what does while(!Serial.available()) SPARK_WLAN_Loop(); means
TCPServer server = TCPServer(23);
TCPClient client;
// start listening for clients
server.begin();
// Make sure your Serial Terminal app is closed before powering your Core
// Now open your Serial Terminal, and hit any key to continue!
Serial.println(WiFi.localIP());
Serial.println(WiFi.subnetMask());
Serial.println(WiFi.gatewayIP());
Serial.println(WiFi.SSID());
if (client.connected()) {
// echo all available bytes back to the client
while (client.available()) {
server.write(client.read());
} else {
// if no client is yet connected, check for a new connection
client = server.available();
this is from the doc
i wanted to be able to connect using TCP without serial but this has to connect to serial first
i been unable to connect to tcp without using serial first
