If i have a variable defined in my code as something like
Spark.variable('temp', &temperature, DOUBLE);
What is the best way to read this on the javascript side?
When I do a device.getVariable, the value is wildly different than I see if i just print the original float to the serial.
For example
Serial.println(temperature, 2);
// prints: 26.10
On the javascript side, my result value is:
{... result: 6.204439556495507e-270 ...}
I was trying to just have the variable be a string and use sprintf inside my photon’s code, but i couldn’t get it working and I read that sprintf support was removed.
Anyone have some advice on how i could parse this result value to be the proper number?
