Hello,
I have an electron that has subscribed to an event where it always receives data in the format “message, id” where it looks like this: “1,64941349958349”
I have a handler function that runs when it receives this data where the goal of the function is to
1. Parse this data
2. Extract the message and id
3. Create a new char buffer that includes the extracted id and a timestmap
4. Publish that as a new event
However, sometimes the Time.timeStr() returns an empty timestamp. This is what the Serial monitor displays for the code provided below:
Message Received: 1,64941141915078
copy: 1,64941141915078
message: 1
tnow:
Sending ack data:
64941141915078,
Notice how in this specific output, tnow is blank, thereby publishing an incomplete event. This happens once every few times. Could you please tell me why this is happening?
I usually receive 3 messages at once, spaced apart every 10 secs, in case this info is useful.
I very much appreciate your help!
Pasindu
void myHandler(const char *event, const char *data) {
Serial.print("Message Received: ");
Serial.println(data);
char* saveptr;
char* copy = strdup(data);
Serial.print("copy: ");
Serial.println(copy);
int message = atoi(strtok_r(copy, ",", &saveptr)); // using strtok_r instead of strtok because strtok uses global pointer and causes problems when threading
Serial.print("message: ");
Serial.println(message);
char* id = strtok_r(NULL, ",", &saveptr);
Serial.print("id: ");
Serial.println(id);
const char* tnow = Time.timeStr(); // store timestamp in tnow
Serial.print("tnow: ");
Serial.println(tnow);
char buffer[strlen(id) + strlen(tnow) + 2]; // create a buffer that's the length of the id, timestamp, and 2 more spaces (for a comma and a NULL termination character)
strcpy(buffer,id); // copy id into buffer along with NULL ternimation character automatically
strcat(buffer,","); // concatinate a comma into buffer which overwrites NULL ternimation and rewrites it at the end
strcat(buffer,tnow); // concatinate timestamp into buffer which overwrites NULL ternimation and rewrites it at the end
Serial.println();
Serial.println("Sending ack data:");
Serial.println(buffer);
Serial.println();
Particle.publish("ackdata", buffer , 60, PRIVATE);
free(copy);
