Stack Overflow when calling Particle.connect
When running in manual mode has anyone seen a stack overflow when you call Particle.connect?
This is in a program running in MANUAL mode. There are two scenarios where it tries to connect:
  1. If the device wakes from sleep by the sleep timer it will connect and post the battery SOC without problem then deep sleep.
  2. But it it is woke with the pin it does it’s logging just fine and then tries to connect before going back to sleep.
In this second case it S.O.S flashes a stack overflow.
Full Code
#include "SdFat.h"
#include "PowerShield.h"
// Don't connect to the cloud to reduce time jitter.
// WARNING you must use safe mode for OTA flash if you use manual mode.
// Remove comment on next line to decrease time jitter.
SYSTEM_MODE(MANUAL);
PowerShield batteryMonitor;
 * This program logs data to a binary file.  Functions are included
 * to convert the binary file to a csv text file.
 * Samples are logged at regular intervals.  The maximum logging rate
 * depends on the quality of your SD card and the time required to
 * read sensor data.  This example has been tested at 500 Hz with
 * good SD card on an Uno.  4000 HZ is possible on a Due.
 * If your SD card has a long write latency, it may be necessary to use
 * slower sample rates.  Using a Mega Arduino helps overcome latency
 * problems since 13 512 byte buffers will be used.
 * Data is written to the file using a SD multiple block write command.
// User data functions.  Modify these functions for your data items.
// Read analog pins not used by primary SPI.
// You may want to connect the SD to the secondary SPI interface.
const uint8_t ADC_DIM = 3; //number of data channels
struct data_t {
  unsigned long time;
  unsigned short adc[ADC_DIM];
unsigned long timeMillis = 0;
unsigned long closedTime = 0;
unsigned long socUpdateFreq = 86400; //how often to try and publish battery SOC in seconds
char payload[256] = "";
int wakePin = A7; //wake pin
int runStatus = 0;
int debounceTime = 20; //debounde time in ms
int turnOffTime = 2000; //long hold sitch to stop recording in ms
LEDStatus status1(RGB_COLOR_YELLOW, LED_PATTERN_FADE, LED_SPEED_FAST); //setting up files, between button press and record
LEDStatus status2(RGB_COLOR_RED, LED_PATTERN_BLINK, LED_SPEED_SLOW); //recording
LEDStatus status3(RGB_COLOR_BLUE, LED_PATTERN_BLINK, LED_SPEED_FAST); //converting to CSV file
LEDStatus status4(RGB_COLOR_ORANGE, LED_PATTERN_FADE, LED_SPEED_FAST); //publishing SOC
//SYSTEM_THREAD(ENABLED);
// Set useSharedSpi true for use of an SPI sensor.
const bool useSharedSpi = false;
// Acquire a data record.
void acquireData(data_t* data) {
  data->time = micros();
  data->adc[0] = analogRead(A0); //X
  data->adc[1] = analogRead(A1); //Y
  data->adc[2] = analogRead(A2); //Z
  //data->adc[3] = analogRead(A7);
// Print a data record.
void printData(Print* pr, data_t* data) {
  pr->print(data->time);
  for (int i = 0; i < ADC_DIM; i++) {
    pr->write(',');
    pr->print(data->adc[i]);
  pr->println();
//map a float
float mapf(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
// Print data header.
void printHeader(Print* pr) {
  pr->println(F("time,X (A0),Y (A1),Z (A2)"));
// Start of configuration constants.
//Interval between data records in microseconds.
const uint32_t LOG_INTERVAL_USEC = 1000;
// Pin definitions.
// SD chip select pin.
const uint8_t SD_CS_PIN = D1;
// Digital pin to indicate an error, set to -1 if not used.
// The led blinks for fatal errors. The led goes on solid for SD write
// overrun errors and logging continues.
const int8_t ERROR_LED_PIN = D7;
// File definitions.
// Maximum file size in blocks.
// The program creates a contiguous file with FILE_BLOCK_COUNT 512 byte blocks.
// This file is flash erased using special SD commands.  The file will be
// truncated if logging is stopped early.
const uint32_t FILE_BLOCK_COUNT = 256000;
// log file base name.  Must be six characters or less.
#define FILE_BASE_NAME "data"
// Buffer definitions.
// The logger will use SdFat's buffer plus BUFFER_BLOCK_COUNT additional
// buffers.
#ifndef RAMEND
// Assume ARM. Use total of nine 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 8;
#elif RAMEND < 0X8FF
#error Too little SRAM
#elif RAMEND < 0X10FF
// Use total of two 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 1;
#elif RAMEND < 0X20FF
// Use total of five 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 4;
#else  // RAMEND
// Use total of 13 512 byte buffers.
const uint8_t BUFFER_BLOCK_COUNT = 12;
#endif  // RAMEND
// End of configuration constants.
// Temporary log file.  Will be deleted if a reset or power failure occurs.
#define TMP_FILE_NAME "tmp_log.bin"
// Size of file base name.  Must not be larger than six.
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
SdFat sd(1); //use secondary SPI interface
// Secondary SPI with DMA
// SCK => D4, MISO => D3, MOSI => D2, SS => D1
SdBaseFile binFile;
char binName[13] = FILE_BASE_NAME "00.bin";
// Number of data records in a block.
const uint16_t DATA_DIM = (512 - 4)/sizeof(data_t);
//Compute fill so block size is 512 bytes.  FILL_DIM may be zero.
const uint16_t FILL_DIM = 512 - 4 - DATA_DIM*sizeof(data_t);
struct block_t {
  uint16_t count;
  uint16_t overrun;
  data_t data[DATA_DIM];
  uint8_t fill[FILL_DIM];
const uint8_t QUEUE_DIM = BUFFER_BLOCK_COUNT + 2;
block_t* emptyQueue[QUEUE_DIM];
uint8_t emptyHead;
uint8_t emptyTail;
block_t* fullQueue[QUEUE_DIM];
uint8_t fullHead;
uint8_t fullTail;
// Advance queue index.
inline uint8_t queueNext(uint8_t ht) {
  return ht < (QUEUE_DIM - 1) ? ht + 1 : 0;
void fatalBlink() {
  while (true) {
    if (ERROR_LED_PIN >= 0) {
      digitalWrite(ERROR_LED_PIN, HIGH);
      delay(200);
      digitalWrite(ERROR_LED_PIN, LOW);
      delay(200);
void error(const char* msg) {
  sd.errorPrint(msg);
  Serial.printlnf("Switch Status = %d", runStatus);
  fatalBlink();
// Convert binary file to csv file.
void binaryToCsv() {
  Serial.println("Starting CSV Write");
  uint8_t lastPct = 0;
  block_t block;
  uint32_t t0 = millis();
  uint32_t syncCluster = 0;
  SdFile csvFile;
  char csvName[13];
  status3.setActive(true);
  if (!binFile.isOpen()) {
    Serial.println();
    Serial.println(F("No current binary file"));
    return;
  binFile.rewind();
  // Create a new csvFile.
  strcpy(csvName, binName);
  strcpy(&csvName[BASE_NAME_SIZE + 3], "csv");
  if (!csvFile.open(csvName, O_WRITE | O_CREAT | O_TRUNC)) {
    error("open csvFile failed");
  Serial.println();
  Serial.print(F("Writing: "));
  Serial.print(csvName);
  Serial.println(F(" - type any character to stop"));
  printHeader(&csvFile);
  uint32_t tPct = millis();
  while (!Serial.available() && binFile.read(&block, 512) == 512) {
    uint16_t i;
    if (block.count == 0) {
      break;
    if (block.overrun) {
      csvFile.print(F("OVERRUN,"));
      csvFile.println(block.overrun);
    for (i = 0; i < block.count; i++) {
      printData(&csvFile, &block.data[i]);
    if (csvFile.curCluster() != syncCluster) {
      csvFile.sync();
      syncCluster = csvFile.curCluster();
    if ((millis() - tPct) > 1000) {
      uint8_t pct = binFile.curPosition()/(binFile.fileSize()/100);
      if (pct != lastPct) {
        tPct = millis();
        lastPct = pct;
        Serial.print(pct, DEC);
        Serial.println('%');
    csvFile.close();
    Serial.print(F("Done: "));
    Serial.print(0.001*(millis() - t0));
    Serial.println(F(" Seconds"));
    Serial.println("CSV Write Done");
    status3.setActive(false);
    postSOC();
    Serial.printlnf("Switch Status = %d", digitalRead(wakePin));
    Serial.println("Sleeping");
    System.sleep(SLEEP_MODE_DEEP, socUpdateFreq);
    //System.sleep(wakePin, RISING); //sleep untill rising edge on
// read data file and check for overruns
void checkOverrun() {
  bool headerPrinted = false;
  block_t block;
  uint32_t bgnBlock, endBlock;
  uint32_t bn = 0;
    Serial.println();
    return;
  if (!binFile.contiguousRange(&bgnBlock, &endBlock)) {
    error("contiguousRange failed");
  binFile.rewind();
  Serial.println();
  Serial.println(F("Checking overrun errors - type any character to stop"));
  while (binFile.read(&block, 512) == 512) {
      break;
      if (!headerPrinted) {
        Serial.println();
        Serial.println(F("Overruns:"));
        Serial.println(F("fileBlockNumber,sdBlockNumber,overrunCount"));
        headerPrinted = true;
      Serial.print(bn);
      Serial.print(',');
      Serial.print(bgnBlock + bn);
      Serial.print(',');
      Serial.println(block.overrun);
    bn++;
    Serial.println(F("No errors found"));
  } else {
    Serial.println(F("Done"));
// dump data file to Serial
void dumpData() {
  block_t block;
    Serial.println();
    return;
  binFile.rewind();
  Serial.println();
  Serial.println(F("Type any character to stop"));
  delay(1000);
  printHeader(&Serial);
  while (!Serial.available() && binFile.read(&block , 512) == 512) {
      break;
      Serial.print(F("OVERRUN,"));
    for (uint16_t i = 0; i < block.count; i++) {
      printData(&Serial, &block.data[i]);
// log data
// max number of blocks to erase per erase call
uint32_t const ERASE_SIZE = 262144L;
void logData() {
  // Allocate extra buffer space.
  block_t block[BUFFER_BLOCK_COUNT];
  block_t* curBlock = 0;
  Serial.println();
  // Find unused file name.
  if (BASE_NAME_SIZE > 6) {
    error("FILE_BASE_NAME too long");
  while (sd.exists(binName)) {
    if (binName[BASE_NAME_SIZE + 1] != '9') {
      binName[BASE_NAME_SIZE + 1]++;
    } else {
      binName[BASE_NAME_SIZE + 1] = '0';
      if (binName[BASE_NAME_SIZE] == '9') {
        error("Can't create file name");
      binName[BASE_NAME_SIZE]++;
  // Delete old tmp file.
  if (sd.exists(TMP_FILE_NAME)) {
    Serial.println(F("Deleting tmp file"));
    if (!sd.remove(TMP_FILE_NAME)) {
      error("Can't remove tmp file");
  // Create new file.
  Serial.println(F("Creating new file"));
  binFile.close();
  if (!binFile.createContiguous(sd.vwd(),
                                TMP_FILE_NAME, 512 * FILE_BLOCK_COUNT)) {
    error("createContiguous failed");
  // Get the address of the file on the SD.
  // Use SdFat's internal buffer.
  uint8_t* cache = (uint8_t*)sd.vol()->cacheClear();
  if (cache == 0) {
    error("cacheClear failed");
  // Flash erase all data in the file.
  Serial.println(F("Erasing all data"));
  uint32_t bgnErase = bgnBlock;
  uint32_t endErase;
  while (bgnErase < endBlock) {
    endErase = bgnErase + ERASE_SIZE;
    if (endErase > endBlock) {
      endErase = endBlock;
    if (!sd.card()->erase(bgnErase, endErase)) {
      error("erase failed");
    bgnErase = endErase + 1;
  // Start a multiple block write.
  if (!sd.card()->writeStart(bgnBlock, FILE_BLOCK_COUNT)) {
    error("writeBegin failed");
  // Set chip select high if other devices use SPI.
  if (useSharedSpi) {
    sd.card()->chipSelectHigh();
  // Initialize queues.
  emptyHead = emptyTail = 0;
  fullHead = fullTail = 0;
  // Use SdFat buffer for one block.
  emptyQueue[emptyHead] = (block_t*)cache;
  emptyHead = queueNext(emptyHead);
  // Put rest of buffers in the empty queue.
  for (uint8_t i = 0; i < BUFFER_BLOCK_COUNT; i++) {
    emptyQueue[emptyHead] = &block[i];
  status1.setActive(false); //setup led off
  status2.setActive(true); //recording led on
  Serial.println(F("Logging - type any character to stop"));
  // Wait for Serial Idle.
  Serial.flush();
  delay(10);
  uint32_t bn = 0;
  uint32_t t1 = t0;
  uint32_t overrun = 0;
  uint32_t overrunTotal = 0;
  uint32_t count = 0;
  uint32_t maxDelta = 0;
  uint32_t minDelta = 99999;
  uint32_t maxLatency = 0;
  // Start at a multiple of interval.
  uint32_t logTime = micros()/LOG_INTERVAL_USEC + 1;
  logTime *= LOG_INTERVAL_USEC;
  bool closeFile = false;
  while (1) {
    // Time for next data record.
    logTime += LOG_INTERVAL_USEC;
    if (Serial.available()) {
      closeFile = true;
    if (closeFile) {
      if (curBlock != 0) {
        // Put buffer in full queue.
        fullQueue[fullHead] = curBlock;
        fullHead = queueNext(fullHead);
        curBlock = 0;
    } else {
      if (curBlock == 0 && emptyTail != emptyHead) {
        curBlock = emptyQueue[emptyTail];
        emptyTail = queueNext(emptyTail);
        curBlock->count = 0;
        curBlock->overrun = overrun;
        overrun = 0;
      int32_t usec = logTime - micros();
      if (usec < 0) {
        error("Rate too fast");
      delayMicroseconds(usec);
      uint32_t delta = micros() - logTime;
      if (delta > maxDelta) maxDelta = delta;
      if (delta < minDelta) minDelta = delta;
      if (curBlock == 0) {
        overrun++;
      } else {
        acquireData(&curBlock->data[curBlock->count++]);
        if (curBlock->count == DATA_DIM) {
          curBlock = 0;
    if (fullHead == fullTail) {
      // Exit loop if done.
      if (closeFile) {
        break;
    } else if (!sd.card()->isBusy()) {
      // Get address of block to write.
      block_t* pBlock = fullQueue[fullTail];
      fullTail = queueNext(fullTail);
      // Write block to SD.
      uint32_t usec = micros();
      if (!sd.card()->writeData((uint8_t*)pBlock)) {
        error("write data failed");
      usec = micros() - usec;
      t1 = millis();
      if (usec > maxLatency) {
        maxLatency = usec;
      count += pBlock->count;
      // Add overruns and possibly light LED.
      if (pBlock->overrun) {
        overrunTotal += pBlock->overrun;
      // Move block to empty queue.
      emptyQueue[emptyHead] = pBlock;
      bn++;
      if (bn == FILE_BLOCK_COUNT) {
        // File full so stop
        break;
        if (digitalRead(wakePin) == 0 && runStatus == 1) { //turn off code, switch closed and output high
          runStatus = 0;
          Serial.println("Stopping Log");
          status2.setActive(false);
          closeFile = true;
  if (!sd.card()->writeStop()) {
    error("writeStop failed");
  // Truncate file if recording stopped early.
  if (bn != FILE_BLOCK_COUNT) {
    Serial.println(F("Truncating file"));
    if (!binFile.truncate(512L * bn)) {
      error("Can't truncate file");
  if (!binFile.rename(sd.vwd(), binName)) {
    error("Can't rename file");
  Serial.print(F("File renamed: "));
  Serial.println(binName);
  Serial.print(F("Max block write usec: "));
  Serial.println(maxLatency);
  Serial.print(F("Record time sec: "));
  Serial.println(0.001*(t1 - t0), 3);
  Serial.print(minDelta);
  Serial.print(F(" <= jitter microseconds <= "));
  Serial.println(maxDelta);
  Serial.print(F("Sample count: "));
  Serial.println(count);
  Serial.print(F("Samples/sec: "));
  Serial.println((1000.0)*count/(t1-t0));
  Serial.print(F("Overruns: "));
  Serial.println(overrunTotal);
  Serial.println("Converting to CSV");
  binaryToCsv();
    pinMode(ERROR_LED_PIN, OUTPUT);
  pinMode(wakePin, INPUT_PULLDOWN);
  // Wait for USB Serial
  while (!Serial) {
    SysCall::yield();
  Serial.println("Setup started");
  Serial.print(F("FreeMemory: "));
  Serial.println(System.freeMemory());
  Serial.print(F("Records/block: "));
  Serial.println(DATA_DIM);
  if (sizeof(block_t) != 512) {
    error("Invalid block size");
  // initialize file system.
  if (!sd.begin(SD_CS_PIN, SPI_FULL_SPEED)) {
    sd.initErrorPrint();
    fatalBlink();
  if (digitalRead(wakePin) == 1) {
    Serial.println("logging started");
    status1.setActive(true);
    runStatus = 1;
    logData();
  if (digitalRead(wakePin) == 0 && runStatus == 0) {
    postSOC();
    Serial.println("sleeping");
    status4.setActive(false);
void postSOC() { //atempts to post the battery SOC
  // This essentially starts the I2C bus
  batteryMonitor.begin();
  Serial.println("battery mon");
  // This sets up the fuel gauge
  batteryMonitor.quickStart();
  Serial.println("quick start");
  Particle.connect();
  Serial.println("particle connect");
  Particle.process();
  Serial.println("process");
  delay(3000);
  status4.setActive(true);
  if (waitFor(Particle.connected, 5000)) {
    Serial.println("if start");
    Particle.process();
    float cellVoltage = batteryMonitor.getVCell(); // Read the volatge of the LiPo
    float stateOfCharge = batteryMonitor.getSoC(); // Read the State of Charge of the LiPo
    Particle.process();
    sprintf(payload, "{ \"Cell Voltage\":%.1f,\"SOC\":%.1f}", cellVoltage, stateOfCharge);
    Particle.publish("postGoogle", payload, PRIVATE, WITH_ACK);
    Particle.process();
    //Particle.publish(payload, NULL, PRIVATE, WITH_ACK);
    delay(2000);
I’m not claiming to understand all of this, however here is something to try. Instead of calling postSOC() from within binaryToCsv() which is within logData(), how about just putting it after the call to logData() within your loop() function. This will allow all that stack from those large functions to unwind, freeing up some stack space for postSOC() to run?
And we have a winner. I’m new to this and there was no reason to have those nested like that. I pulled binaryToCsv() and postSOC() out to the loop() and that fixed it.
Thanks for the help and giving me a better understanding of when stack is consumed.
