Hi everyone,
I want to turn on/off the onboard-LED (D7) with a function from outside. If the LED is turned on, a timer is started, which turns off the LED after 10 seconds (timer-function).
If turned on an event is fired with “LED/7 on”.
If turned off an event is fired with “LED/7 off”.
Here is the problem: Turning on works fine with the following event “LED/7 on” and the serial output
LED: on
Event: 1
After the timer is fired, the LED is automatically turned off, but there is no event “LED/7 off” in the stream and the serial output is
LED: off
Event: 0
The line “Event: 0” means, that the event is not successfully fired (to the cloud).
Strange thing: The LED is turned off, the serial output appears, the device (photon) disconnect and reconnects and the event is lost.
Does anyone has an idea how find/fix the error?
Sandy
#define SECURITY_TIMEOUT 10000
int ledState = LOW;
Timer t = Timer(SECURITY_TIMEOUT, &turnOffLED, true);
pinMode(D7, OUTPUT);
Particle.function("TurnLED", turnLED);
Particle.variable("D7", ledState);
// nop
void changeLEDState(int pin, int state) {
digitalWrite(pin, state);
refreshLEDState();
String mode = digitalRead(pin) ? "on" : "off";
Serial.println("LED: " + mode);
Serial.println("Event: " + String(Particle.publish("LED/7 ", mode, PUBLIC)));
if(state) {
t.start();
} else {
t.stop();
int turnLED(String dummy) {
int state = digitalRead(D7);
changeLEDState(D7, !state);
return 1;
void turnOffLED() {changeLEDState(D7, LOW);}
void refreshLEDState() {
ledState = digitalRead(D7);
