Spark.variable as trigger
Hi all,
I was doing some tests with IFTTT and I wanted to use spark.variable as a trigger.
However, I cannot select the variable as a trigger. The dropdown box " If (variable name)" only shows my core name instead of the variable name. I also cannot select my core in that same dropdown box. Is this an issue only I have due to a fault on my side or do more people experience this?
For that to work, you need your variable to be exposed. It will then be added to the list, underneat your Core name. It should look something like this (in the app):
I got it working with help of @moors7 by using Spark.process(); in my code, somehow my WiFi connection failed otherwise.
