String overloads not working properly
This is c++11 related, and I’m not entirely aquainted with R-values
The following code doesn’t compile, why?
String status;
void setup() {};
String tempString = “”;
unsigned char DEC_BASE = static_cast(DEC);
tempString = String(13,DEC_BASE);
status = tempString;
I’m getting
undefined reference to `String::operator=(String&&)’
I works, if you move the declaration and assignment into the same line
String status;
void setup() {};
String tempString = String(13,DEC_BASE);
Thoughts?
My unsigned char casting is the same solution as posted for this problem
although this is the a further issue with the move operator
Both of these should be fixed so you can do
// A->B->A method here used to prevent compiler from optimizing.
String myString;
String temp;
temp = String(13,DEC);
myString = temp;
