Hello,
in the particle white-paper about power efficient IoT products there is a table with the different particle sleep modes. One is, that I can turn of the MCU off and keep the radio on -> System.sleep() in network standby mode, where it can still receive messages from the cloud.
When I checked the reference, I found the function, but the photon can only wake up by time-out or a wake-up pin.
System.sleep(D3, RISING, 30, SLEEP_NETWORK_STANDBY);
This works just fine, but is there any way to use the cloud messages to wake up the photon from the “network standby mode” without using any extra hardware to trigger a wake-up pin?
Currently the photon sends every three hours a data payload via webhook to my cloud, where it is analysed. After that the photon goes into sleep mode for the next three hours. This works just fine. Our ideal scenario would be, that I can check in between the sensor readings or trigger a particle function with an app and after that the device goes to a sleep mode again (which one depends on the current battery level).
Is the System.sleep() with network standby the right way, or are there any other ways to do this?
