Hi everyone!
I am having trouble with some unpredictable Time.now() behaviour even after reading numerous other threads.
I cannot for anything in the world make it return a unix timestamp to a Particle.variable, either using sprintf or the String class. In the docs it is described that Time.now() should return an integer, which both methods should be capable of converting.
I have tried numerous methods already and it would be inefficient for me to post all of them. I am providing a minimum example using sprintf that at least returns something. String() returns nothing at all in the Particle.variable.
char theTime[100];
sprintf(theTime, "%i", Time.now());
Particle.variable("data",theTime);
The resulting Particle.variable reads:
"cmd": "VarReturn",
"name": "data",
"result": "�T",
"coreInfo": {
"last_app": "",
"last_heard": "2016-09-29T11:31:55.395Z",
"connected": true,
"last_handshake_at": "2016-09-29T11:31:49.423Z",
"deviceID": "2d0030001747353236343033",
"product_id": 6
In another thread it was mentioned that %i should rather be %u in sprintf, but I find the results are exactly the same.
Any good suggestions to why my time is “�T”? Thanks in advance!
