We have few boron 404X devices installed at various locations powered by Lithium battery.
An external RTC based module wakes up Boron 404X module 4-8 times per day (depending on programmed alarm schedule) to send information. Once information sent Boron 404X turns off its cellular and few seconds later shuts its own power off by pulling Enable Pin (simple FET circuit).
For 1-2 years everything was OK. Battery lasted for almost 12 Months.
Later In firmware we implemented if System.powerSource() == POWER_SOURCE_BATTERY it should cut its power off by pulling (Through FET circuit) Enable pin and if System.powerSource() == VIN leave Enable pin Enabled.
We found that System.powerSource() some time reported incorrectly that has caused boards to stay awake and discharging the battery.
Some site are still going for almost 5 Months and some site battery didn't last a week. It is confirmed that board stays awake causing battery to discharge and System.powerSource() is in question???
Any input will be highly appreciated.
Device Boron404x OS = 4.2.0
