New error: The Doctor didn't complete successfully. Unknown module type: 3
When trying to run Particle Doctor on a Particle Core.
Is this because the CLI updated itself to the latest version ?
I didn't get a choice about the above, it just did it.
The current verison of the Particle CLI does not support the Spark Core. To install and older version see installing a specific version of the Particle CLI.
However that also won't help particle doctor as it has never worked on the Spark Core. These instructions may help recover the device.
Thank you - there seems to be a link on that page (how to roll back the CLI) that isn't a link?
Thanks again
Found the instructions but sadly unable to downgrade. Don't worry I'll bin the device it's not really fair to ask for support for a Core ten years on.
macbookpro:~ boom$ sudo npm install -g particle-cli@2
Password:
/usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/dist/index.js
> fsevents@1.2.9 install /usr/local/lib/node_modules/particle-cli/node_modules/fsevents
> node install
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Pre-built binaries not installable for fsevents@1.2.9 and node@10.15.3 (node-v64 ABI, unknown) (falling back to source compile with node-gyp)
node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/lib'
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/build'
gyp ERR! System Darwin 19.6.0
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/lib/binding/Release/node-v64-darwin-x64/fse.node" "--module_name=fse" "--module_path=/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/lib/binding/Release/node-v64-darwin-x64" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
gyp ERR! cwd /usr/local/lib/node_modules/particle-cli/node_modules/fsevents
gyp ERR! node -v v10.15.3
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/lib/binding/Release/node-v64-darwin-x64/fse.node --module_name=fse --module_path=/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/lib/binding/Release/node-v64-darwin-x64 --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:189:13)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:970:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
node-pre-gyp ERR! System Darwin 19.6.0
node-pre-gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/particle-cli/node_modules/fsevents/node_modules/node-pre-gyp/bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/particle-cli/node_modules/fsevents
node-pre-gyp ERR! node -v v10.15.3
node-pre-gyp ERR! node-pre-gyp -v v0.12.0
node-pre-gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/particle-cli/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 install: `node install`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
+ particle-cli@2.16.0
