Strange results using and returning doubles [SOLVED]
I’m experiencing some strange results when using doubles…
I’ve got a global double declared:
double x;
Which I clear in setup():
x = 0;
I’ve got the following, which executes (sucessfully) once a second:
void make_x()
    int a = 3642;
    x = (double)a;
and the following so that I can retrieve x, from within setup():
Spark.variable("getx", &x, DOUBLE);
Yet when I call ‘getx’, I get the following result:
    "cmd": "VarReturn",
    "name": "getx",
    "result": 3.7777603e-317,
    "coreInfo": {
        "last_app": "",
        "last_heard": "2014-02-13T23:33:48.598Z",
        "connected": true,
        "deviceID": "xxxxxxxxxxxxxxxxxxxx"
And the value isn’t as I was expecting, unless my maths is seriously wrong somewhere!
How can 3642 be the same as 3.7777603 x 10^-317 ??
I’ve checked that I’m not setting the variable elsewhere.
Can anyone help? Thanks.
Hi @binaryfrost; we’ve got this on our backlog to fix; we think it’s a problem with endianness. I believe that currently every variable type except double should be working, so perhaps you can use another type?
I’ve got a fix for this and it’ll be included in our next production push (hopefully tomorrow), this one has been bugging me!
David
A work-around until this is fixed might be to use strings instead. This came up before in another thread and this code worked fine.
#include <math.h>
double result = 0;
char resultstr[64];
  Spark.variable("result", &resultstr, STRING);
  result = log10(10000);
  sprintf(resultstr, "%f",result);
  delay(5000);
Glad it’s not me going mad. Many thanks guys!
In the interim I’ll try the String work around.
Hey @binaryfrost , Thanks for sharing. @Dave just fixed this issue yesterday, but it’s not deployed to production. Will post here when doubles are working expected.
Hah! @Dave just deployed this to production and verified that it works. Strange double variable behavior should be a thing of the past–if anyone experiences something otherwise, please post here.
@jgoggins awesome - many thanks.
Thinking about my previous post…
…which bug was this logged against? I cant find a closed bug corresponding to this on the github channel…
Thanks :slight_smile:
No prob @binaryfrost. It was logged against our internal project management tool, not logged against anything public. As @Dave mentioned in that post, let’s try logging known bugs via GitHub issues that arise on this community site and see if that helps folks know when things are fixed/etc.
Some bugs won’t make sense on Github at the moment, e.g. stuff with the build IDE, etc. So posting those on the forums might make more sense.
