Hello,
is it possible to use a Timer outside the main .ino file, For example in a library?
I tried to declare the timer Timer timer(1000,timer_fnc); in the .cpp file with void timer_fnc(void) declared in the .h file. I get a ‘timer_fnc’ was not declared in this scope error.
Thank you
Simone
Yes, you can do that - you just need to make sure that all symbols are defined wherever you need them (once explicitly and everywhere else as extern for variables and for functions you need a function prototype/forward declaration).
Thank you.
I have declared void timer_fnc(void) in the .h and defined it in the .cpp together with the Timer initialization Timer timer(1000,timer_fnc); .
But when I compile I still get a error: 'timer_fnc' was not declared in this scope;
Could you provide an example?
If you are using Web IDE, can you provide a SHARE THIS REVISION link to see what exactly you do and what the entire error message (including file reference and related notes) tells?
Sure I could provide a working example, but in order to know the dos and don’ts it better to see why it is not working the way you did it
Here’s the link to the code. Thank you so much.
One thing that wasn’t disclosed in any of your previous post is that your timer_fnc() actually is a non-static class method.
That’s why it is important to work on your code not mine
For non-static class functions you need to use another Timer constructor
https://docs.particle.io/reference/device-os/firmware/#class-member-callbacks
And in order to actually do that you need an object instance of your Motion_Service class.
For that reason you cannot have this in your library: Timer timer(1000, MotionService::timer_fnc); - not even with the correct constructor as you haven’t got an object at that time.
The way you laid out your library I’d rather have the Timer as a private member of the class and construct and start it in the class constructor.
Thank you. The is clear now. I rather turned the function and variable into static, I think this is a better option (?). It compiles. See updated code.
