Hi all,
I am trying to benchmark the speed at which I can transfer data off of an Argon using TCPClient and a simple node.js TCP server to receive and save the data to a file. I’ve seen in other posts such as by @rickkas7 showing that speeds of up to 900KB/s or even 1MB/s are possible, but the max I can seem to achieve is around 45-55KB/s using the Argon.
I am able to use other tcp clients that aren’t particle devices, such as a node.js tcp client example and get much higher speeds, but no more than 55KB/s on the Argon. I have tried changing my buffer size and I get essentially the same results at 512 and 1024 B.
Since the Argon uses the ESP32 for wifi comms and communicates with the ESP32 via Serial, is it possible that the Serial data rate is the limiting factor here? I’ll include my device code below, and I can include my node server code as well in case anyone else wants to check their own results.
UPDATE: Using Ethernet instead of WiFi on the Argon I can reach speeds of 400KB/s which is certainly better, but still it’s basically 1/2 of the speed people claim to get over WiFi! I understand that gen3 devices communicate with the ethernet shield via SPI whereas WiFi through the ESP32 is done with Serial so regardless of the inherent advantages of wired over wireless I feel like this could be related (SPI vs Serial)
Thanks for any help/insight anyone can offer!
device code:
SYSTEM_MODE(MANUAL);
SYSTEM_THREAD(ENABLED);
#define CACHE 1024
TCPClient client;
const byte host[] = {192, 168, 0, 110};
char buf[CACHE];
waitUntil(Serial.isConnected);
Serial.println("Starting WiFi...");
WiFi.on();
WiFi.connect();
waitUntil(WiFi.ready);
Serial.print("WiFi connected with IP: ");
Serial.println(WiFi.localIP());
Serial.println("Connecting to TCP Server...");
int rc = client.connect(host, 8081);
Serial.printf("Connect returned code: %d\n", rc);
if (client.connected()) {
Serial.print("Connected to : ");
Serial.println(client.remoteIP());
memset(buf, 'A', CACHE);
for(int i = 0; i < 1000000; i += CACHE) {
client.print(buf);
while(client.available() > 0) {
Serial.print(client.read());
client.stop();
} else {
Serial.println("Connection failed!");
server code: (excuse my sloppy work)
const net = require('net');
const port = 8081;
const host = '0.0.0.0';
var fs = require('fs');
var totalsize = 0;
var totaltime = 0;
var start = 0;
var end = 0;
var avgspeed = 0;
const server = net.createServer();
server.listen(port, host, () => {
console.log('TCP Server is running on port ' + port + '.');
server.on('connection', function(sock) {
totalsize = 0;
currspeed = 0;
start = process.hrtime();
console.log('CONNECTED: ' + sock.remoteAddress + ':' + sock.remotePort);
fs.unlinkSync("data.dat");
var file = fs.createWriteStream("data.dat");
sock.on('data', function(data) {
file.write(data);
totalsize += data.length;
end = process.hrtime(start);
totaltime = end[0]+(end[1]/1000000000);
avgspeed = (totalsize/1000)/(totaltime);
process.stdout.write(avgspeed+' KB/s\n')
sock.on('close', function(data) {
file.close();
console.info('Transfer time: %ds %dms', end[0], end[1] / 1000000);
console.log('Avg speed: '+avgspeed+' KB/s');
console.log('Total size: '+totalsize);
console.log('CLOSED: ' + sock.remoteAddress + ' ' + sock.remotePort);
