I have a simple program which utilizes a software timer. I don’t understand why the device restarts every time the timer expires. Thoughts?
Here’s the code:
//Strobe Light Control
//C Thomas Morrison
//20190829
//Let's use an external antenna if it one is connected
STARTUP(WiFi.selectAntenna(ANT_AUTO));
#define __FILENAME__ (strrchr(__FILE__, '/') ? strrchr(__FILE__, '/') + 1 : __FILE__)
retained int onSeconds = 900; //number of seconds to run strobe light
retained int onMilliseconds = onSeconds * 1000; //number of milliseconds to run strobe light
int strobe = D5; //output used for strobe light
char gDeviceInfo [200];
//Required for the timer function
void callstopOutput () {
stopOutput("fred");
Timer t(onMilliseconds,callstopOutput); //one shot timer used to stop strobe light
//Serial.println("we're trying to sync the device's time");
while(Time.year() <= 1970) Particle.process();
//Publishes info about the device
snprintf(gDeviceInfo, sizeof(gDeviceInfo)
,"Application: %s, Date: %s, Time: %s, System firmware: %s, SSID: %s"
,__FILENAME__
,__DATE__
,__TIME__
,(const char*)System.version() // cast required for String
,(const char*)WiFi.SSID() // cast not required but always safe when in doubt if String or char*
//,WiFi.RSSI()
Particle.variable("deviceInfo",gDeviceInfo);
Particle.variable("onSeconds",onSeconds);
Particle.function("pReset",pReset);
Particle.function("startStrobe",startOutput);
Particle.function("stopStrobe",stopOutput);
Particle.function("setOnPeriod",setOnPeriod);
Particle.function("getStrobeState",getStrobeState);
pinMode(strobe, OUTPUT);
//nothing needed in here
int startOutput (String command) {
t.reset(); //reset and start the timer to automatically shut off the filler
digitalWrite(strobe,1);
Particle.publish("Started strobe",NULL,60,PRIVATE);
return 1;
int stopOutput (String command) {
digitalWrite(strobe,0);
t.stop();
Particle.publish("Stopped strobe",NULL,60,PRIVATE);
return 1;
int pReset(String command) {
//function to call to remotely reset Photon
Particle.publish("strobe control reset",NULL,60,PRIVATE);
System.reset();
return 1;
int getStrobeState(String command) {
int _state = digitalRead(strobe);
if (_state==0){
Particle.publish("Strobe is off",NULL,60,PRIVATE);
else {
Particle.publish("Strobe is on",NULL,60,PRIVATE);
return _state;
int setOnPeriod(String command) {
//change the Grovestreams update period
Serial.println("Setting strobe run period");
int _command;
_command = command.toInt();
if (_command>=60 && _command<=3600) {//in minutes - between 1 and 3 minutes)
onSeconds = _command;
t.changePeriod(onMilliseconds);
return 1;
else {
return -1;
