I am working on creating my own recipes (via the IFTTT website) and I was wondering how to use the test operations on a string. They seem to be desiged to work well with numbers but not so much on strings.
Is there a way to do a IF <variable> CONTAINS <sub string>
Wouldn’t it be easier to have your Spark check for the required word, and then have it fire an event if it finds it? This would eliminate having to check for a string. It should also be a bit more responsive than the variables.
Just an idea though. If you could describe your use case, we might be offer to viable alternatives/solutions.
@Moors7, Actually no. In my case I am using a cloud variable for error messages. the string can contain a combination of errors. If I want to trigger something on a combination then I need to create an exponentially growing event supply.
Take the Twitter module for example, it has a search string. I just think the choices
Greater
Less
Equals
Greater Or Equal
Less or equal
are useless for strings. How can I at least test if a string is empty?
The great power of IFTTT is that is decouples internal logic from external interpretation and leaving it up to the user what to do.
Ooh good question, maybe! I know IFTTT lets you provide a set of options programmatically, but I don’t think they tell you what else has been picked in the form, so I don’t think you can do conditional logic like that in the form itself.
The other part that is tricky for adding options is I can’t change them directly myself now that the channel is published. So I need to wait on them to add them behind the scenes I suspect. But I think the string comparison options are a great idea, I’ll try to get them in.
