Found problem after some debugging.
Help needed please.
res stays zero and does not convert to a float to do the test ??
int dayson;
int days;
float res;
res = days/dayson;
if (round(days/dayson) == (days/dayson))
MET = 3;
res = days/dayson;
because both days and dayson are ints the rvalue is calculated using integer math,
try casting either or both to a float…
res = float(days)/dayson;
Thanks.
Problem solved.
I must really ask the forum quicker for answers. Battled for a day !!!
