I've been using an older version of the firmware develop branch that compiles my app without any errors. However, the latest version of the firmware develop branch (which I "git pull"(ed)) when compiled gives me a bunch of sprintf errors (these errors occur when I run "make clean all PLATFORM=photon APP=MY_APP_NAME"):
sprintf' referenced in section.text._Z13SF_command_BL6String' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans1.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)sprintf' referenced in section.text._Z21sendinteractionrecordv' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans1.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)
sprintf' referenced in section.text._Z15progressButtons12accuracyenum' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans1.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)sprintf' referenced in section.text._Z15progressButtons12accuracyenum' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans1.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)
sprintf' referenced in section.text._Z18correctConsequencev' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans1.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)sprintf' referenced in section.text._Z16senddevicereportv' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans3.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)
sprintf' referenced in section.text._Z11finishTrialv' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans3.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)sprintf' referenced in section.text._Z14DL_P_PlayAudioii' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans3.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)
sprintf' referenced in section.text._ZN10RestClient7requestEPKcS1_S1_P6String.constprop.22' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans5.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)sprintf' referenced in section.text._Z6DL_cmdcPcm' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans7.ltrans.o: defined in discarded section.text' of rt_dynalib.o (symbol from plugin)
sprintf' referenced in section.text._Z19DL_L_LightwithFlashiiiii' of /var/folders/21/gd3g8pn90tlfm0tty3mzztj80000gp/T//cclGBaz5.ltrans7.ltrans.o: defined in discarded section `.text' of rt_dynalib.o (symbol from plugin)
make[1]: *** [../../../build/target/user-part/platform-6-m-lto/applications/cleverpet-behaviorlayer/cleverpet-behaviorlayer.elf] Error 1
make: *** [modules/photon/user-part] Error 2
Will there be fixes for sprintf in later revisions of the branch?
