Strstr() failing!
I can’t believe it, but it seems that the strstr() function is giving me erroneous results… To prove the point, I have written this piece of test code:
   strstr-fail.in0
   Testing strstr() operation
2017-11-16
- Created
bool bOnceOff = false;
char szSrc[64];
    Serial.begin();
    const char * psz2;
    if (!bOnceOff)
        bOnceOff = true;
        Serial.println("Tests");
        strcpy(szSrc, "0123456789012345678901234567890123456789");
        if (strstr(szSrc,psz2="0123456789012345678901234567890123456789") == NULL);
            Serial.printf("FAIL <%s> :: <%s>\r\n", szSrc, psz2);
        if (strstr(szSrc,psz2="01234567890123456789") == NULL);
        if (strstr(szSrc,psz2="012345") == NULL);
        strcpy(szSrc, "0123456789");
        if (strstr(szSrc,psz2="0123456789") == NULL);
        if (strstr(szSrc,psz2="01234") == NULL);
Here is the output:
Tests
FAIL <0123456789012345678901234567890123456789> :: <0123456789012345678901234567890123456789>
FAIL <0123456789012345678901234567890123456789> :: <01234567890123456789>
FAIL <0123456789012345678901234567890123456789> :: <012345>
FAIL <0123456789> :: <0123456789>
FAIL <0123456789> :: <01234>
Anyone have the same problem or clue as to what is going on with this most basic of functions?
Case closed…
Note the pesky… “;” at the end of the if statement. Going blind…
Thanks for posting your solution!
