I’m trying to install the terminal on windows. I have all the parts installed, that is, node, python, DFU… the problem I have is with node, no version of Node works, both 0.12.2 and 0.10.0 cause an error when I try to install it on my command promt. However, that is one of the 100’s of errors that come up. I thought I should look at that first, which version of Node.js should I use and how to I avoid the errors?
@thespark, which version of Windows are you running? I have Win7x64 and am using Node.js 0.12.x (not sure which minor version). Before that, things worked well with 0.10.33.
I’m using windows 8, and I tried both of those versions to no avail
