This is a port of Adafruit’s MCP28003 8-bit I2C IO Expander Arduino library. I needed it for a project I’m doing with the Spark Core, so thought I’d share it. It’s also been published through the web IDE.
Code is here: https://github.com/JBionics/MCP23008-I2C
Nice! Congrats.
I wonder if this will work with my PCF8574 without modding…
@henriquepss
I took a quick look at the PCF8574 datasheet. It operates differently than the MCP23008, however it’s a simpler chip to work with.
You just Wire.write() and Wire.read() to read/write IO pins. No chip configuration required.
This tutorial code runs on the spark with minimal changes:
Hey,
the libary looks really nice
Would it to work together with the MCP23016?
As far as I know the MCP23016 is basically just the 16 channel version of the MCP23008.
