Hello,
does anyone have an idea what I’m doing wrong?
TCPServer server = TCPServer(90);
TCPClient client;
int led = D7;
int incomingByte;
pinMode(led, OUTPUT);
server.begin();
while(!Serial.available()) SPARK_WLAN_Loop();
Serial.println(Network.localIP());
Serial.println(Network.subnetMask());
Serial.println(Network.gatewayIP());
Serial.println(Network.SSID());
if (client.available()) {
incomingByte = client.read();
Serial.write(incomingByte);
if (incomingByte == '1')
digitalWrite(led, HIGH);
Serial.println("LED ist eingeschaltet!");
if (incomingByte == '0')
digitalWrite(led, LOW);
Serial.println("LED ist ausgeschaltet!");
None of the led function on the terminal ?!
Regards from Germany
Marc
Dave
August 4, 2014, 9:03pm
2
Hi @MarcGermany ,
That program won’t do anything until you open a serial terminal and hit a key to start it up. It also isn’t listening for connections or start a server, it just checks the socket that hasn’t been opened. I think you want something like:
if (client.connected()) {
//do things
else {
// if no client is yet connected, check for a new connection
client = server.available();
David
this should get you started:
// import libs
#include "application.h"
#include "spark_disable_cloud.h"
// init vars
TCPServer server = TCPServer(23);
TCPClient client;
// set led as output
pinMode(D7, OUTPUT);
// start server
server.begin();
// loop until data stops
while (client.available())
// handle keypress events
switch ((char)client.read())
case '1':
// 1 turns on
digitalWrite(D7, HIGH);
break;
case '0':
// 0 turns off
digitalWrite(D7, LOW);
break;
case 'q':
// q quits
client.stop();
break;
else
// wait for new connections
