I am using the WEB IDE to compile a new project using the “SparkFunMicroOLED.h” library. However when i compile the program i get “SparkFunMicroOLED.h: No such file or directory”
This sometimes happens.
Can you just try changing #include <SparkFunMicroOLED.h>
It also helps if you show us your code, which device, and what version of system firmware you’re compiling against.
I am using a Photon with Firmware Version 7
I have changed quotes to <> but this still brings up the same error
test code below
// Blink an LED
#include "SparkFunMicroOLED.h"
int led1 = D0; // Instead of writing D0 over and over again, we'll write led1
// You'll need to wire an LED to this one to see it blink.
int led2 = D7; // Instead of writing D7 over and over again, we'll write led2
// This one is the little blue LED on your board. On the Photon it is next to D7, and on the Core it is next to the USB jack.
// We are going to tell our device that D0 and D7 (which we named led1 and led2 respectively) are going to be output
// (That means that we will be sending voltage to them, rather than monitoring voltage that comes from them)
// It's important you do this here, inside the setup() function rather than outside it or in the loop function.
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// To blink the LED, first we'll turn it on...
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
// We'll leave it on for 1 second...
delay(1000);
// Then we'll turn it off...
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
// Wait 1 second...
delay(1000);
// And repeat!
Hi Peekay123
Many thanks. I didn’t attach the library (oops - New to this environment) so I have now and this works now. I had the same problem with another app using this library and the MQTT library. I reattached the MQTT library and this now works
Many Thanks
