Math problem in Particle Electron
hi all,
I am encountering a math problem with my particle, I need to divide pulses by 88 to get liters on my flow meter. if I use the inter value it reports to the console the pulses, but when i try to divide by 88 it just reports a 0.000.
what could be the problem.
int LEDpin = D7;
unsigned long publish_delay = 20000;
unsigned long LastPublish = 0;
int state = LOW;
unsigned long WaterPulseCount = 0;
    pinMode(LEDpin, OUTPUT);
    pinMode(A1,INPUT_PULLUP);
    attachInterrupt(A1,WaterInterupt, CHANGE);
  unsigned long now = millis();
  digitalWrite(LEDpin,state);
  if((now - LastPublish) < publish_delay)
    double liters = WaterPulseCount / 88;
    Particle.publish("data",String(liters));
    LastPublish = millis();
    delay(1000);
void WaterInterupt()
    state = !state;
    WaterPulseCount++;
When both operands in a division are integers then the result will also be an integer, irrespective of the target variable which should receive the result after the fact.
You can do this to force a floating point division
  double liters = WaterPulseCount / 88.0;
hi
thanks working like a dream now. thanks a lot and have a good day.
This is also a reason why I rarely put “magic” constants in executed lines of code but instead as their own constant variables. This way you can better enforce your expectations for how that value will be used.
Eg:
const double kPulsesPerLiter = 88;
double liters = WaterPulseCount / kPulsesPerLiter;
Alternatively, in a more generic case, and especially when sharing code amongst other people, there is a danger that if someone changes the magic constant number, that they might forget the .0. For that reason I would also have a slight preference for an explicit typecast, such as:
double liters = WaterPulseCount / static_cast<double>(88);
thanks, for this, if your ever in Cape Town South Africa there is an open invitation for a beer.
