I am attempting to use serial commands to start and stop a timer that prints ADC values at a sampling rate of 500 Hz using the code below. A ‘1’ will start the timer and turn on an LED. a ‘2’ will stop the timer and turn off the same LED.
int val0 = 0; // variable to store the read value
int val1 = 0;
int val2 = 0;
int count = 0;
char inByte;
void Hertz()
count++;
val0 = analogRead(A0); // read the input pin
//val1 = analogRead(A1);
//val2 = analogRead(A2);
Serial1.println(count);
Serial1.println(val0);
//Serial1.println(val1);
//Serial1.println(val2);
Timer timer(2, Hertz); // 500 Hz
Serial1.begin(38400);
Serial1.println("***redacted***");
pinMode(D7, OUTPUT);
setADCSampleTime(ADC_SampleTime_3Cycles);
void serialEvent1()
if (Serial1.available())
char inByte = Serial1.read();
if (inByte == '1'){
digitalWrite(D7, HIGH); //turn LED on
Serial1.println(Time.now()); //unix time stamp
timer.start();
if(inByte == '2'){
digitalWrite(D7, LOW); //turn LED off
timer.stop();
count = 0;
void loop(){
serialEvent1();
The timer will start fine, but the timer will not stop once i send the stop command (a serial char ‘2’). However, the Particle Photon that I am using will still turn the LED off and reset the variable “count,” but won’t stop the timer. After playing around with some timer.changePeriod() and delay() function inserted in various places within the code, I am fairly certain that it is a priority issue with the timer actually interrupting the very call that’s supposed to stop it- having a ‘2’ as the timer’s input sets the timer to interrupt every 2 milliseconds, so somewhat fast. I am fairly knowledgeable on priority timing dependencies/interrupts, but cannot seem to solve this issue. I would very much appreciate any information or advice pertaining to getting my timer.stop() function to call. Thanks!
