Timer with Publish happens only once but expected repeat
See below code. This is supposed to send a test message periodically using the Timer, but it only does so once. The LED blink that accompanies the publish only occurs once as well. Thanks!
int boardLed = D7;
void sendHeartbeat() {
  blinkLed(3, 200);
  Particle.publish("bethesda_labs_heartbeat", "up");
Timer timer(1000 * 10, sendHeartbeat);
    timer.start();
    pinMode(boardLed, OUTPUT);
void blinkLed(int n, int t) {
    for(int i = 1; i <= n; i++) {
      digitalWrite(boardLed, HIGH);
      delay(t);
      digitalWrite(boardLed, LOW);
      delay(t);
For me this works just as expected
Thanks, that’s strange.
Well, I have since refactored it to set a flag in the timer function rather than publish, and it works.
int boardLed = D7;
boolean publishFlag = true;
void triggerHeartbeat() {
  publishFlag = true;
Timer timer(1000 * 10, triggerHeartbeat);
    timer.start();
    blinkLed(3, 200);
  if (publishFlag) {
    blinkLed(3, 200);
    publishFlag = false;
      delay(t);
      delay(t);
You should think about Timer callback like an interrupt service routine; very little should happen inside that function. You have placed some blocky code in there. I’d look to write non-blocking methods for that blinking.
Even if that isn’t responsible for the problem you are seeing, it could factor. I suspect this is a component of a larger program.
thanks!
