.gps.ubx] TRACE: RX:
0000109375 [app.gps.nmea] TRACE: RX: $PUBX,00,092413.00,0157.10877,S,03004.33498,E,1435.695,RK,20,1
0000110233 [app] TRACE: publishing from triggers
0000110367 [app.gps.nmea] TRACE: RX: $PUBX,00,092414.00,0157.10878,S,03004.33497,E,1435.694,DR,20,1
0000111233 [app] TRACE: publishing from triggers
0000111365 [app.gps.nmea] TRACE: RX: $PUBX,00,092415.00,0157.10878,S,03004.33497,E,1435.694,DR,20,1
0000112233 [app] TRACE: publishing from triggers
0000112366 [app.gps.nmea] TRACE: RX: $PUBX,00,092416.00,0157.10878,S,03004.33497,E,1435.692,DR,20,1
0000113233 [app] TRACE: publishing from triggers
0000113408 [app.gps.nmea] TRACE: RX: $PUBX,00,092417.00,0157.10878,S,03004.33500,E,1435.791,RK,20,1
0000114233 [app] TRACE: publishing from triggers
0000114374 [app.gps.ubx] TRACE: RX:
0000114384 [app.gps.nmea] TRACE: RX: $PUBX,00,092418.00,0157.10880,S,03004.33410,E,1436.102,RK,19,1
0000114389 [app.gps.ubx] TRACE: RX:
0000115233 [app] TRACE: publishing from triggers
0000115407 [app.gps.nmea] TRACE: RX: $PUBX,00,092419.00,0157.10881,S,03004.33334,E,1436.331,RK,19,1
0000116233 [app] TRACE: publishing from triggers
0000116413 [app.gps.nmea] TRACE: RX: $PUBX,00,092420.00,0157.10881,S,03004.33185,E,1436.873,RK,18,1
0000117233 [app] TRACE: publishing from triggers
0000117422 [app.gps.nmea] TRACE: RX: $PUBX,00,092421.00,0157.10880,S,03004.33082,E,1437.301,RK,16,1
0000118233 [app] TRACE: waiting for stable GNSS lock for triggers
0000118406 [app.gps.nmea] TRACE: RX: $PUBX,00,092422.00,0157.10883,S,03004.33012,E,1437.787,RK,16,1
0000119233 [app] TRACE: waiting for stable GNSS lock for triggers
0000119391 [app.gps.ubx] TRACE: RX:
0000119412 [app.gps.nmea] TRACE: RX: $PUBX,00,092423.00,0157.10884,S,03004.32958,E,1438.198,RK,15,1
0000120233 [app] TRACE: waiting for stable GNSS lock for triggers
0000120386 [app.gps.nmea] TRACE: RX: $PUBX,00,092424.00,0157.10883,S,03004.32922,E,1438.506,RK,14,1
0000121233 [app] TRACE: waiting for stable GNSS lock for triggers
0000121400 [app.gps.nmea] TRACE: RX: $PUBX,00,092425.00,0157.10882,S,03004.32892,E,1438.836,RK,14,1
0000122233 [app] TRACE: waiting for stable GNSS lock for triggers
0000122377 [app.gps.nmea] TRACE: RX: $PUBX,00,092426.00,0157.10881,S,03004.32872,E,1439.085,RK,13,1
0000123233 [app] TRACE: waiting for stable GNSS lock for triggers
0000123393 [app.gps.nmea] TRACE: RX: $PUBX,00,092427.00,0157.10879,S,03004.32855,E,1439.285,RK,13,1
0000124233 [app] TRACE: waiting for stable GNSS lock for triggers
0000124359 [app.gps.ubx] TRACE: RX:
0000124379 [app.gps.nmea] TRACE: RX: $PUBX,00,092428.00,0157.10879,S,03004.32843,E,1439.488,RK,13,1
0000124421 [app.gps.nmea] TRACE: RX: $PUBX,03,12,1,-,167,64,24,000,7,U,248,66,31,064,8,-,147,12,19,
0000124435 [app.gps.nmea] TRACE: RX: $PUBX,04,092428.00,031122,379468.00,2234,18,842178,-606.298,21
0000124443 [app.gps.ubx] TRACE: RX:
0000125233 [app] TRACE: publishing from triggers
0000125390 [app.gps.nmea] TRACE: RX: $PUBX,00,092429.00,0157.10876,S,03004.32832,E,1439.594,RK,12,1
0000126233 [app] TRACE: publishing from triggers
0000126374 [app.gps.nmea] TRACE: RX: $PUBX,00,092430.00,0157.10875,S,03004.32821,E,1439.750,RK,12,1
0000127233 [app] TRACE: publishing from triggers
0000127393 [app.gps.nmea] TRACE: RX: $PUBX,00,092431.00,0157.10874,S,03004.32815,E,1439.982,RK,12,1
0000128233 [app] TRACE: publishing from triggers
0000128362 [app.gps.nmea] TRACE: RX: $PUBX,00,092432.00,0157.10872,S,03004.32807,E,1440.129,RK,11,1
0000129233 [app] TRACE: waiting for stable GNSS lock for triggers
0000129390 [app.gps.ubx] TRACE: RX:
0000129410 [app.gps.nmea] TRACE: RX: $PUBX,00,092433.00,0157.10871,S,03004.32801,E,1440.367,RK,11,1
0000130233 [app] TRACE: publishing from triggers
0000130364 [app.gps.nmea] TRACE: RX: $PUBX,00,092434.00,0157.10871,S,03004.32793,E,1440.508,RK,11,1
0000131233 [app] TRACE: publishing from triggers
0000131392 [app.gps.nmea] TRACE: RX: $PUBX,00,092435.00,0157.10872,S,03004.32785,E,1440.723,RK,11,1
0000132233 [app] TRACE: publishing from triggers
0000132360 [app.gps.nmea] TRACE: RX: $PUBX,00,092436.00,0157.10873,S,03004.32777,E,1440.910,RK,11,1
0000133234 [app] TRACE: publishing from triggers
0000133379 [app.gps.nmea] TRACE: RX: $PUBX,00,092437.00,0157.10871,S,03004.32768,E,1441.075,RK,10,1
0000134234 [app] TRACE: publishing from triggers
0000134341 [app.gps.ubx] TRACE: RX:
0000134361 [app.gps.nmea] TRACE: RX: $PUBX,00,092438.00,0157.10868,S,03004.32758,E,1441.266,RK,10,1
0000134368 [app.gps.ubx] TRACE: RX:
0000135234 [app] TRACE: publishing from triggers
0000135375 [app.gps.nmea] TRACE: RX: $PUBX,00,092439.00,0157.10869,S,03004.32751,E,1441.524,RK,10,1
0000136234 [app] TRACE: publishing from triggers
@no1089 , @Colleen and/or @rickkas7 in case you can provide assistance here.
Thanks @gusgonnet.
@thomharv we’re looking into it - the logs are not what I’d generally expect to see.
@thomharv/@djamimat can you please create a support ticket for this issue? Thanks!
@Colleen done! Thanks
A post was split to a new topic: B524 blinking green
