Particle variable show 0.00
I’m using the Particle.variable to display the float of the time as hh.mm. On the console variable section, it displays all times fine but if there’s a 0 at the end it will truncate the display. ie for 21:10 it will display 21.1. Is there a way to set the precision to a fixed amount for the variable function I can do it with publish but not variable
Showing your code would help :wink:
However, that is how floating point variables are typically rendered.
After all 21.1 is the same as 21.100000000 or even pretty much the same as 21.099999999999999999
If you want to display a time with trailing and/or leading zeros you should use a string variable.
Sorry about the lack of code!
You’ve managed to help me anyway the string did the trick I didn’t realise you could return strings. I don’t think it’s possible for Particle.function?
I’ve attached my solution if anyone in the future happens to pass by. Sorry for any strange naming I’m self-taught and don’t know the nuances of coding.
Annotation 2020-05-17 122142
Do you know if its possible to declare the the
  Particle.variable("Sunrise Open Time", sunrise2Console);
outside the void setup? I’m trying to reduce my number of global variables. I doubt there is but you seem to know a lot about particle coding!
There is a simpler way to create a formated time string
  Time.format(someTime, "%H:%M");
https://docs.particle.io/reference/device-os/firmware/photon/#format-
Particle.variable() now supports passing in a function instead of a global variable, if that helps.
https://docs.particle.io/reference/device-os/firmware/photon/#particle-variable-calculated
But the actual registration of the variable with the cloud needs to be done in setup() (or at least round about the time the cloud connection gets established).
BTW, you should not use blanks in the Particle.variable name.
What do you mean by blanks?
Should better be
Particle.variable("SunriseOpenTime", sunrise2Console);
according to this
Blanks or spaces are used synonymously.
