Ya that’s what I did.
Just tried it again and this is at the tail end of the log.
2426 verbose about to build /usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/optimist/node_modules/wordwrap
2427 info build /usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/optimist/node_modules/wordwrap
2428 verbose linkStuff [ true,
2428 verbose linkStuff '/usr/local/lib/node_modules',
2428 verbose linkStuff false,
2428 verbose linkStuff '/usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/optimist/node_modules' ]
2429 info linkStuff wordwrap@0.0.2
2430 verbose linkBins wordwrap@0.0.2
2431 verbose linkMans wordwrap@0.0.2
2432 verbose rebuildBundles wordwrap@0.0.2
2433 info install wordwrap@0.0.2
2434 info postinstall wordwrap@0.0.2
2435 verbose about to build /usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/optimist
2436 info build /usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/optimist
2437 verbose linkStuff [ true,
2437 verbose linkStuff '/usr/local/lib/node_modules',
2437 verbose linkStuff false,
2437 verbose linkStuff '/usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules' ]
2438 info linkStuff optimist@0.3.7
2439 verbose linkBins optimist@0.3.7
2440 verbose linkMans optimist@0.3.7
2441 verbose rebuildBundles optimist@0.3.7
2442 verbose rebuildBundles [ 'wordwrap' ]
2443 info install optimist@0.3.7
2444 info postinstall optimist@0.3.7
2445 verbose about to build /usr/local/lib/node_modules/spark-cli/node_modules/serialport
2446 info build /usr/local/lib/node_modules/spark-cli/node_modules/serialport
2447 verbose linkStuff [ true,
2447 verbose linkStuff '/usr/local/lib/node_modules',
2447 verbose linkStuff false,
2447 verbose linkStuff '/usr/local/lib/node_modules/spark-cli/node_modules' ]
2448 info linkStuff serialport@1.3.1
2449 verbose linkBins serialport@1.3.1
2450 verbose link bins [ { serialportlist: './bin/serialportList.js',
2450 verbose link bins serialportterm: './bin/serialportTerminal.js' },
2450 verbose link bins '/usr/local/lib/node_modules/spark-cli/node_modules/.bin',
2450 verbose link bins false ]
2451 verbose linkMans serialport@1.3.1
2452 verbose rebuildBundles serialport@1.3.1
2453 verbose rebuildBundles [ 'async', 'bindings', 'nan', 'optimist', 'sf' ]
2454 info install serialport@1.3.1
2455 verbose unsafe-perm in lifecycle false
2456 info serialport@1.3.1 Failed to exec install script
2457 info /usr/local/lib/node_modules/spark-cli/node_modules/serialport unbuild
2458 info preuninstall serialport@1.3.1
2459 info uninstall serialport@1.3.1
2460 verbose false,/usr/local/lib/node_modules,/usr/local/lib/node_modules/spark-cli/node_modules unbuild serialport@1.3.1
2461 verbose /usr/local/lib/node_modules/spark-cli/node_modules/.bin,[object Object] binRoot
2462 info postuninstall serialport@1.3.1
2463 verbose about to build /usr/local/lib/node_modules/spark-cli
2464 info /usr/local/lib/node_modules/spark-cli unbuild
2465 info preuninstall spark-cli@0.2.92
2466 info uninstall spark-cli@0.2.92
2467 verbose true,/usr/local/lib/node_modules,/usr/local/lib/node_modules unbuild spark-cli@0.2.92
2468 verbose /usr/local/bin,[object Object] binRoot
2469 info postuninstall spark-cli@0.2.92
2470 error serialport@1.3.1 install: `node-gyp rebuild`
2470 error Exit status 127
2471 error Failed at the serialport@1.3.1 install script.
2471 error This is most likely a problem with the serialport package,
2471 error not with npm itself.
2471 error Tell the author that this fails on your system:
2471 error node-gyp rebuild
2471 error You can get their info via:
2471 error npm owner ls serialport
2471 error There is likely additional logging output above.
2472 error System Darwin 13.1.0
2473 error command "node" "/usr/local/bin/npm" "install" "-g" "spark-cli"
2474 error cwd /Users/jacob/Documents/sparkcore
2475 error node -v v0.10.26
2476 error npm -v 1.4.3
2477 error code ELIFECYCLE
2478 verbose exit [ 1, true ]
